NOHOME MegaDork
8/23/20 9:57 p.m.
In reply to java230 :
That will work.
 Remember, coarse makes flat, fine makes smooth.
bgkast (Forum Supporter)
bgkast (Forum Supporter) PowerDork
8/23/20 10:03 p.m.
Looks awesome pink. The close up finish looks like drywall texture!
8/23/20 10:04 p.m.
That's a whole lotta pink!
java230
java230 UberDork
8/23/20 10:45 p.m.
In reply to NOHOME :
I hope so! It's just sanding at this point. Hence the third coat.
java230
java230 UberDork
8/23/20 10:45 p.m.
In reply to bgkast (Forum Supporter) :
It's very drywall esk!
java230
java230 UberDork
8/23/20 10:46 p.m.
That's what she said?
java230
java230 UberDork
8/24/20 12:40 p.m.
Decent
Not quiet as nice. I had to rebuild the body line.
Lots of these
Dusterbd13-michael (Forum Supporter)
Dusterbd13-michael (Forum Supporter) MegaDork
8/24/20 12:44 p.m.
Start at 220 on the longest board you got.
Its better than you think.
java230
java230 UberDork
8/24/20 12:53 p.m.
In reply to Dusterbd13-michael (Forum Supporter) :
Not 180? And I bought a 40" just for this.....
8/24/20 12:56 p.m.
Yup. 220. High build cuts way better than i expected. 220 was almost TOO aggressive.
java230
java230 UberDork
8/24/20 1:02 p.m.
Good to know! I don't know if I even have any 220....
java230
java230 UberDork
8/24/20 4:27 p.m.
220 Procured. Ouch. 45 pieces for the big sander is one whole roll.
8/24/20 4:29 p.m.
It lasts longer than i thought it would.
Your pink stuff is self-guidecoated supposedly,  right?
java230
java230 UberDork
8/24/20 4:35 p.m.
Supposedly. Reviews seem mixed. I have dry guide coat on hand.
8/24/20 4:42 p.m.
I used black lacquer primer. Dunno how the dry stuff works!
What i learned is to not go chasing the low spots necessarily. Its way easier to fill lows with high build than it is to tap down highs.
Nohome gave some good text tips ehen i was at that stage, but muly experience boiled down to going with an x pattern in 220 until I had the whole panel done, reading the panel to the best of my ability to see what could be sanded more and what needed filler/primer. I got a feel for it after a while. But not sure how to explain....
java230
java230 UberDork
8/24/20 4:49 p.m.
Ill see what its looking like once I get paper on the panels :D
84FSP
84FSP UltraDork
8/24/20 5:47 p.m.
Awesome progress let the pink boogers commence!
java230
java230 UberDork
8/24/20 6:02 p.m.
In reply to 84FSP :
I'm wearing my mask!
It does show the highs/lows a bit. And makes a ton of dust!
Ordered soft sanders to help with the curves. That was all with the big boy. It just fits on the doors too!
wawazat
wawazat Dork
8/24/20 8:13 p.m.
The Pink Panther theme is rolling around in my head right now!
Well done!
java230
java230 UberDork
8/25/20 9:24 a.m.
Man a 30" block is a quick reminder how NOt flat it really is.... It really does turn gray when its sanded flat. It just really does not show up in the pics.
The hood and this fender are not too bad.
You can kinda see the highs and lows here.
But the hood blocked out pretty well!
Front of this fender, not great.
Adn door made me immediately sad. I quit for the night. The pink really washes the pics out.... Its not great.
This was all 220, I amy call SPI and see what they think about the epoxy sticking well to 220. Its not very toothy. I may drop to 180.
APEowner
APEowner Dork
8/25/20 9:27 a.m.
Wow.  That's looking great. Those weren't that straight from the factory.
8/25/20 10:00 a.m.
you have made great progress with this behemoth! it looks better than you think. you're suffering from "i know where to look" syndrome.
NOHOME MegaDork
8/25/20 10:11 a.m.
Epoxy will stick just fine to the 220.
The really long sanding blocks can be a bit hard to control. Something in the 20" lengths sanding in a cross section should give you more control.
Remember, you are going to shoot epoxy over this. You can afford to have several sand-throughts since the  constant you are looking for is a flat 220 grit surface. That surface can be filler if it so happens to be a high spot you sanded into. Or you can do local touch ups of anything really egregious.
Overall I think you are in pretty good shape.
Pete
java230
java230 UberDork
8/25/20 10:23 a.m.
SPI said their epoxy will be fine to 800 if I wanted. He did mention I should induce for 4 hours to overnight if possible for best UV resistance.
I am just doing the big flat areas with the big board (seems like most of it now :D ), I just hit the hood ridge with one end when I didn't see that side of it, its long.
I know I don't have enough material on to be able to sand out some of the areas. Oh well. I just don't know how much will show in final shiny paint. Its really hard to get in the pictures, in person the high/low areas are super obvious. It really does go gray.
NOHOME MegaDork
8/25/20 10:41 a.m.
Still gonna drive it in epoxy right?
If so, then it dont really matter that this be perfect. You can easily go over the spots that stick in your craw when you go to paint over the epoxy primer.
This was my first coat of high fill. It showed me where I still had filler that I could have sanded flatter. So I did. I think I did two rounds of high fill, but in both instances there was some sand-through to filler. Just part of the game.
Then I shot the Urethane over that, or in your case epoxy.
8C3ylrS1x4iAtGRlicCjYv38HIRhgFOH3TjiM0EH4PQtMREUyW4BfXyB1Ft5qRHk
