5 6 7 8 9
Sky_Render
Sky_Render SuperDork
8/27/15 1:35 p.m.
I sometimes come to GRM just to see if there are more progress pics of this build.
Ben_Modified
Ben_Modified Reader
8/27/15 2:24 p.m.
Sky_Render wrote: I sometimes come to GRM just to see if there are more progress pics of this build.
Glad to hear it. Here you go.
Todays progress. Right side rocker and battery mount.
My Other Builds
jsquared
jsquared Reader
8/27/15 2:25 p.m.
It just keeps getting better and better
TeamEvil
TeamEvil Dork
8/28/15 5:08 p.m.
If you decide to run with side scoops rather than louvers, you could still keep the VW Type II theme by using the upper rear scoops (from a 1968 and up Bus) fitted to the lower forward sides of your truck.
http://4-photos.ebizautos.com/used-1968-volkswagen-bus-t2-5973-5885801-4-640.jpg
http://s433.photobucket.com/user/aeromech32254/media/Dans1978Bus/P8180007.jpg.html
Ben_Modified
Ben_Modified Reader
8/28/15 5:46 p.m.
TeamEvil wrote: If you decide to run with side scoops rather than louvers, you could still keep the VW Type II theme by using the upper rear scoops (from a 1968 and up Bus) fitted to the lower forward sides of your truck. http://4-photos.ebizautos.com/used-1968-volkswagen-bus-t2-5973-5885801-4-640.jpg http://s433.photobucket.com/user/aeromech32254/media/Dans1978Bus/P8180007.jpg.html
Thanks. I contacted the seller from your previous post. The vents should be coming my way soon!
Ben_Modified
Ben_Modified Reader
8/30/15 6:38 a.m.
Just posted Part 8 of the Build on YouTube. A bit of a rehash of the photos here.
Part 8
Ben_Modified
Ben_Modified Reader
9/5/15 12:16 p.m.
The first of two transmission coolers is installed. An auxiliary fan cooled unit for towing is next.
Build Videos are here:
Ben_Modified
Ben_Modified Reader
9/6/15 2:19 p.m.
Installed trans cooler #2 and started on the exhaust
Build Videos
Ben_Modified
Ben_Modified Reader
9/9/15 6:42 p.m.
Progress on the exhaust system.
Build Videos
Ben_Modified
Ben_Modified Reader
9/14/15 8:57 p.m.
I'm putting together a fan shroud to mount the twin electric radiator fans. I have some left over stainless steel flashing that should work well.
Starting to look like a shroud!
Build Videos:
Ben_Modified
Ben_Modified Reader
9/15/15 6:43 p.m.
El Cheapo
El Cheapo HalfDork
9/15/15 8:35 p.m.
Great work! I love this thread!
Ben_Modified
Ben_Modified Reader
9/17/15 6:08 p.m.
TeamEvil wrote: Not to intrude again, but it might make for a neat continuation of the theme were you to include the rear engine vents from a split window VW Type II on the side bed sheetmetal. Help cool the engine just a smidge and certainly reference what the factory did with the rear most flank of the Type II. Subtle, but a nice tip of the hat . . .
Got the vents today! Thanks for the suggestion!
The Build Videos!
Ben_Modified
Ben_Modified Reader
9/26/15 9:59 p.m.
Finished relocating the seat mounting points for maximum leg room.
Also making good progress on a dash mounted shifter.
Ben_Modified
Ben_Modified Reader
9/27/15 10:43 a.m.
Shifter is roughed in. This is Park. Please imagine the leather boot in place
First
Mad_Ratel
Mad_Ratel HalfDork
9/27/15 11:30 a.m.
first looks like a spear aimed at your chest...
Ben_Modified
Ben_Modified Reader
9/27/15 12:36 p.m.
Mad_Ratel wrote: first looks like a spear aimed at your chest...
Its okay, its a dull spear
TeamEvil
TeamEvil Dork
9/27/15 1:14 p.m.
Not to tell you what to do, but . . .
Considering that the shifter is inserted into the radio hole, wouldn't it be cooler if you popped a push button shifter horizontally into the hole, one that totally mimicked the buttons on a vintage push-button radio?
http://www.ebay.com/itm/Mopar-Push-Button-Shifter-w-Shift-Cable-1960s-1963-Dodge-880-Polara-/121668399759?hash=item1c5400728f&vxp=mtr
Maybe even pop an automatic tuner radio into the hole and placed the buttons beneath it in the dash to completely mimic the look of a radio ?
Or maybe not . . .
Ben_Modified
Ben_Modified Reader
9/28/15 4:42 p.m.
With cool piston shift knob installed
Ben_Modified
Ben_Modified Reader
9/28/15 4:43 p.m.
TeamEvil wrote: Not to tell you what to do, but . . . Considering that the shifter is inserted into the radio hole, wouldn't it be cooler if you popped a push button shifter horizontally into the hole, one that totally mimicked the buttons on a vintage push-button radio? http://www.ebay.com/itm/Mopar-Push-Button-Shifter-w-Shift-Cable-1960s-1963-Dodge-880-Polara-/121668399759?hash=item1c5400728f&vxp=mtr Maybe even pop an automatic tuner radio into the hole and placed the buttons beneath it in the dash to completely mimic the look of a radio ? Or maybe not . . .
I was actually a step ahead of you..on this one. I looked into it and even looked for an electric shifter solenoid for the power glide, but could not find a way to make it all work. Thanks for the suggestion.
wearymicrobe
wearymicrobe SuperDork
9/28/15 5:31 p.m.
Jegs makes one for sure comes with the mouting plate and everything else. Just have to wire it up to what ever switch you watn.
Ben_Modified
Ben_Modified Reader
9/28/15 7:42 p.m.
I looked at a similar product and as I understand it, this will only bump up the gears going done the track. It will not handle moving the trans into and out of reverse and park. Thanks for the suggestion
Mad_Ratel
Mad_Ratel HalfDork
9/29/15 7:15 p.m.
wouldnt that make it a club now? :P way safer looking. though still spookey.
Ben_Modified
Ben_Modified Reader
9/30/15 5:52 a.m.
Finished up the shifter mounting bracket but before I install it, I made a small modification. The Powerglide has a transbrake and a full manual valve body, so I will be shifting between 1st and 2nd a lot. The shifter, as it is, allows you to simply push it forward from 2nd into neutral without depressing the button, as most shifters do. But to get it back into drive (2nd) you have to push the button. I can see myself accidentally in neutral, easily, so I modified the shift gate. I drilled and tapped a 10-32 hole in the gate and installed a screw to provide a neutral lockout. Now I just push the lever forward from 1st to 2nd with no chance of winding up in neutral
Ben_Modified
Ben_Modified Reader
10/1/15 8:44 p.m.
Finished up the neutral lock out. The shifter is ready to go back in.
Machined down the tip of the bolt
The Build Videos
5 6 7 8 9
TOzBFQkhVNlN5Flhd2GxiCVi25CTyEtxCizMyF8hudBickciC3J2CdPiZfUeECD2
