therealpinto said:
Hi there fellow Capri driver :-)
I am the first (no, not really the first you get my point) to agree that the stock(ish) Capri front suspension has severe shortfalls. Bad camber compensation, not enough caster, large scrub radius when you add reasonably wide wheels and some bump steer on top of that.
But fitting something else that is magically better? The "best" solution I have seen and driven, is probably Sierra struts with adjustable track control arms. For you (in the US I take), that would mean XR4Ti struts. In Europe, new adjustable Sierra TCA's are easy to get - not so sure about the US. Correctly fitted, this solution will aid all the problems mentioned above and is almost bolt-in. Depending on desired poke/stance/wheel width and fender treatment, eccentric or adjustable strut tops are recommended to get the wheel where you want it. You will also need to use a modified ARB for caster adjustment or go straight to tension struts or compression struts....
SLA is nice but going to a Mustang II setup they way they usually are would, IMO, be step down at least in handling. For an SLA to work in a Capri you'd need serious inner wing modifications. I would be tempted to look at one of the "modern" designs with a high upright and the upper arm above the wheel. Nissan 350Z comes to mind as a possible donor.
Gustaf
Heya Gustaf- I re-read your thread before I posted...
The car has been out of service 20 years, parked in the barn in MI. I retired and am moving back to Cascadia (Washington state, about 30km (18 miles for us 'Murkins) east of the local highway summit.) Putting together a 4l v6, T5Z transmission, and an lsd on the Atlas axle.
Right now I'm focusing on front suspension, since the way it's currently set up sucked soo much. If I don't make it the first time around, there's time for a second. At this point, I'm not fixated on any single solution, If I can get where I want with few changes, that's better than making changes just to make changes.
I think at this point I'm really fishing for suggestions to improve the Mac Strut. You suggest Sierra, am I correct in understanding that the Sierra uses clamp or bolt on spindle? Never paid much attention to them when they were sold in the US. Never seen a US built adjustable TCA- most of the Brit vendors don't ship these parts to the US, I think because of the liability situation. This doesn't scare me- easy enough to fabricate
Front ARB's modified for caster adjustment are available here-a bit spendy, but available. I've dallied with the thought of a tension or compression strut to isolate location from anti-roll function. Planning on using a high positive offset wheel- a primary goal here is to do no more than roll fenders. I plan on a set of caster/camber plates to help build more caster in- may eliminate the need for an adjustable TCA?
Want to start working on the car when it moves out here from Michigan in November, trying to collect parts as much as possible so I'm not sitting on my hands.
