3 4 5 6 7
bgkast
bgkast UltraDork
4/7/15 3:42 p.m.
Hmmmm......
drummerfromdefleopard
drummerfromdefleopard SuperDork
4/7/15 4:09 p.m.
I see 6 eggs, the pink one is difficult to see with the sun though.
mrwillie
mrwillie Dork
4/7/15 4:45 p.m.
In reply to drummerfromdefleopard:
Is it on the ground in front of the car?
beans
beans Dork
4/7/15 10:54 p.m.
This E36 M3 is epic. I strongly support the RallySaab.
Rusted_Busted_Spit
Rusted_Busted_Spit UberDork
4/8/15 9:16 a.m.
That RallyCross 9-3 is a beast. It did a 11:13.20 at Pikes Peak in 2002.
Contradiction
Contradiction Reader
4/8/15 4:43 p.m.
That's awesome that you may actually be getting this titled and on the road!
bgkast
bgkast UltraDork
4/9/15 1:47 p.m.
Everything with the bumper support repair was going great. Everything looked pretty straight and I had the new piece fitting and lining up with the existing structure great...then I test fit the bumper...
With the bumper lined up on the "non damaged side" (in quotes because it is slightly wrinkled, but not enough to matter I don't think) this is where the replacement mount wants to sit; about 1/2" inboard from where it should.
I need to take some measurements in my neighbor's uncrashed example and see what's off.
ultraclyde
ultraclyde UltraDork
4/9/15 2:26 p.m.
just beat it with a hammer. Beat the other parts to match.
06HHR
06HHR HalfDork
4/9/15 2:40 p.m.
^^^What he said, nothing a BFH and a come-along can't fix..
RossD
RossD PowerDork
4/9/15 2:51 p.m.
When your hammer cost more than your ride... just GRM things.
ssswitch
ssswitch Reader
4/9/15 3:10 p.m.
In reply to RossD:
Hey, you're right. He should use a tree, those don't cost anything.
bgkast
bgkast UltraDork
4/12/15 6:25 p.m.
I borrowed the neighbor's car and took some measurements.
The good news is I eyeballed the new mount to within 1/8" from where it should be.
The bad news is the other side is out of place by 3/4" towards the outside of the car, which is what was causing the alignment issue.
I have 2 ideas.
1) try to pull the other mount back to where it should be or
2) drill a new hole in the bumper structure and call it good.
I'm leaning towards option 2 for now, especially since someone has already messed up the bumper by doing the same thing on the other side when they tried to "fix" it before.
patgizz
patgizz PowerDork
4/12/15 7:26 p.m.
definitely 2.
Mad_Ratel
Mad_Ratel Reader
4/12/15 8:26 p.m.
tree and come along?
bgkast
bgkast UltraDork
4/12/15 11:01 p.m.
In reply to Mad_Ratel:
Im thinking porta-power and the neighbor's bulldozer when the time comes, but for now I will just leave the one side slightly out of whack and concentrate on getting it running.
former520
former520 Reader
4/13/15 12:24 a.m.
I think in this instance, the Stance guys might just have the answer for a front bumper. Not your usual Stance car
bgkast
bgkast UltraDork
4/24/15 10:55 a.m.
The bumper support is done and it came out great!
I finally got a break in the weather (no rain and little wind) so I welded it on. My welds aren't the greatest, but all of the factory welds I have ground down have had some porosity, so mine are at least factory quality.
I used spray galv heavily in the overlapping area and over all of the welds, then hit it with some duplicolor. My idea to get bright red paint from a GM didn't pan out (it's basically a GM, right? ) Apparently red GMs are a brighter, oranger red. Once the front is back together you won't be able to see this area though.
A test fit of the bumper shows how far off the other mount is:
A few seconds with a drill will fix that! This side appears to be a bit low based on the body line between the fender and bumper, but the body line on the side I replaced is PERFECT!
I also spoke with the last owners again, they are still working on getting the release of interest notarized. As soon as I get that I can get a key for this thing and see if it runs.
bgkast
bgkast UltraDork
4/27/15 12:04 a.m.
Back together, much to the relief of my wife.
Powar
Powar SuperDork
4/27/15 10:24 a.m.
Looking good!
bgkast
bgkast UltraDork
4/30/15 2:46 p.m.
Wooooo! Pardon the smart phone redaction.
jimbob_racing
jimbob_racing Dork
4/30/15 2:47 p.m.
Wow. Nice job! Now, you just need some keys?
bgkast
bgkast UltraDork
4/30/15 3:13 p.m.
In reply to jimbob_racing:
Theoretically just a key and security module. This document should let me order the key.
mrwillie
mrwillie Dork
4/30/15 3:21 p.m.
That paper has more black ink than a declassified Area 51 file.
Does this allow you to apply for a title now? I know a guy who knows a guy who sells saab parts if you need something.
bgkast
bgkast UltraDork
5/1/15 8:02 p.m.
Yes, I can get a salvage title after a VIN inspection. I set up the inspection for later this month. I just dropped $59 on a key cut to the VIN, and found a security module locally for $125.
Total spent:$257. Dang, this thing is getting expensive.
bgkast
bgkast UltraDork
5/2/15 11:01 p.m.
I picked up the new TWICE security module with matching key and reader today. Unfortunately I didn't win the lottery and the key doesn't fit the locks. Oh well, one cut to the VIN is on the way. I should have ordered it a month ago, they haven't asked me for any proof of ownership... When it arrives I will snap the transponder from the key that I got today in and should be good to go.
3 4 5 6 7
CKmiYri5VBm10pb092mzPXOJWpz3w5HpiS3mMgPPBBXGff7j3yKpYnZUokfVO0iJ
