6 7 8 9 10
Dusterbd13-michael
Dusterbd13-michael MegaDork
1/31/24 8:19 p.m.
1500-1800 rpm. High idle, still figuring itself out.
And still putting together. A bit of a list before driving, including the ac idler pulley that was fine when i pulled it is now stiff as hell and needs replaced. For no good reason. And i broke the fog light bolts pulling the front bumper. And the headlights need polished. And the front suspension needs torqued from replacement. And....
Mr_Asa
Mr_Asa MegaDork
1/31/24 8:26 p.m.
Stampie said:
Mr_Asa said:
So, you still tinkering, or have you hooned it around yet?
That's why I love you.
Love you too, pookie.
Dusterbd13-michael
2/2/24 8:44 p.m.
let the shakedown cruise begin.
Mr_Asa
Mr_Asa MegaDork
2/2/24 9:36 p.m.
clutchsmoke
clutchsmoke UberDork
2/2/24 11:44 p.m.
Let the good times roll.
Brett_Murphy (Agent of Chaos)
2/3/24 1:19 a.m.
That boost gauge isn't reading anywhere near where it needs to be. laugh
Is it at least building boost if you stomp on it instead of dying?
Dusterbd13-michael
2/3/24 5:42 a.m.
11psi!
And it doesn't break up anymore
Dusterbd13-michael
2/3/24 8:43 a.m.
Power steering pump is dying. Rattle from the back. Broke a sway bar end link. Pulls left. Some various rattles and bangs over bumps and turns. Need to nut and bolt check.
45 miles down, only 150 more today!
adam525i
adam525i SuperDork
2/3/24 10:09 a.m.
There's an o-ring on the fluid input line to the power steering pump that starts to fail and allow air in. This causes an audible grown and eventually damages the pump. Definitely worth checking/replacing and then bleeding the system.
Dusterbd13-michael
2/3/24 10:39 a.m.
I actually thought about the o ring. However, it wasn't noisy until i removed the hoses that are quite hard.
Im thinking the hoses are where the air is getting in. I have all the spare stuff from the parts car, so ill try that first. And swap the o ring for thorough sake.
2/3/24 4:50 p.m.
Dusterbd13-michael said:
11psi!
Ok, that's about right. Yay!
Dusterbd13-michael
2/3/24 4:57 p.m.
all normal test drives include r free duster fenders, an exterior door, and various stock car parts, right?
sevenracer
sevenracer HalfDork
2/3/24 6:31 p.m.
Damn, man. I'm sure it didn't feel like it at the time, but that's a right quick troubleshoot and recovery of an obscure harness problem.
Also, didn't know the back seats were a pass through to the bed. That's awesome.
Turbine
Turbine HalfDork
2/3/24 6:43 p.m.
I LOVE the sawblades on that thing. Great work
2/3/24 8:06 p.m.
i also did not know about the back seat pass-thru.  E36 M3, that's kooky enough for me to give subaru another chance.
and yeah, the sawblades look fantastic on there.  nice work, duster!
Patrick
Patrick MegaDork
2/3/24 8:26 p.m.
It's a baby avalanche
Stampie
Stampie MegaDork
2/3/24 8:33 p.m.
Show them the license plate trick.
Mr_Asa
Mr_Asa MegaDork
2/3/24 8:39 p.m.
Nice, man.  She hoons well?
Dusterbd13-michael
2/3/24 10:34 p.m.
Thanks everyone.
No beating yet. Want to work the kinks out beforehand.
200 miles today. Tomorrow I'll put it on dads lift for a.once over, and swap the power steering pump and resivoir. Its no longer building pressure.
Some squeaks, rattling, banging and clunking to find.
Cel for lean code
Coast to on throttle has some bog/hesitation/uglyness to find
Exhaust leaks out the wazoo
Needs alignment
I dig it!
And stampies request is honored:
Dusterbd13-michael
2/4/24 11:58 a.m.
The broken end link turned into a good thing. Tribeca sway bar, though reported to be a bolt on, bound up on BOTH lower control arms. Deformed the mounting points for the end links. I had to get a large prybar to remove it from where it was bound into the crossmember and lcas. Popped out like a rocket shot. Factory baja bar back in.
2/4/24 3:16 p.m.
does it make a difference if the Tribeca bar is flipped end-to-end?
Dusterbd13-michael
2/4/24 4:20 p.m.
Looked at that.it fouled in different places then.
Oh well.
Stock baja bars back on, rids and drives way better. 99% of squeaks, clunks and rattles fixed. Waiting on diff bushings to fix that. Power steering was fixed with the o ring, the best pair of hoses and resivoir from the pile, and a few worm style hose clamps. Not noise free, but quiet enough!
2/4/24 7:36 p.m.
I'm sure you'll have a boomin' system in there pretty soon, if you don't already. That'll fix the PS noise!
Dusterbd13-michael
2/4/24 8:35 p.m.
Trust me. I cant hear it!!!
Stereo will get pulled for challenge, but im amazed by the kicker powered 8 under the passengers seat  my wife got me for Christmas. It hits pretty serious for what it is!
Antihero
Antihero PowerDork
2/5/24 9:51 a.m.
Add me to the list of not knowing it was pass thru too.
In fact..,..that's the primary reason SaxyHero wants an avalanche
6 7 8 9 10
8QVjtO2EWdlyHBU4uVVbuDLt3lJj8ifk4Ml2wS0VnVk2OQmQefoiTIkYWzjtxFmG
