dan0
dan0 Dork
9/11/24 4:51 p.m.
Forgot or accidentally deleted the shot of it back to right side up with the frame cut, also kinda positioned the third brake light panel up there.
Trying to use as much factory pieces as I can to try to make it look nice.
A little more of this for now, but also going to start of the work of the bed frame and try to figure out how to hinge the tailgate.
Indy - Guy
Indy - Guy UltimaDork
9/11/24 5:31 p.m.
In reply to dan0 :
Yeah, the reverse angle wasn't considered when I suggested that.....
Carry on Sir, you're doing fine work. 👍
Piguin
Piguin Reader
9/11/24 6:43 p.m.
Agreed on the exposed wheel wells. Or maybe 'covers' like trailer fenders so they'll look more normal while still not taking up too much space.
Have you considered starting with lexan for the rear window and eventually getting a flat glass cut?
dan0
dan0 Dork
9/11/24 7:00 p.m.
When the bed is finished off, the plan was to do a rhino lining on it, so that would help the wheel well blend into the bed, or possibly a partial cover up depending on how it comes out.
Hadn't thought of lexan and then glass cut. Depends on how glass looks/costs. I just remember reading back many years of 1552 Design's MK4 Jetta Coupe they built and they spent a lot of time / money to get an OEM quality window. I had also thought the dimensions of a MK4 Golf might be a good fit as well.
dan0
dan0 Dork
9/14/24 3:56 p.m.
I think this is going to be the way for the rear window. VW Amarok Pickup rear glass. I'm kinda a stickler for OEM which is why I tried to make the hatch glass work. I messed around with it more today. It would sit lower than I wanted if positioned vertical, and if slightly angled messes with the length of the bed/cab and proportions.
They were sold in Mexico so shouldn't be outrageous to find one and get it into the US.
dan0
dan0 Dork
9/14/24 5:05 p.m.
Doing truck stuff.
dan0
dan0 Dork
9/15/24 1:48 p.m.
Got tired of the ugly overhang and cut a little more off the roof to make it closer to the final form.
Rest of the week will probably just be some cardboard aided design. Gotta get some work in on parting out my other Touareg.
dan0
dan0 Dork
9/15/24 6:36 p.m.
Not a urgent thing but the airbags leak, there's a jack mode that I've never put this in and it's been on blocks before for months with wheels off. So it squats down after a day or so hence the low in some pictures. It does look good aired up.
dan0
dan0 Dork
9/16/24 3:53 p.m.
Someone on Facebook questioned the rigidity.
"but can you open the door when its flexed like that"
Yes.
Light isn't exactly cooperating but all four doors opened
dan0
dan0 Dork
9/28/24 5:23 p.m.
Never had one lesson. It's not great and just tacked in for looks. I didn't exactly intend it to be the final piece. But it's almost good enough to leave and just fix it with the grinder and hammers...
Tomorrow I'll try the other side and work for a better piece.
Piguin
Piguin Reader
9/28/24 5:58 p.m.
Love seeing the progress on this.
Question: wouldn't it be easier to cut a rectangle (with rounded edges) around the handle spot and fill that in instead of trying to follow that bow tie shape?
dan0
dan0 Dork
9/28/24 6:41 p.m.
Maybe, this is the first time I'm doing anything like this so I'm just winging it. With the shaped piece it does kinda have a little recess it can go into. That might make it tougher to smooth later. With cutting a rectangle it might be a little harder to hold it in place as I begin to weld, even with a magnet holding it. Like I might accidentally push it through. It is fairly straight but the door does curve just a touch. I cut the piece out of the back pillar I cut out, so it also has a little curve.
OjaiM5
OjaiM5 HalfDork
9/28/24 8:28 p.m.
I think what you have done so far looks Bitchn'
I have been following the Rad Factory build on the Tube. I commented that he shouldn't cover up the access to the fuel pump / filter. I have a lot of respect for you guys fabricating trucks. It is much more work that I suspected.  I have a POS lifted Cayenne on 32s, super fun beater rig.
dan0
dan0 Dork
9/29/24 8:18 a.m.
In reply to OjaiM5 :
I'm following them too. I was in the Facebook groups where they posted some updates. He even mentioned in the latest video how all the YouTube comments were positive and the Facebook people were mostly ripping on them.
The video where they had the body shift because they tied into the subframe I commented about my truck and showing off the strength. Gavin replied something like "Awesome you got a Touareg truck" and I replied yeah but just in progress and commented I should put up a recent short showing how it's coming. Check comments an hour later and my little self promotion comment was deleted. That kinda irked me and I deleted all my Facebook comments promoting them and deleted that YouTube comment.
