1 2 3 4 5
ransom
ransom SuperDork
2/3/13 4:30 p.m.
Woohoo!
Thanks for the inspiration! Heading out to work on the shop wiring...
CLynn85
CLynn85 Reader
2/3/13 9:14 p.m.
ditchdigger wrote: I did it!! I tried a few hillbilly methods like the picture above but it turns out most bottle jacks don't work on their sides so I decided to make our press taller two feet did the trick Uploaded from the Photobucket Android App
"What's the worst that could happen?"
chandlerGTi
chandlerGTi Dork
2/3/13 9:54 p.m.
Oooo, oooo, I know!
aussiesmg
aussiesmg UltimaDork
2/3/13 10:17 p.m.
Nice build, here's some inspiration
I spent a large part of my childhood getting driven around in one of these
ditchdigger
ditchdigger SuperDork
2/9/13 10:07 p.m.
Falcon 7.5" VS Explorer 8.8"
It is strange to me that Ford used so many parts for so long. The explorer drum hardware is identical to the falcon stuff, the e brake cables hooked right up. Even the rubber brake line was the right length and the same SAE thread and hooked right up.
I tried to lower the rear an additional half inch but I couldn't get the wheel on at two inches it is a bit of a puzzle to twist it in there. Swapping to discs or stepping up to 17" wheels would fix that.
Stepping up to the front I tore apart the passenger side and made a template for the "shelby drop".
I went with 1" down and 1/8" back since any more would require welding in reinforcements in the engine bay.
bolt in, drill new.
To go with the control arm drop I changed the ball joint angle
pie cut
bend and weld
Tomorrow I do this to the other side and put it all back together with the disc brake knuckles
CLynn85
CLynn85 Reader
2/10/13 7:48 a.m.
Those wheels look killer on there, never thought a late model wheel could look so perfect on a 60's anything.
Can't wait to see pics of it out in the open on all 4s.
The_Jed
The_Jed Dork
2/10/13 8:23 a.m.
I'm not very knowledgeable with older Fords so I'm curious, why change the ball joint angle?
Does the stock angle do bad things when combined with the Shelby mod?
Epic DD by the way!
ditchdigger
2/10/13 10:42 a.m.
As low as I have this car the ball joint was at its limit in full bump. By dropping the inner mounting point it would run out of travel and possibly broken if not bind. You can buy a kit that has a wedge shaped spacer to fit under the ball joint to fix this but this seemed just as easy and free.
AngryCorvair
AngryCorvair PowerDork
2/10/13 10:48 a.m.
mcdonald's should give you back your jingle. i'm lovin' it.
aussiesmg
2/10/13 3:20 p.m.
I want to see a full car pic showing the ride height and wheels
Nice job
Nathan JansenvanDoorn
Nathan JansenvanDoorn Dork
2/10/13 3:33 p.m.
I second Aussiesmg's request! I love these cars...
ditchdigger
2/10/13 5:32 p.m.
You asked for it
ditchdigger
2/10/13 5:39 p.m.
Some of the crap removed
Tossed a new center link and tie rods in there
Brakes!!!!
I squealed a bit when it hit the ground the first time.
What I have left now is mounting the 91 Ranger master cylinder and running new front brake lines, source a flange yoke and adapter U joint for the explorer rear and shorten my drive shaft.
The car has about 2 inches of toe in at max adjustment so I need to shorten the tie rods too. Then it should be bleed the brakes and send it off for an alignment.
God I hope it drives better. How can it not?
4Msfam
4Msfam New Reader
2/10/13 5:56 p.m.
That looks so right! Nice going!
crankwalk
crankwalk Reader
2/10/13 6:11 p.m.
Those wheels look perfect on it! Nice job!
fasted58
fasted58 UberDork
2/10/13 6:13 p.m.
very well done
singleslammer
singleslammer Dork
2/10/13 6:52 p.m.
That turned out great! Keep it up.
Billy_Bottle_Caps
Billy_Bottle_Caps HalfDork
2/11/13 10:56 p.m.
Man love the stance and the overall look
DuctTape&Bondo
DuctTape&Bondo HalfDork
2/12/13 10:32 a.m.
Very well done!
bgkast
bgkast Reader
2/12/13 12:14 p.m.
Hot!
aussiesmg
2/12/13 1:53 p.m.
Great googly moogly
pres589
pres589 SuperDork
2/12/13 2:32 p.m.
It's crazy how a set of relatively inexpensive wheels and spacers and some lowering work has turned this into something really special to look at vs. how it originally appeared.
Ranger50
Ranger50 UberDork
2/12/13 2:36 p.m.
What is with the out of place and huge black mirror????
I wish I had never seen this thread... Would make the $2500 63 2dr primered Falcon on CL less tempting.....
Gearheadotaku
Gearheadotaku UltraDork
2/12/13 2:49 p.m.
Wow!
I've heard of alterations done to control arms like that before. How do you figure out how big a cut to make?
pres589
pres589 SuperDork
2/12/13 2:51 p.m.
Wait, yeah, what's with the mirror on the driver's door? Shouldn't be too hard to change though.
1 2 3 4 5
ntdrX58MbcNAyDJJ5YgMsI1yquDp2p0sBdOpFSM36N8OChNXPGqIDpyXrcirtnGD
