7 8 9
2/17/23 8:10 p.m.
In reply to RichardSIA :
Nice!
RichardSIA
RichardSIA Dork
2/17/23 9:00 p.m.
The "Fun" part is going to be painting the inside of the frame head.
RichardSIA
RichardSIA Dork
2/19/23 6:50 p.m.
Siphon gun with a right angle head did a pretty good job for painting inside the frame head.
It is not made for that but worked pretty well.
Now that I have to leave the chassis alone for a few days I am back to smaller projects.
Today I port-matched my intake manifolds.
They had a step at the top of the port where the intake manifold was smaller than the head port.
This was crescent moon type of mis-match, the bottom was fine.
I marked the manifold face with a sharpie, then used a sharp U shaped scribe to reach into the port and scribe my line for an exact match.
I used the boring bar on my vertical mill to bore each branch of the manifolds.
Ports are nearly a perfect match now but I still have to do some blending.
Always good to have milling machine.
RichardSIA
RichardSIA Dork
3/6/23 1:47 a.m.
Body rotisserie is almost ready for use.
It will be ugly but functional.
This will allow me to do body work without killing my back.
I hope it will also let me do the paint off the chassis, but maybe not as there is some flex to keep in mind.
RichardSIA
RichardSIA Dork
3/11/23 9:57 p.m.
After realizing just how much "Fun" assembling the rear hubs will be I decided to turn a scrap stub-axle into a tool.
I turned down the inner bearing shoulder on my lathe so that the bearing just drops on.
I no longer need a press to get it apart.
Now I may use it to easily mock up my Scirocco caliper disc-brake conversion.
They are light aluminum and let me keep a parking brake.
RichardSIA
RichardSIA Dork
4/16/23 11:44 p.m.
Repair of gel-coat star cracks and edge delamination has begun on the front and rear covers.
Using epoxy with medium speed hardener which is working well for me so far.
7 8 9
1zViXQiwNrKF9m1MWXIdrhg7TPvWzkjfjS8NIPiasbR323FuIFPpvD0RMGsqF39R