The most recent video with them finishing the cab it really came out great looking. It was questionable with the amount of filler used and how warped the rear wall was. I hope to do a little bit more metal shaping so I use less filler.
The platform does really well. I was a VW service writer when they came out in 2004. Thought they were cool but kinda disliked them for all the trouble the early ones had at first. Lots of service bulletins and updates. I'm glad I bought one. Very capable stock.
Enjoy that Cayenne you got !
dan0
dan0 Dork
9/29/24 2:18 p.m.
Side quest. What every vehicle needs. "A bangin stereo for me tunes"
dan0
dan0 Dork
10/1/24 6:58 p.m.
So I wanted to clean out where I had the stock seats sitting (my bus) plus driving it around sitting on a little work platform isn't easy.
So in goes the drivers seat. Plug in connections, no movement. Rough with it some yesterday and today. Still no luck, but in messing around some trying to jump power connections I unknowingly did raise the seat some and the seat back some, so it's slightly better than before.
Check fuses, scan it, etc. no luck.
Grab the passenger seat, plug it in. Boom it works immediately. Still nothing drivers side. At least it's fully bolted in just in case I get the urge for a longer test drive.
dan0
dan0 Dork
10/3/24 10:16 a.m.
A little treat to help motivate me...
I've really like this Audi color for a while and it's available on a model I'd love to buy. Even seen o e around my town a couple times now.
Also I bought these wheels YEARS ago and once I realized I wasn't going to paint my other silver Touareg a different color, I've tried selling them with no luck. Close one time buyer that's another story. Wait no TWO close sales both interesting stories.
Audi District Green Metallic and Alpha Equipt Bravo wheels in "Quicksand"
dan0
dan0 Dork
10/3/24 10:24 a.m.
My brains been thinking overtime on how to finish the cab area and kinda thought off something new. Well not new in automotive terms but a new idea for me. Chevy Avalanche-esque panel rear wall.
Reinforce and build the roof area with two drop downs to the floor fixed. Then a half panel wall that can be removed, and a window wall.
What got me thinking was the fight with the drivers seat. It hinges back because the battery is underneath. And with the quick piece I put in the it made it impossible to tilt all the way. And getting the back bolts in would be tough
dan0
dan0 Dork
10/3/24 7:37 p.m.
A little work in this afternoon. I had been researching different cutting tools in an attempt to get a better cut. Ended up the same as the other side with a angle grinder.
Equal parts better and worse.
Picture upload has been finicky last couple of days but, I have pictures on Instagram.
https://www.instagram.com/p/DArS9VgPJPO/?igsh=cHN2Z2JpcTdpbWh2
dan0
dan0 Dork
10/3/24 7:42 p.m.
As for the tools I might end up buying a Milwaukee Hackzall.
Google / Amazon searching for auto body panel cutting come back with 99% of Low vibration pneumatic reciprocating saws. Problem is I don't have a huge compressor and would prefer a cordless or corded tool over air.
The Milwaukee is a small reciprocating saw so it might fit the bill. Other choice would be like a scroll saw, but they have a little weight to them. A good fine tooth blade might work well.
jfryjfry
jfryjfry UltraDork
10/4/24 9:06 a.m.
I might be interested in the wheels...  details??? Pics?
dan0
dan0 Dork
10/5/24 3:16 p.m.
In reply to jfryjfry :
Nah. What I was intending to say was these wheels are now going on this truck and off the market.
dan0
dan0 Dork
10/5/24 7:04 p.m.
A little progress today.
Found a broken power wire. Seat kinda works, forward and backwards something is jammed or if two motors one isn't working
Cut the giant muffler off and a trim piece, where the lower also cut bumper would have mounted.
Got my paint in late and tried a quick patch. Can't wait to see it in the full sunlight tomorrow.
dan0
dan0 Dork
10/7/24 9:46 a.m.
Ordered catalytic converters for it. Well primary cats at least.
Pictures with a little color on it.
https://www.instagram.com/p/DAzQizQAt__/?igsh=MXdvNzU0a253NDQydA==
So it shows two cats in the parts diagram. The primary are off the exhaust manifold and where the O2 sensors are so, after that who cares...
dan0
dan0 Dork
10/7/24 10:52 a.m.
So image upload direct from iPhone camera roll hasn't been working but if I edit the photo or a screenshot it works. So here's one edited so I can post directly to the thread.
PpL63VhtFKiGO1Z0xo6NqlR7ET6ly8vmW3pPjHZGW2Nc5rTQFGTvqm05H1G54U5I
