First tim eposting on t his forum so lets hope I get it right.
Remember this build chronicled by Pete?
Life has got in the way but the follow up to Pete excellent work continues. To recall there was an engine swap in the works? Well I work mega slowly, there is lots to do and I drive a lot. I am an Engineering Project Manager so planning is my specialty.
Recall that Pete left me with unpainted sills. No worries this was all part of the scope of work. I drove around for a season with these primer sills but SWMBO 'suggested' I do some improvement.
Winter up here is long so an excellent time to remedy this. Easiest way to paint these sills was to remove the doors etc. Pete can attest to the love he has for the door hinge design on this car but I think I may have taken Murphy by surprise?
The doors are held by quantity 4 5/16" screws into captive nuts in the A & B post. Working on ones own these doors can be 'heavy'.
No special tools other than an exhaust manifold stud, (short one with 5/16" UNF threads both ends) a spacer and a nut. The screws for the doors are regular 5/16" UNF so compatible.
A length of stout line is used as a third hand.
The front door is a bit trickier than the rear door. In both cases the door check needs removing of course. (remember these Pete?) This will allow the front door to swing open to 90 degrees and provide easy access to the quantity 4, 5/16" hex head screws holding the hinge to the door. Unscrew the top fastener with a ring spanner. Thread the stud into this hole, short thread end . Slide on the tube spacer and spin on the nut, and tighten slightly. This single fastener will secure the door adequately. Now remove the 3 remaining hex screws holding the hinge to the door.
Wind down the door glass and wrap the length of line around the door as shown, to form a loop. Put your arm through the rope loop to keep the weight of the door and undo the single nut. The stud will simply slide out of the hinge. The rear door removal is the same. Access is easier, the door can remain closed
and a socket and ratchet can be used.
This method removes the headache of supporting the door weight, whilst fiddling with fasteners and spanners.. As the workshop manual writes, "reassembly is the reversal of the above method"
Salut
B
