1 2 3 4 5
The_Jed
The_Jed UltraDork
6/6/14 6:37 p.m.
Struts have arrived!
At first I thought I'd been shafted since they are Excel-G's instead of GR-2's but after google-ing it turns out they are one and the same.
When I pulled off the front wheels I noticed my newly installed endlinks have already started cracking.
DAMMMIT!!!!
The_Jed
The_Jed UltraDork
6/6/14 6:38 p.m.
Step One:
The_Jed
The_Jed UltraDork
6/6/14 6:39 p.m.
One strut done:
The_Jed
The_Jed UltraDork
6/6/14 6:39 p.m.
Old and busted
New Hawtness
The_Jed
The_Jed UltraDork
6/6/14 6:41 p.m.
It's back on the ground and I'll be taking it out for a cruise tonight.
I forgot to mention, the other day I borrowed a timing light from a buddy and set the timing at 15 degrees before TDC.
The_Jed
The_Jed UltraDork
6/6/14 6:43 p.m.
In reply to SirThomasCrapper:
Welcome to GRM, Sir Thomas!
Do you have a build thread on the LeMons forum?
The_Jed
The_Jed UltraDork
6/6/14 6:52 p.m.
I also adjusted the door strikers so the doors close flush with the body and give a nice, solid "shump" when they are swung shut.
One more thing, I kept the bump stops from the old struts and put them on the new ones.
New struts = $127.xx for the pair
I need to find all of my other receipts and keep a rolling total like my blue LSC.
The_Jed
The_Jed UltraDork
6/8/14 6:29 p.m.
The front suspension has 3 positions for the ride height sensor to give you a bit of adjustment. While changing the struts I noticed that the d/s front was on the lowest setting while the p/s front was in the middle, they had some rust so it looked like they were set this way from the factory. I chalked it up to manufacturing tolerances and assumed they had been set by someone more knowledgeable than myself.
It kept bugging me though, so today I decided to lower the car. I'm not much of a fan of the muscle car rake on anything but muscle cars so I had to level this thing out.
I moved the p/s front sensor to the lowest setting then adjusted the rear sensor to drop that end about 1.5" or so.
After I was done I loaded up the kids and went to a couple of car lots to browse a bit then hit the store for a few things. I was amazed at the difference in driving feel. I love it!
SyntheticBlinkerFluid
6/8/14 8:03 p.m.
So when you coming to visit?
The_Jed
The_Jed UltraDork
6/8/14 9:09 p.m.
We should have a get-together; cook out, museum trip or train museum thing or something.
Mr_Clutch42
Mr_Clutch42 Reader
6/8/14 9:58 p.m.
Nice cruiser. I know nothing about Fords.
6/9/14 1:12 a.m.
The_Jed wrote: We should have a get-together; cook out, museum trip or train museum thing or something.
I'm all for that
The_Jed
The_Jed UltraDork
6/9/14 8:22 p.m.
One more picture:
The_Jed
The_Jed UltraDork
6/11/14 6:59 a.m.
Just filled up and it took 15.4 gallons and the car has been driven 228.9 miles, but keep in mind the car is lacking overdrive and has 3.45 gears (3,000 rpm @ 70 mph, yada, yada). Also there was lots of idle time and the a/c was run quite a bit.
Looks like 14.8 mpg. Ugh. Well that's the base line. Let's see what improvements I can make!
Edit: According to the trip minder the average mpg was 14.5 and the average speed was 22.2 mph over the course of 228.9 miles (distance according to both the trip minder and trip odometer).
The_Jed
The_Jed UltraDork
6/11/14 7:40 a.m.
That was 80% city, 20% highway.
Edit: MPG is not a big concern with this car it's just another facet of what makes an awesome car; good handling, powerful engine, decent mileage, etc...
The_Jed
The_Jed UltraDork
6/12/14 2:51 p.m.
Mr_Clutch42 wrote: Nice cruiser. I know nothing about Fords.
Thanks.
Well, the best thing to do to remedy that lack of knowledge is buy an old Fox body!
6/14/14 12:19 a.m.
I thought the OD was an easy fix? Or are you driving around in 3rd gear for a reason?
The_Jed
The_Jed UltraDork
6/14/14 6:40 a.m.
Sadly overdrive was burned out completely. I was hoping a new t/v cable bushing would solve the issue when I initially took possession of the car, but it's DOA.
6/14/14 2:23 p.m.
Well I have an '86 crown Vic coupe with an AOD in it if you're interested don't know what condition OD is in, but could be a good spare
The_Jed
The_Jed UltraDork
6/14/14 3:23 p.m.
I love boxy Crown Vics...
I appreciate the offer but I'm planning a rebuild at a local shop that's run by a friend of the family. Excessive overtime turns me into a check-writing car enthusiast; three days, done and done!
What kind of shape is it in?
Restomod?
Ranger50
Ranger50 PowerDork
6/14/14 3:50 p.m.
Loss of OD is either a band failure or servo failure. I have seen the servo o-rings fail on both rebuilds and high mileage units. Also have seen broken springs cause a loss of OD. The band will fail from either a broken attachment points or loss of material.
It really isn't a big $ job to fix, it's just a PITA to fix.
Morbid
Morbid Reader
6/14/14 4:48 p.m.
The_Jed wrote: I love boxy Crown Vics... What kind of shape is it in? Restomod?
No. No. NO.
SyntheticBlinkerFluid, you just made the list. And the list is not a good place to be.
Morbid
Morbid Reader
6/14/14 4:54 p.m.
6/14/14 5:59 p.m.
Parts dammit! PARTS!
Morbid
Morbid Reader
6/14/14 9:46 p.m.
You may have meant parts, but he interpreted it as 'new project', therefore you're both fired
1 2 3 4 5
JaOdNrquKUnGIgknMRWh6dnzJtulAzJN67NoI2KgBk80wJJdTZAeCdGO1WPoQCZB
