RacingComputers
RacingComputers Reader
11/16/23 5:57 p.m.
The planned location for the mount was in the middle of the license plate recess
RacingComputers
11/17/23 5:26 p.m.
Front Wheels and Tires:
American Racing Vintage VN125   20" X 8"
Nitto NT 555 G2    275 x 35 x 20"
Mounted Balanced and ready to install
Rears Still to be determined
RacingComputers
11/17/23 7:51 p.m.
Trail Fitting the Watson Rear Tow Bar Mount Bar
RacingComputers
11/17/23 8:09 p.m.
@tom_spangler
Pinion Angle orf/with a 1.5" lowered rear end?
Thoughts
RacingComputers
11/17/23 8:12 p.m.
@ tom_spangler
Pinion Angle for/with a 1.5" lowered rear end?
Thoughts
RacingComputers
11/17/23 8:16 p.m.
RacingComputers
11/19/23 3:39 p.m.
RacingComputers said:
@ tom_spangler
Thoughts
Currently at +1 Positive
RacingComputers
11/20/23 4:26 p.m.
Revised Rear Tow Bar Mount
RacingComputers
11/20/23 4:27 p.m.
Rear Bumper Cut Out for Tow Hook
RacingComputers
11/20/23 4:28 p.m.
Noow to take it all apart, powder coat the mount, paint the bumper , then remount
More to come
RacingComputers
11/21/23 9:50 a.m.
Project seems to be expanding due to scope creep.
Right Moser 31 spline axle has 3 loose studs
Guess the rear end is going to need to be opened up to pull the axles, replace existing studs with 3" ARPs
Probably freshen up bearing and seals while the cover is off
Oh Well
RacingComputers
11/21/23 9:29 p.m.
Rear Tow Bar welded and ready to go to the Powder Coater
tester (Forum Supporter)
tester (Forum Supporter) HalfDork
11/22/23 7:45 a.m.
With the tow hook in the license plate recess, I am guessing this car will no longer be on the street? I thought it was going to be more of a dual purpose car with the Torque thrust style wheels. Looks great so far!
Never do the math. I did a little back of the napkin math on what it would take to duplicate this build, and it was breathtaking!  Super nice though!!
RacingComputers
11/22/23 6:13 p.m.
The tow hook is going to be removed for ever day driving. License Plate is being mounted on a Flip Down Plate Mount.
Tow hook will be mounted during Off Road events
The math will scare you
As someone said, "Just do It"
RacingComputers
11/22/23 6:20 p.m.
Final mock up completed
Matt will disassemble and get the tow bar mount powder coated and the rear bumper cover painted
RacingComputers
11/22/23 6:27 p.m.
In reply to tester (Forum Supporter) :
This is Phase #1
Furious66 completed Phase #2
Matt, Mike, Ryan & Chad did Phase #3
Phase #4 is just starting
Each Phase had a budget point and was completed thusly.
Easier to Budget by Phase and not look at Total Cost of ownerhip
Fast Eddie did pahse @1
RacingComputers
11/22/23 6:33 p.m.
Rear End out Out and headed to Buzze Racing in Mooresville NC
Will be gone through and Ford Performance 4.10 Fear Set installed on the Torsten Read differential
RacingComputers
11/22/23 9:30 p.m.
In reply to RacingComputers :
Fast Ed58 Did the original build
jfryjfry
jfryjfry UltraDork
11/23/23 9:57 a.m.
and this is how you tighten loose wheel studs.
Awesome!
RacingComputers
11/23/23 4:06 p.m.
Well
The rear end was starting to make expensive noises on decelerate, the axles had to come out to have the 3" ARP studs installed.
The 4.10s are a precursor of the 6 speed to be installed in Phase #5.
Thanks for following along
RacingComputers
11/24/23 8:49 p.m.
Just a reminder of where we started
Pre Tesla Brake check
RacingComputers
11/24/23 8:50 p.m.
RacingComputers
11/24/23 9:15 p.m.
RacingComputers
11/28/23 8:06 p.m.
Rear wnd is in the process of being rebuilt
Details to follow
RacingComputers
11/29/23 7:19 p.m.
The attention moves to the front
IIqR1KhmMBUH4iggDZ5ApWBHLKUUAV0dG7vXjisMo3JVCao9rdOoq15QMXQvT99O
