3 4 5 6
Indy - Guy
Indy - Guy UltimaDork
12/23/24 11:56 a.m.
In reply to maschinenbau :
12/23/24 12:24 p.m.
maschinenbau said:
This will allow the engine to removed by simply unplugging the ECU and this connector while leaving the engine harness on the engine.
berkeley yeah dude, serviceability FTW
maschinenbau
maschinenbau PowerDork
12/29/24 7:59 p.m.
First drive today! It's a certified ripper! Lots of tire squeal and torque steer
wawazat
wawazat SuperDork
12/29/24 10:41 p.m.
Nice!!!  Congrats!
classicJackets (FS)
classicJackets (FS) SuperDork
12/29/24 10:58 p.m.
Nicely done!!
Piguin
Piguin Reader
12/30/24 3:12 a.m.
Just as it should be :D
¯\_(ツ)_/¯
¯\_(ツ)_/¯ UltimaDork
12/30/24 7:36 a.m.
And now I'm here for the future awd conversion after you've snapped every remaining Camry axle in north america.
maschinenbau
12/30/24 9:29 a.m.
Here's the full update. 3 main things were keeping me from a first drive: mounting the ECU to the firewall, mounting the gas pedal, and building an exhaust. Got all three done this break.
I removed the old cable gas pedal and built a bracket to adapt the 2GR electronic pedal. Pedal ergonomics seem good so far but I might tweak this later.
The ECU was just hanging out in space so I bent up one of the original brackets and drilled the firewall for rivnuts. The lower bracket got cut and welded, and attaches to a bolt for the A/C lines.
And finally, the exhaust. I had left off at the Y-pipe just behind the engine subframe which was way too loud. I added a big huge resonator from the donor car and 2.5" all the way back to a universal Walker 17615 "mega-flow turbo" muffler. It is nice and mellow at idle, cruise, and even some mid throttle. A little rasp in the higher band but so far I am pretty satisfied with the sound, especially given how cheap this system has been to build. I'll put together a sound video soon.
I am really happy that a few big questionable items have been proved:
  • The clutch, pressure plate, and flywheel combination works without any weird noises or issues. It just feels...normal!
  • The axle bearing bracket did not immediately fail!
  • Power steering pump seems compatible with the old Camry and I was able to fill and bleed it properly. And it does not leak!
  • No exhaust rattling or engine interference with the body or other parts.
  • The engine does not overheat, and the radiator fans kick on and off like they are supposed to. Heat works too.
  • No immediately bad engine codes like misfire or sensors. The questionable junkyard engine is healthy!
Of course I've uncovered a few new teething issues too. Fuel pressure setting is questionable due to the cheap gauge that came with the cheap regulator. Short term fuel trims were hovering near +20% which implies the ECU is giving it more injector to make up for lack of fuel pressure. At full throttle I get a code for knocking, even after filling up with a tank of 93. After messing with the regulator, the gauge responds erratically so I was just guessing at that point. Eventually got a lean code. So I'm going to try a nicer gauge.
But yeah, I'm pretty happy with the 6 month engine swap turnaround. I brought this engine home from the junkyard on July 27. Can't wait for the $2000 Challenge road trip!
Mezzanine
Mezzanine SuperDork
12/30/24 8:36 p.m.
Knocking at higher RPM: are you running out of injector/fuel pressure resulting in the lean condition?
riggedrevs
riggedrevs New Reader
12/31/24 12:42 a.m.
Just found this. Been hearing updates from Foster at work from time to time but didn't realize there was a build thread! I'm watching now. Cant wait to see this thing at comp.
maschinenbau
12/31/24 7:44 a.m.
In reply to Mezzanine :
That's my theory, running lean due to lower than expected fuel pressure. The 2GR normally runs a returnless fuel system that is regulated in the tank, with no manifold vacuum reference (always has constant fuel pressure). The ECU will "trim" the fuel injector pulse width to compensate for any pressure changes the best it can.
¯\_(ツ)_/¯
12/31/24 8:02 a.m.
How accessible is the tank?  Toyota generally doesn't change stuff unless they have to, so I wonder if you could drop an entire fuel pump "bucket" with regulator and all into the hole where your current stuff lives.
brad131a4 (Forum Supporter)
brad131a4 (Forum Supporter) HalfDork
12/31/24 2:46 p.m.
Another possible solution is to put a cat in and hook it up. To many after market cats in any configuration not to be running one.
maschinenbau
1/7/25 9:04 a.m.
With the shop build, haven't had any time to troubleshoot but I did drive it a couple times and it seems magically better now, with trims under +-10%.
