Ok, let's install some intercoolers! This, while not a difficult project, is a time consuming one. I probably had something around 8-10 hours into this. This isn't a complete DIY, I'm assuming you know how to take off your rear bumper. If you don't, look it up. If that looks like something you don't want to do, installing these intercoolers is something you definitely don't want to do.
Tools needed:
3/8" drive rachet, with extensions
T25 socket or driver
10mm and 13mm sockets
Screwdriver, phillips and flat head
Dremel with cut off wheel and sanding attachments
Rivet gun and rivets
Weather stripping
Patience, lots and lots of patience!
Ok, time to kick this off. Remove the rear bumper. That leaves you staring at the intercooler assembly. Porsche designed this to come off as one big piece.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574518655_stock-ics-still-on-car_mmthumb.jpg)
There are various 13mm bolts/nuts holding this on. Two on the front, two on the back, two on the bottom attached to the heat shield and one vertically mounted one on the top front. Don't forget to pop the two retaining clips off the boost hoses and pull the boost hoses free. Now remove the entire thing and you have this sitting on the floor.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574518746_stock-ic-with-shrouds-2_mmthumb.jpg)
Car looks like this now
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574518776_ic-off-car_mmthumb.jpg)
Now you have to seperate the bracket from the shrouds/IC assembly. They're held in place with clips, 4 total, 2 on the top and bottom each. Once you've done that, pull the bracket free.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574518847_washers-and-clips-off-stock-ics_mmthumb.jpg)
Pop the retaining clips off that hold the two halves of the shrouds together, after you've marked the orientation and sides of the shrouds so you know how to put them back together. These pop off easily with a flat head screwdriver. Mark the clips for inside/outside, as they do differ. Set them aside, we'll be using these later.
Now let's compare the stock IC to the GT2RS ones. You'll notice that the stock ones are longer, but the GT2RS IC's are thicker and have more rows to them. Research has shown these to cool 65-70F better than stock and recover quickly.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519002_stock-ic-vs-gt2rs-ic_mmthumb.jpg)
Width of GT2RS IC
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519021_width-of-gt2rs-ics_mmthumb.jpg)
Width of stock IC
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519039_width-of-stock-ics_mmthumb.jpg)
Ok, time to start modifying the shrouds. You don't need to modify the GT2RS IC's themselves at all for a 996 Turbo install. Modifying the shrouds, frankly, was a huge PITA. Be really careful as the plastic is brittle and to replace them is costly. I got a lot of help here from a pwdrhnd, a local 996 turbo owner who'd done this before. He let a friend and me borrow his already modified shrouds so we could measure them and copy his design.
There are several modifications you have to make, beginning with cutting off the inner lip from each shroud. Do this with a dremel/cut off wheel, then smooth it down with files, sandpaper wheels, etc. Now you get to start to cut notches in the shrouds. Here's where you do it, with measurements.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519225_measurement-of-shroud-mod-1_mmthumb.jpg)
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519235_measurement-of-shroud-mod-2_mmthumb.jpg)
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519244_measurement-of-shroud-mod-3_mmthumb.jpg)
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519256_measurement-of-shroud-mod-4_mmthumb.jpg)
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519264_measurement-of-shroud-mod-5_mmthumb.jpg)
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519301_ics-trim-around-end-tank_mmthumb.jpg)
Here's the shrouds sitting on the IC's so you can orient the above pics to make sense
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519334_ics-showing-trim-around-end-tank_mmthumb.jpg)
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519350_ics-trim-around-other-side_mmthumb.jpg)
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519360_ics-trim-around-side-of-end-tank_mmthumb.jpg)
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519376_showing-trim-around-end-tank_mmthumb.jpg)
Now you have to add an extension plate to the shroud to make it fit the shorter GT2RS IC better. You only need to do this on the inlet side. Some thin aluminum sheeting works well here, then rivet it into place.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519571_trim-added-to-shroud_mmthumb.jpg)
Put weatherstriping all around the perimeter of this shroud, as it's the inlet side. I used this stuff.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519756_weather-stripping_mmthumb.jpg)
Ok, now you have a decision to make. How do you plan to hold the two halves of the shrouds together? The stock clips are too short to fit. You can either modify the clips, or use heavy duty zip ties. Either will work, your choice. Zip ties are easier, clips are more secure long term. I decided to modify the clips.
You need to cut the clips in half, then use 4.5cm length piece of aluminum to extend them. Drill holes in the clips/extension pieces and rivet them together using 1/8" rivets with a backing plate. These are the rivets I used
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519776_rivets-used_mmthumb.jpg)
Your clips should now look like this
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519796_ic-clips-modified_mmthumb.jpg)
Ok, time to start putting all this stuff back together. Put the IC's into the shrouds, making sure you're orientating them correctly. Pop the clips on. This is how I felt at the time
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519849_gt2rs-ic-assembled-but-mad-at-it_mmthumb.JPG)
Put the assembly back into the brackets. Note that only three of the bracket mounting points line up now. Getting those clips back in is a total PITA if you're solo. I recommend lubing the snot out of the bushings and using a wood workers racheting clamp to squeeze the assembly togther so you can drive the clip into place. Once that's done, install them into the car.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519937_gt2rs-ic-installed_mmthumb.jpg)
Hook everything up, put the rear bumper back on and you're done. You've more than earned your favorite frosty beverage!
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/11/23/1574519975_car-assembled_mmthumb.jpg)
