joeman
joeman New Reader
5/4/24 1:02 p.m.
I need pics of removable SM legal wings and possibly tips on making one.
sleepyhead the buffalo
sleepyhead the buffalo PowerDork
5/4/24 7:32 p.m.
What's an "SM legal Wing"?
I know lots of people don't like Aero because it's hard.   But I never thought it reached the point of being Saddistic or Masochist?  Maybe I'm just a Buffalo in Denial?
johndej
johndej UltraDork
5/4/24 7:50 p.m.
I'm 99.9% sure they are entirely forbidden by the rules. Feel free to post the rules by whichever sanctioning body you are running under but I've never seen a spec miata with a wing. It's a "low cost" class designed to not have these contests to begin with.
ojannen
ojannen HalfDork
5/10/24 9:57 p.m.
I would contact 9 lives racing.  They should be able to answer your question.  I assume SM means street modified and not spec Miata in this question.
camopaint0707
camopaint0707 HalfDork
5/13/24 7:12 a.m.
I'd guess street modified for scca autocross rules
5/13/24 8:09 a.m.
can you give me the tl;dr on those?  buffalos and scca ax rules don't mix.
I assume there's a size limit and a restriction on them being "single element"?
ojannen
ojannen HalfDork
5/13/24 4:23 p.m.
Paraphrasing a bit
  • Wings size is limited to 8 sq ft (total) and limited to two elements
  • Wing endpoints are limited to 200sq inches and limited to two endplates
  • Supports should attach to the rear deck/hatch.  They trunk/hatch still needs to be openable.
  • The wing must be fully within the body work from the top, less than 6" above the roof, and less than 6" forward of the rear axle
There should be a fully legal off the shelf option for the 350z.  The mounts are hard to make yourself because they normally need to go in the panel gap between the trunk and the rear quarters.  If you are good with a 3d printer,  you can probably download an airfoil and print it in 6" sections, then wrap it in carbon fiber or fiberglass for strength.
VolvoHeretic
VolvoHeretic SuperDork
5/29/24 9:39 p.m.
I can't help with anything but after much consideration and observation of the swan neck wing uprights, I have improved them with the Reverse Swan Neck. smiley
j_tso
j_tso Dork
5/31/24 2:18 p.m.
In reply to VolvoHeretic :
Audi has done that on the R8 GT3
VolvoHeretic
5/31/24 10:41 p.m.
In reply to j_tso :
Dang, too slow again. indecision
Inwx076T0SBhSOCILKedzdU5ykfD4v5Wuv8BhIOOqzCnZUsugiTRssgkWkEEvAlG
