So when we left off last time, I had polished headlights, aggressive leaks, broken rear sway bar, parts strewn around, and about 174k on the clock.
Well, heres where ive been at.
First up is the leak: not all the head gaskets fault. Somehow the oil filter loosened up. Either the gasket shrank, I didn't put it on tight enough at the last oil change, or the magnetic field of the earth rotated perfectly around the canister. I don't know. But one full turn, and oil consumption back to normal. Which buys me some time, hopefully until I get the duster back on the road so I have something else to drive while I yank the engine out of this. Or summer, when I can steal my mazda back from the wife while her and the munchkin are out of school
But, this is a build thread, so lets get on to some building.
As with all builds, some wins, some losses, and some smacking yourself in the head while saying “aw, E36 M3!”
First head smacking win came with the headlight conversion. Its done. 55 watt 5000k bulbs and ballasts, relay harness, all sank into a factory housing. Looks pretty good. Unfortunately, due to the head smack, they don't work right. You see, when I mocked them up, I didn't reseal the housings. Which left an extra ~1/2 inch or so between the projector lens and factory clear lens.
This 1/2 inch doesn't actually exist. If anything, you're a few thousandths shy of things working properly. When resealed, and I went to do adjustment against the back wall of lowes, I found that the projector bulbs slightly touch the lens in one spot, making the factory adjusters useless. I may have stripped them before figuring it out. Im not sure. The headlights were aimed way too low, which should have sent a red flag for me. But, in the interest of needing the car to go to work the next morning, I shimmed the whole housing up with some 1/4 washers under the lower inner bolt and longer bolts. The aim still sucks, the pattern is suffering, and they are worse than the halogens. Hopefully the 60 hour workweeks will be done soon, and ill be able to redo the install. But, in the interest of providing educational proof of don't be a dumb-ass, measure, heres what they look like.
You'll also note that I discarded the orange reflectors that were glued to the lenses. This was an accident on the first one, and intentional on the second. I like the looks, and will find some clear/orange bulbs to put in there at some point.
[URL=http://s54.photobucket.com/user/dusterbd13/media/subaru/20160304_200111_zps5bzgn8u2.jpg.html]
[/URL]
[URL=http://s54.photobucket.com/user/dusterbd13/media/subaru/20160304_200113_zpsoginohxi.jpg.html]
[/URL]
[URL=http://s54.photobucket.com/user/dusterbd13/media/subaru/20160304_200117_zpsr3sv4fgg.jpg.html]
[/URL]
[URL=http://s54.photobucket.com/user/dusterbd13/media/subaru/20160304_200136_zpsv6gvvw6c.jpg.html]
[/URL]
[URL=http://s54.photobucket.com/user/dusterbd13/media/subaru/20160304_200139_zpsyxm77f4m.jpg.html]
[/URL]
Next is the cold air intake curtsy of lowes racing products. Its some fernco fittings, a pair of 45 street elbows, and about a foot of 2 inch pipe. The original flex coupler was shot, as well as the rubber isolation mounts on the stock setup. I figured id try this. Nice noises, maybe a little more power at lower rpms, possible a little more throttle response, and no MPG change. Still averaging a low of 23 with AC on, and 25 mostly highway with ac off.
[URL=http://s54.photobucket.com/user/dusterbd13/media/subaru/20160304_200635_zpsz4piapoz.jpg.html]
[/URL]
Next is rear sway bar. Its a 17mm off a baja turbo. I was told it would be a direct swap. Its not. You have to pull one of the cross-member reinforcement bracket bolts out, and kind of force it into place. It rubs and squeaks. But the turn in was a LOT better, and the car is more predictable overall than with the stocker. Much more better. Granted, a not broken sway bar would have also been much more better.
[URL=http://s54.photobucket.com/user/dusterbd13/media/subaru/20160221_143705_zpsjn3d3kwx.jpg.html]
[/URL]
Lastly of the things I have pictures of: I tinted the car. I noticed the frequency of my migraines increasing, and was trying to think of what changed. Only thing I could think of was that this car wasn't tinted. All my others have been since it was recommended to me to try. So I did it, and I went back to my standard frequency. I went 35% on the front windows and rear glass, 20% on all the rest of the side glass. None on windshield, and 5% on the sunroofs. I will say that I accidently bought the static cling tint for the 20%. Not impressed, but it was non-returnable by the time I realized my mistake. So I used it. Well see how it holds up, but it is not nearly as clear as the normal tint. From the inside it looks like the windows are fogged. Cant see it from the outside. But don't buy this stuff.
[URL=http://s54.photobucket.com/user/dusterbd13/media/subaru/20160306_173737_zpssxlvbu6h.jpg.html]
[/URL]
That brings us up to today. No pictures from today.
I found when getting tires rotated that my passengers side tie rods had a bunch of play. This coincided with vibrations in the wheel at highway speeds, and VIOLENT vibrations under light braking. No vibrations under heavy. So I swapped in some import direct inner and outer tie rod ends on that side, as well as a masterpro rack boot and went for a drive. The vibrations are drastically reduced to the point of almost not being there. Still some though, and I checked everything else on the front end out. I found excessive movement in the rearmost bushing in the front lower control arms, as well as seriously degraded rack bushings. Suggestions on this front are encouraged. What should I buy, and from who, and why? Anything I may be missing?
Up next is installing the alpine components I found in pull a part last week ($12!) and rebuilding the drivers seat before I can no longer walk.
Oh, 178k as of the way to church this morning.
Michael
