In reply to GoLucky :
The goal for the van is to be just a cool parts hauler with about the same power to weight as a 90's minitruck. The engine that is currently in it is a 225 that hasn't run in over a decade, and the compression test I ran on it doesn't bode well for it (70ish psi on all but #2, which had 90). The transmission is currently held up with a ratchet strap, and I'm missing some of the clutch linkage, so I figured I'd swap it.
Swapping a Mopar V8 into it has a few disadvantages, mainly that the LA series V8 hasn't been produced in almost 20yrs, so any example I find is likely going to need a rebuild (or at least freshening up), and you're stuck with a Chrysler automatic transmission to put behind it (see also: rebuild, upgrade or very expensive standalone for the 8hp), or an adapter plate to put a GM transmission behind it. Most stock (or nearly stock) 318 magnums only put out about 180hp at the wheel, with about 230 ft/lbs of torque, and are fairly thirsty to boot.
Swapping in a LS would make significantly more power, and allow a decent transmission selection, and I am kicking around the idea, but then it's just "another LS swap".
Rebuilding the 6 is entirely possible, but the amount of money needed to be sunk into it in order to move the van at a reasonable pace would more than pay for a V8 swap.
MZR (duratec) 2.5 makes 170ish HP, 170ish torque at the wheels in a Miata (about double the HP, about the same torque as a 225, almost the same HP as a stock 318 magnum), new enough to get a low mileage unit, small enough to fit in the van's engine bay and be pretty easy to work on, and has a few RWD automatic transmissions that can be bolted to it (Mazda 6 spd, Ford 5 spd, Ford 6 spd, Ford 10spd). It also can usually be had for about the same price as a camshaft for a Mopar V8, or what Holley charges for LS swap mounts.
The reason I asked about the trans is I had a lead on a wrecked NC (2009) a few months back that had one in it. My thinking was to buy the car, sell the 2.0, and swap a boneyard 2.5, that trans and the harness/ ecu/ tcu into the van, but I couldn't find any info on the trans, so I (stupidly) didn't jump on it.
I realize that looking at if from a pure displacement standpoint, it does sound kinda dumb- and If I were building a hot-rod, the MZR wouldn't be anywhere near the top of the list. All I am looking for is "easy to work on, easy to get parts for, capable of keeping up with modern traffic, and cruising at 70", so "same torque, twice the power and twice the gears for the same cost as rebuilding what's there" starts to make a bit of sense.
