Update!
I'm still alive and so is the project. Its very difficult to find time to work on the car, much less update the thread. We have a newborn in the house to go along with our other 2 kids, so there's times that I might get 30 minutes/week or no time at all to work. But this last weekend the nap times seemed to be all synchronized and I put in a good 4-5 hours of work in 3 days.
New set of piston rings came! Great! Bought another full set just so I could use one of the compression rings! $38 for a set or $28 for one ring.... Seriously.
Bottom end assembled! Checked all the clearances with plasti-gauge... Basically to make sure nothing massive is wrong. There isn't much adjusting to do since I don't think I could get different grades of these bearings even if I wanted to. All the clearances (ring end gap, rod, main) seem to be on the loose end of factory spec, if not slightly outside of spec. I am not sure how to build a performance engine exactly, I think they're supposed to be loose anyway. I suppose I'll find out. I know the right way to build a street engine would be to select all the parts and/or machine the engine to have clearances within OEM specs. I'm not sure that's really going to matter on this project. I didn't find any huge problems with clearances so we'll run it and learn something (hopefully not the hard way!).
Head's back from the machine shop. Came out very good, they only had to remove .004-.005" to clean up the surfaces. The headgasket is an Ajusa. Kinda rolled the dice with this one. They made a good gasket for my old car (Sentra Spec V - QR25de) and I read really good reviews about it from the DSM guys. Its a composite gasket like the OEM and was only $21 ish. Looks good to me.
Mic'd all 2 sets of my OEM head bolts to find 1 good set within OEM specs. I was surprised at how many head bolts I found that had lengthened from being torqued. Usually I check the head bolts on Nissan engines and it's a waste of time because none of them are even close. Found quite a few that failed this time though, so I'm glad I checked. Ideally I'd use some ARP studs, if I race with this engine a lot I'll do them next time.
Head on, torqued. Timing chain, oil pump, rockers/lifters/cams put on and torqued. I had a problem with the oil pump/front cover. It looked significantly taller than the deck of the block. I was pretty pissed when I found this, as it looked like it was about .005" taller. To me this seems like it could definitely lift the head up enough and make the headgasket weaker around cylinder 1 area. People have had this problem when they deck their blocks and do not have this cover attached. I didn't deck this block so I have no idea why this is occurring. This is the oil pump that came on the block, and this engine did have a blown head gasket. I decided not to risk it, and pull the cover and try to sand it down. It doesn't have to be as precise as the block surface so I didn't mind doing it at home, it's supposed to get some RTV anyway and just needs to hold oil (not combustion pressure/coolant pressure). Kinda doubt a machine shop could have machined this surface by itself anyway, and I am NOT taking the bottom end back apart and sending it off.
Of course while all this is happening I'm constantly looking for deals on race car parts I know I'm going to need. So I snagged some Tien springs (the only one's I can find) for $80 shipped!
Some s13 alloys for $100 delivered.
....aaaaand the best part on the entire car.... Birthday present from my wife and kids!
I've been pretty much obsessed with Sparco wheels since before I could drive. So it's fitting that the only nice part on the car is the wheel. And if this car doesn't work out in the long run I can always quick-release the wheel off and take it to the next car!
More updates coming soon!
