conesare2seconds
conesare2seconds Dork
7/15/18 3:40 p.m.
GMC motorhome on the street, Saab 9-3 Estate in the driveway. You, sir, a living a life. Congratulations on the purchase.
Wally
Wally MegaDork
7/15/18 3:48 p.m.
californiamilleghia said:
When you have a chance can you measure how much room between the rear wheelwells ?
and since most of the newer Motor homes have slide out rooms , has anyone done that on a GMC ?
They also sold these as a mobile  "Office"
When I was a kid the local fire department had one as an ambulance.
m4ff3w
m4ff3w UberDork
7/15/18 5:42 p.m.
GTV6 under car cover (baby sitting Hungry Bill's)
m4ff3w
m4ff3w UberDork
7/15/18 5:43 p.m.
Got the engine spun over by hand this morning, installed new plugs and made new 8mm plug wires.
She will run on ether.
Need to figure out how to dispose of 40 gallons of bad gas.
Ian F
Ian F MegaDork
7/15/18 7:33 p.m.
Drain it and mix it in with lawn mower gas.
Trans_Maro
Trans_Maro PowerDork
7/15/18 7:55 p.m.
What would Kid Rock do?
759NRNG
759NRNG SuperDork
7/15/18 8:03 p.m.
Bring it(stale gas) to my house(Magnolia Tx. just sayin') and let me use it on the BURN pile.....late...... great score on da 'BUS' always wanted one
Pete Gossett
Pete Gossett MegaDork
7/15/18 10:11 p.m.
Drink it?
m4ff3w
m4ff3w UberDork
7/15/18 10:14 p.m.
Saw some fuel being squirted out of the injectors, but it stopped..
Not getting fuel out of the tank.
Suck up some fuel into the high pressure pump from a jar and she started right up.
I hear what I think is the in tank pump prime, but no fuel comes out.  More trouble shooting to follow.
Gotta say, I didn't think I'd hear it run the 2nd day I had her home.  Super happy with the purchase!
AngryCorvair
AngryCorvair MegaDork
7/16/18 12:57 p.m.
In reply to m4ff3w :
got a way to blow some air pressure through the fuel line from the engine to the tank?  maybe the pump inlet in the tank is crudded up with sediment?   worth a shot just because it's a cheap thing to test.
m4ff3w
m4ff3w UberDork
7/16/18 1:35 p.m.
Yup, that was my plan for this evening.
Dusterbd13
Dusterbd13 MegaDork
7/16/18 2:52 p.m.
Make sure you remove the gas cap first. I did that one time and didn't wound up pressurizing the tank and blowing all the gas out of the filler neck
m4ff3w
m4ff3w UberDork
7/16/18 3:08 p.m.
In reply to Dusterbd13 :
Thanks for reminder.
SONICJK
SONICJK
7/16/18 3:14 p.m.
Awesome!
Good to see other people messing with these.
If you have any questions shoot me a message, I've had them down to the frame and a shell and back.
Here's mine
www.thegmcrv.com
Run_Away
Run_Away HalfDork
7/16/18 3:15 p.m.
In reply to SONICJK :
Drool!!
m4ff3w
m4ff3w UberDork
7/16/18 3:17 p.m.
Oh E36 M3!  I've seen your site, didn't realize you were on here.  Amazing work!
m4ff3w
m4ff3w UberDork
7/16/18 3:18 p.m.
I like the name Onan the Barbarian.  My slide is stuck, need to figure that out so I can see if it works.  It doesn't try to start when I hit the button on the wall.
Antihero
Antihero HalfDork
7/16/18 3:35 p.m.
that is awesome
MadScientistMatt
MadScientistMatt PowerDork
7/16/18 4:16 p.m.
Looks like quite a score! I've sometimes wanted to fix up an old motorhome for a long road trip myself.
SONICJK
SONICJK New Reader
7/16/18 6:01 p.m.
Yeah man I'm a bit of a lurker around here.
I've got a lot of projects, an e30 rallycross car is next on the docket!
californiamilleghia
californiamilleghia Reader
7/16/18 6:14 p.m.
I really like the white on the inside , most campers are dark wood and when old look depressing ,
Great Job
m4ff3w
m4ff3w UberDork
7/18/18 8:33 a.m.
So air into the primary fuel tank hose just blows.  Can't tell if it is blowing into the tank or above the tank.  So that tank needs to get dropped.  I was able to get the drain plug out, what's in there doesn't even smell like gasoline.
Shooting air into the hose for the aux fuel tank (both are 25 gallons) and I can't get air to flow at all.  Drain on it is stripped (by me :( )
SONICJK
SONICJK New Reader
7/18/18 3:05 p.m.
Dropping the tanks isn't that bad so long as you can fit under it.
Some ramps to drive up on would make it MUCH easier.
ALL the fuel line needs to be replaced anyway to stand up to these E36 M3ty fuels we have today.
stylngle2003
stylngle2003 Reader
7/19/18 1:50 p.m.
Sonic, that interior is amazing.  Any more pics?
I love the orange.  And the name Onan the Barbarian.  Following along
java230
java230 UltraDork
7/19/18 2:46 p.m.
Just in case you have not seen this....
Landspeed record version
Fantastic project!!
55NnyFWKUqzuv8MbKkfhXv0QIvSjQK2Jgl4sOr5H1dwiJL8yI962ipXKGNIDK0lY
