Haven't posted in a while as life got busy but progress has still been made.
In a continuous effort to save weight where/when possible I moved ahead with chopping the frame horns off and doing a full tubular front end.
Due to the terrifying fact that with the fenders not installed pulling up and pushing down on the frame horn would show at least and 1/8" of flex all the way back at the windshield area and significantly more at the bumper trying to save weight in the fender and core support was out of the question. Class rules don't allow cage tubes forward of the firewall so I got creative with a fender support tube. It bolts on with the fender at the base of the windshield and door hinge area which is nice and strong. Then runs inside the fender until it turns and lands on the tube frame rail.
I then cut away the inner fender steel and made tabs to hold the fender skin.
Next was the core support. I want to tilt the radiator in anticipation of fully ducting it so the plan was a cross tube that would hold up the header panel and double as upper radiator mount. This header panel is crap, with several stripped out holes and others only held by body filler I wasted no time cutting away what I could and making new mounts near the headlights with riv-nuts.
Haven't gotten to the radiator yet as the plan is to use the sway bar cross tube for the lower mount and not need another cross tube just for the radiator.
Instead of reusing the factory style sway bar that I have not been happy with due to several stripped holes, reduced turning radius and no adjustment I'm going to a splined setup. Its easier to mount, less work, tuneable (way higher or lower rates available), and I can move it lower in the chassis and get some tire clearance back. Waiting for a few more parts to get going on that.
Also should mention that I used interlocking tube clamps for the fender bars at the front so they can be removed. It was an afterthought when I realized that welding them solid would make it nearly impossible to remove the doors or fenders if the need ever came up.
As part of my major front end upgrades I'm swapping to a 3 pc spindle. They're ment for circle track and are direct replacement for the stock spindle. The kicker is that they are stronger, and have the option of a pinto "short arm" steering arm. Not only does this quicken the steering (with my 2.5" rack it will net a 21% increase at 1/4 turn) it also moves the tie rod further outboard to help with Ackerman and improve bump steer geometry. Here's a comparison.
The 3pc spindle is different how the brake caliper brackets bolt on which will require fabrication of new ones. I'm attempting to be more exact about it this time which is required since it's a much more complicated bracket needed. I may end up needing to mill them as a billet part.
I decided that I would lower the car again as the turn in response just wasn't crisp with the higher ride height. Not that it was slower per lap, just not the feel I like. Using a 6x6 block to set crossmember height at 5-1/2" is about where I was before. I then went about moving the body and suspension parts through roll to see what was actually going on. At this height I could put my weight on the fender and get 2.0 degrees of body roll at about 1-1/4" of movement at the fender. This same process yeilded 2.6 degrees of negative camber gain. I tired again with a stock length upper ball joint and only got 1.5 degrees gain. I'm going with the 1/2" longer ones which should let me run less static camber. The weight jacking effect will reduce that figure some due to increase in ride height while cornering.
With the sway bar and going to coil over changes another set of control arms are in order. Was going to get on them Sunday but had to stop or go blind when the battery died in my welding helmet. Can't find one in town as they're backordered but have one coming I found on line.
