6/30/24 1:35 p.m.
Indy - Guy said:
In reply to DIYCustoms :
This is a BRILLIANT solution.
I'm totally stealing this concept when I get around to building my trans tunnel.
I said the same thing. Brilliant.
DIYCustoms
DIYCustoms New Reader
6/30/24 1:35 p.m.
DIYCustoms
6/30/24 1:36 p.m.
DIYCustoms
6/30/24 1:42 p.m.
new power plant
DIYCustoms
7/13/24 9:23 a.m.
NOHOME MegaDork
7/13/24 11:39 a.m.
Thanks for the update. Kinda slipped off my radar for a while and its good to know that the project is not dead.
DIYCustoms
7/13/24 9:43 p.m.
In reply to NOHOME :
Going full bore!
DIYCustoms
7/24/24 10:54 a.m.
Volvo came back from the media blaster
84FSP
84FSP PowerDork
7/24/24 11:19 a.m.
Oooh looking good!  Like the floor/tunnel work.
DIYCustoms
7/26/24 12:52 p.m.
1965 Volvo 1800s sprayed in PPG epoxy primer
wvumtnbkr
wvumtnbkr UltimaDork
7/26/24 2:23 p.m.
DIYCustoms said:
Looks familiar!  Your headers look WAY nicer than the ones I made for my 3900.  However, that collector looks awfully familiar!
DIYCustoms
7/30/24 11:29 p.m.
In reply to wvumtnbkr :
Yes the flat collector solved the issues between the frame and starter
DIYCustoms
7/30/24 11:33 p.m.
NOHOME MegaDork
7/31/24 8:07 a.m.
If that steering rack is mounted in position, then that is an interesting approach angle for the steering column.
akylekoz
akylekoz UberDork
7/31/24 8:24 a.m.
What is going on with your shop?  Seriously can you at least throw a misplaced coffee cup or random tool out there, you're making me feel bad.
I'm adding more lights to my shop and was concerned about adding too many fixtures, based on what I see here it will be fine.
Great project, carry on.
Ian F (Forum Supporter)
7/31/24 4:37 p.m.
You'll definitely want to check the steering geometry before going too far down that road.
Flaming River sells a 90 deg device that might actually make that rack input angle work reasonably well with the OE Volvo column shaft.
DIYCustoms
8/2/24 12:47 p.m.
Just loosely mounted. Still need to adjust the output pitch
DIYCustoms
12/20/24 8:49 a.m.
Engine bay painted with a single stage system because its much easier to repair a scratch if needed.
Baking in the booth at 80 degrees
DIYCustoms
12/20/24 8:51 a.m.
Regatta Blue is the choice of color. Used Sprint H79 clear. Sprayed 2 coats....cured 24 hours...wet sand 600 .... applied 2 more wet coats of clear.
Engine bay shown in Champion White and front grill snorkel area completed
DIYCustoms
12/20/24 8:52 a.m.
getting ready for color!
Body in 2 coats of hi-build primer and ready for blocking
DIYCustoms
12/20/24 8:54 a.m.
Installing tear drop exhaust thru the side rear quarters
DIYCustoms
12/20/24 8:56 a.m.
The fuel delivery will be through the rear deck lid as the Cyan Volvo was constructed.
DIYCustoms
12/20/24 8:56 a.m.
Cobra style fuel cap mocked in place.
12/20/24 9:26 a.m.
Love seeing this on Page 1 again!
golfduke
golfduke SuperDork
12/20/24 10:06 a.m.
Dang, that color is gorgeous.
Q2gsnYqhJtaAG3O8VsuJyo7uSAhQPE10zg7sclAZzi1nHnW88ZMqL97TiQksc0iW
