mazdeuce
mazdeuce MegaDork
8/24/17 5:24 p.m.
Not the world's best picture, but that stuff you see at the back of the intake port is winter mouse food. Oldopelguy many be able to indentify the specific grain. Unsurprisingly this is on the cylinder I'm fighting. I should probably ask you guys about disassembling and checking heads.
And three of the five exhaust manifold bolts rounded off. I'm getting good at bashing smaller sockets onto bolts. Useful skill.
coexist
coexist Reader
8/24/17 8:17 p.m.
I recently bought a 16/9 20" monitor with DVI input at the thrift store for $12. Seems to be pretty common there, as long as it's under 23".
There are dvi to vga adaptors,(and hdmi to vga) which we use for our older projector.
csmith1510
csmith1510 New Reader
8/24/17 9:20 p.m.
You need a Go Pro and helmet or a body cam like the police use so you can just video it all, then take still shots from that to share.
as far as PC build, use an SSD for the OS and a regular drive for storage.... just saying.
mazdeuce
mazdeuce MegaDork
8/24/17 9:49 p.m.
In reply to csmith1510:
Deucekid#2 was pretty insistent this summer that I needed a time lapse go-pro. The problem is that 70% of the footage would be me drinking coffee poking at stuff, and so far most of the rest would be me hitting things with a variety of hammers.
Speaking of which there are 8 empty bores and 8 pistons sitting in their labeled spots.
java230
java230 SuperDork
8/24/17 9:54 p.m.
We wanted to see you beating it out!
And you can do like 32 frames a second at 2 min intervals. That's a lot of coffee drinking
sleepyhead
sleepyhead Reader
8/24/17 9:57 p.m.
just make sure to drink it "out of frame", and then set the cup down "in frame" from time to time ...
actually, this gives me an idea for when temps around here cool off
Run_Away
Run_Away HalfDork
8/24/17 11:00 p.m.
java230 wrote: We wanted to see you beating it out!
Phrasing!
mazdeuce
mazdeuce MegaDork
8/25/17 9:31 a.m.
The outer rain bands of Hurricane Harvey are sprinkling here north of Houston. The storm track is right now is ridiculous with rain for the next six days and the storm passing over us Wednesday of next week. We're going to hope that changes. In preparation I slotted the cab support back in, lowered the cab, and gave the truck a shower cap. Not sure how much it will help, but it probably won't hurt. Biggest danger in my yard is always falling trees. Not much can be done about that.
pres589
pres589 PowerDork
8/25/17 9:44 a.m.
I like the idea of an old dslr, an intervalometer, and some cheap lens that can go reasonably wide. Stop the lens down, turn off the autofocus, and let the camera run the exposure out as long as it wants.
bluej
bluej UltraDork
8/25/17 10:01 a.m.
How are those panning time lapse vids done? I'm assuming some sort of track, but what drives the camera rig along it? It seems smoother than if the camera mer just moved by hand a 1/32" along every time.
java230
java230 SuperDork
8/25/17 10:08 a.m.
In reply to bluej:
Camera track/dolly, some are powered to move on their own very slowly....
759NRNG
759NRNG HalfDork
8/25/17 12:03 p.m.
See your trees and raise you......see you found an eyeball....lookin' gooood!
mazdeuce
mazdeuce MegaDork
8/25/17 12:08 p.m.
In reply to 759NRNG:
I put the eyeball back in a while ago. It's not in all the way and would fall out if the truck could move under it's own power, but the blank spot was bugging me. I like looking at it with the cab down. It's handsome.
759NRNG
759NRNG HalfDork
8/25/17 1:05 p.m.
why yes it is in COE kinda way......
rich_27
rich_27 New Reader
8/25/17 4:19 p.m.
Love the shower cap. That truck exudes personality!
759NRNG
759NRNG HalfDork
8/25/17 4:40 p.m.
But it's bum is showing .....kid's don't look!
Ransom
Ransom PowerDork
8/25/17 5:51 p.m.
Hope the weather calms down over there!
Unrelatedly, another one for the opportunity to play along with the charismatic old truck game! Nominally runs, drives, and is a Mack to boot, for $2500...
https://portland.craigslist.org/wsc/cto/d/1968-mack-gold-series/6245593340.html
SaltyDog
SaltyDog New Reader
8/25/17 7:08 p.m.
Echoing Ransom's wishes on the weather! Just turned on the TV to see Jim Cantore getting his butt kicked in Corpus Christi by this storm!
hhaase
hhaase HalfDork
8/25/17 7:12 p.m.
SaltyDog wrote: Echoing Ransom's wishes on the weather! Just turned on the TV to see Jim Cantore getting his butt kicked in Corpus Christi by this storm!
Never a good sign when Jim "harbinger of the apocalypse" Cantore shows up in your town.
SaltyDog
SaltyDog New Reader
8/25/17 7:30 p.m.
mazdeuce
mazdeuce MegaDork
8/25/17 9:18 p.m.
I pulled the other exhaust manifold off. Broke one bolt. I'll get to play with an ez-out later and then drill and tap anyway. Another exhaust port full of food. Then I dragged the valley cover off the pile of parts. Whoever sealed things last seems to have used clear sealant. Silicon bathroom caulk? And then a bit of wire brushing. Hard to get it perfect with the current lighting. Everything will get painted before it goes back. I'm excited to make it look pretty. More crappy pictures. Duecekid#2 is using the memory card from the camera to try and load Linux onto his computer. He's close.
Ransom
Ransom PowerDork
8/26/17 12:12 a.m.
Bonus points for Linux experience, whatever gaming comes (or doesn't) of it!
ScottS778
ScottS778 New Reader
8/26/17 8:55 a.m.
Looking good on this project as well.
Make sure to use paint for engines on the internal parts don't want cheaper stuff rolling off and clogging the oil return ports. ( don't ask me how I know that)
Broken bolts are part of the game. Do you have a torch and welder? You can weld hex nuts on the end of broken off bolts and get them out. EZ outs are a pain and I try and avoid them unless it is a last resort. You can also drill out the offending part until it gets very thin, then it will unwind like a spring usually, be gentle as it breaks off as well. Bolt will give you some bolt removal ideas.
Many flavors of Linux out there. I have run Linux of some sort since 2010 on my computer and am now. The CEO runs win 10 on the one she uses. Let him have a look at distrowatch.com for reviews and examples.
Good luck with the weather.
Scott
The0retical
The0retical SuperDork
8/26/17 9:52 a.m.
Mint is stupid easy to get started with.
Gentoo is intermediate.
Slack is very manual.
He'll need winex if he wants to do any gaming.
mazdeuce
mazdeuce MegaDork
8/26/17 10:59 a.m.
He installed Ubuntu and something called wine. It has him going so far but I just passed the winex recommendation on to him. Yesterday was frustrating for him, I'm proud of him for sticking with it and solving some problems to get the machine up and running. He's installing Rocket League right now. He's annoyingly excited.
As for me, it's raining. Quite a lot. I get bored inside, walk out to the Grosh, clean something, go back inside, rinse and repeat.
The fuel pump has......something.......inside it. I'm a bit afraid to take it apart inside because I know what old gas smells like. More of that after the rain stops.
And the timing cover. I'm starting to appreciate the artistry in timing covers. I think I could become a collector of timing covers.
Q7GPQAqyFovxr8LUglHJaNzBiDunq6uzQUXKHl60xHO4Gpp9Dxl9xitXFa2C73V7