Exhaust video. It's very mellow and quiet. Just a little rasp only when you get on it.
https://youtu.be/3gTnsqx3gN0?si=KhRBioR4sInGfXEc
Tires arrive today for the sweet new rims
maschinenbau
1/7/25 3:26 p.m.
And finally got those trash wheels replaced with RARE one-year-only 1999 Avalon Platinum Edition wheels made exclusively for Toyota by Enkei. 15x6.5 with a non-dry-rotted all-season tire. Unfortunately I'm missing two of the center caps.
maschinenbau
1/29/25 8:46 a.m.
Not much progress since the garage build is taking all my spare time. I did a brake job where I found two stuck rear cylinders, so that's better now. Up until now, I've only been carefully test-driving, monitoring my OBD scanner like a hawk it since the wiring isn't 100% complete. With the brakes done I think I'll just start driving it to work and let the problems come up naturally, but so far no new codes. It feels musclecar strong from all RPMs in all gears. If you do a pull from 2nd gear it will be spinning a front wheel in the last 2000 RPM or so before shifting. Then in 3rd it will try it again... just absolutely loving the torque. Mission accomplished on the powertrain goals for sure!
Just a couple of anonymous commute warriors, nothing to see here. Amazing how much bigger a Corolla got 20 years after this Camry.
Recon1342
Recon1342 UltraDork
1/29/25 9:09 a.m.
That thing is such a sleeper...
confuZion3
confuZion3 UltraDork
1/29/25 9:21 a.m.
This is such a cool build. Keep it up!
maschinenbau
1/30/25 9:15 a.m.
So far so good, except a couple recurring lean codes. I finally did a proper fuel pressure test with a real gauge, not that fake one that came with the regulator, and it was like 4+ bar instead of the 3 bar the engine wanted. Weird that it still threw a lean code despite having too much pressure, and the short term trims at idle were terribly positive (implying too lean). I also did a test drive with the fuel pressure hooked up and zip tied to my windshield wiper to confirm it wasn't starving, but the cheap knockoff regulator was doing it's job. Then I looked around for vacuum leaks, sure enough found one. For reasons only past-Travis understands, I had a small hose connected directly from intake manifold to airbox, bypassing the MAF. After removing that and capping the manifold port, short term trims are way better all over the place and the code has not yet recurred, but more miles will prove it. It runs noticeably better at idle and transitions between idle and throttle.
I am also investigating a $2000 Challenge wheel and tire package...
2 months until Challenge road trip to Florida and back!
Lof8 - Andy
Lof8 - Andy UltraDork
1/30/25 10:08 a.m.
That size difference vs the newer Corolla is wild!  Camry is looking great!  I'd like to see it lowered slightly, but I'd hate lose the total sleeper appearance.
APEowner
APEowner UltraDork
1/30/25 3:33 p.m.
I never thought that someday I'd deliberately click on a video to listen to a Camry exhaust, let alone really like what I heard!
wvumtnbkr
wvumtnbkr UltimaDork
1/30/25 3:41 p.m.
The jeep wheels live on!
maschinenbau
2/6/25 1:34 p.m.
Just over 100 miles and only a few issues. Main problem is it's just too fast and fun! Can't stop spinning the front tires.
I keep getting P0171 and P0174 (both banks lean) in conjunction with P0101 MAF sensor range issue. Long-term fuel trims are pretty high, especially at idle in the mid +30's which means more air is getting burned than the MAF is accounting for. This could be anything from bad MAF sensor, to fuel pressure too low, to clogged injectors, or more likely a vacuum leak. I did some leak checking with a can of brake clean and couldn't find any, but that's not a great check. It could also be the MAF scaling in the tune is not exactly correct for this intake airbox. Frankenstein Motorworks normally sells his tunes for his own MAF pipe, but I requested the original scaling for my stealth airbox. It could be his "OEM" MAF scaling is for a different OEM airbox, like a Highlander or Sienna or something. Supposedly he also uses a "newer" version of the MAF, and I have an "older" version, which is also a junkyard used piece. Whatever the issue, I am not in much danger of running lean, since the ECU corrects for this with the trims and I can watch AFR on my scan tool as I drive, and it's running pretty good. For now I just bumped up fuel pressure from 3.0 to 3.5 bar (50 PSI) and the fuel trims decreased enough to keep the codes away. Seems like LTFT of 35 will trip the lean codes.
I also found this pile of tires, so I might have to change my Challenge classification.
bbbbRASS
bbbbRASS Reader
2/6/25 1:40 p.m.
Damn that's looking proper.
nsogiba
nsogiba Reader
2/7/25 12:10 p.m.
Videos of FWD rolling burnouts or it didn't happen
3 4 5 6
LKSpOxxeGp8C315v4D0abC14g8oKBdSpgzfv5ud3TO0LdWxVZT54fLItX3IhAEX0
