stroker
stroker SuperDork
11/23/16 9:36 p.m.
Air cooled VW dirt track car. Call it redneck Formula Vee.
http://springfield.craigslist.org/cto/5863029026.html
singleslammer
singleslammer PowerDork
11/24/16 8:09 a.m.
That is awesome
Stampie
Stampie Dork
11/24/16 8:28 a.m.
I want that so bad. I have visions of Subaru engine and hooning.
stroker
stroker SuperDork
11/24/16 9:53 a.m.
We need to have an air-cooled sub-class at the Challenge someday...
cj32769
cj32769 New Reader
11/24/16 11:28 a.m.
I am curious about the shift linkage it's a swing axle transmission set up for mid engine with what appears to be a hydraulic clutch slave. At first I thought it might have been 914 transmission until I saw the swing axles. Is it a flipped vw transmission? Maybe someone was able to swap the diferential from one side to the other to have 4 speeds forward and not 4 speeds backwards? I have heard of people accidently putting the diff part of transaxles in wrong and getting the wrong direction from the wheels 1 speed forward and 4 or 5 backwards. So if you plug the vent hole I guess you can flip a type 1 transmission? Looking at the ad again it has to be a diff sway or else the starter would be in the wrong place and the bolt pattern wouldn't match up right? Either way a very cool piece of work.
nocones
nocones UltraDork
11/24/16 12:03 p.m.
Looks like a SCCA D/Emod Type 3 sedan to me. Appeard under the new rules that if built to SCCA rules it Should be challenge legal.
I'm kinda glad that's far enough away to not tempt me. It looks cool.
Stampie
Stampie Dork
11/24/16 12:58 p.m.
I just came this close to texting the seller. Was able to resist. Might not once I have a few drinks.
patgizz
patgizz UltimaDork
11/24/16 2:02 p.m.
Stampie wrote: I just came this close to texting the seller. Was able to resist. Might not once I have a few drinks.
Someone pass this man a bottle!
RossD
RossD UltimaDork
11/24/16 2:15 p.m.
cj32769 wrote: I am curious about the shift linkage it's a swing axle transmission set up for mid engine with what appears to be a hydraulic clutch slave. At first I thought it might have been 914 transmission until I saw the swing axles. Is it a flipped vw transmission? Maybe someone was able to swap the diferential from one side to the other to have 4 speeds forward and not 4 speeds backwards? I have heard of people accidently putting the diff part of transaxles in wrong and getting the wrong direction from the wheels 1 speed forward and 4 or 5 backwards. So if you plug the vent hole I guess you can flip a type 1 transmission? Looking at the ad again it has to be a diff sway or else the starter would be in the wrong place and the bolt pattern wouldn't match up right? Either way a very cool piece of work.
The ring gear is flipped to the other side and the transaxle is turned 180°. Its still right side, notice the starter is still higher than the axles. "Flipped" is just the colloqiualism.
Stampie
Stampie Dork
11/24/16 4:39 p.m.
I really really don't need this. It'll be years before I could get to it. Seriously I have 3 more projects in front of it.
Dusterbd13
Dusterbd13 PowerDork
11/24/16 4:46 p.m.
In reply to Stampie:
Ill put 20 down to your paypal to encourage you to buy it
Stampie
Stampie Dork
11/24/16 6:20 p.m.
There's no VIN on it. That breaks my rule of at least pretending to have all vehicles street legalable. I'm out.
stroker
stroker SuperDork
11/24/16 8:35 p.m.
Uh, Stampie... Dunno if this would be of any use to you--titled 914 to merge with the dirt car? $900?
http://kansascity.craigslist.org/cto/5865338131.html
Stampie
Stampie Dork
11/24/16 8:41 p.m.
Why do y'all do this stuff to me? What did I do to you to deserve this? Lucky for me I'm not willing to make two trips to Missouri to get both cars.
stroker
stroker SuperDork
11/24/16 8:49 p.m.
Stampie wrote: Why do y'all do this stuff to me? What did I do to you to deserve this? Lucky for me I'm not willing to make two trips to Missouri to get both cars.
Two trips? If you're going for one, get 'em both on the same trip--they're only a couple of hours apart. It sounds like you could cut that 914 in half with a portable sawzall and put in the back of a pickup then pull the dirt car on a trailer... Don't forget WalMart has Black Friday turbos cheap...
Stampie
Stampie Dork
11/24/16 8:51 p.m.
You're not helping here.
stroker
stroker SuperDork
11/24/16 8:54 p.m.
Stampie wrote: You're not helping here.
It's my job. I'm a GRM enabler.
patgizz
patgizz UltimaDork
11/25/16 8:59 a.m.
You should see the text i sent him
singleslammer
11/25/16 9:37 a.m.
I have an empty trailer going to Huntsville. That would get it a fair way there. Going down the 14th.
stroker
stroker SuperDork
11/25/16 9:38 a.m.
too bad there's no way to know if the cage meets SCCA spec without driving all the way down to look at it.
patgizz
patgizz UltimaDork
11/25/16 3:18 p.m.
If anyone grabs it i need those skinny front wheels
eQ7l8FbJHcp2lYx8FR4qpSuWBj1aR7eZXCQCXfuLLIzQzrrI0t8sOIhvlZNnfa4c
