I went ahead and put the filter on
![](https://i.imgur.com/fpUGiiW.jpg)
After datalogging I saw a slight improvement in fuel trims. Was still showing lean but a few points better than before. When the pump showed up I put it in also. It was raining and super cold so I didnt want to do it but it really only took a few minutes.
![](https://i.imgur.com/nKK5TVo.jpeg)
This also improved fuel trims a little. I was still slightly lean at idle, and still lean under throttle but with a small improvement.
Next I wanted to give the car a quick detail and get some wax on it to protect the paint, and maybe hid a few scratches. I washed, claybared and waxed it. Car actually cleaned up really well I think
![](https://i.imgur.com/R3LX62J.jpeg)
![](https://i.imgur.com/gHtfray.jpeg)
![](https://i.imgur.com/REBmcYJ.jpeg)
![](https://i.imgur.com/mw2tEjG.jpeg)
I went back and did some more checking. I smoked the intake and found a small leak were a rubber hose meets a plastic pipe. In the picture you cant see the smoke but you can see a green tinge which is the dye in the smoke. I found the clamp loose and after tightening it, it did not leak anymore.
![](https://i.imgur.com/vL0GeJP.jpeg)
I had also noticed the oil filter housing gasket was still leaking oil, so I thought it was probably causing a vacuum leak also. While watching fuel trims I sprayed some brake clean behind the housing and the trims immediately responded. So I ordered a Fel pro OFHG and took it back apart. I didnt see anything wrong with the gasket when I took it off.
![](https://i.imgur.com/kdLTtcv.jpeg)
I have also been getting an evap code and when I smoked the system I did find a leak at the leak detection pump so I ordered a Bosch one and installed it.
![](https://i.imgur.com/UlvxOql.jpeg)
After datalogging, it looks like my idle fuel trims are finally good. They were right at 0, but under any throttle they go lean. At idle te MAF seems to be reporting right at the lower range of nominal. I believe it is under reporting airflow causing the lean condition, it is a pretty common problem on E46s, there really isnt a great way to diagnos it so its really just an educated guess. I think the car was negelcted and had multiple soft failures, cause I have seen improvement on the data with all of my repairs, but hopefully the MAF was the big one. Ive ordered an OEM once since apparently all the aftermarket ones dont report right and cause all kinds of issues.
I also received my sunroof motor cover after waiting forever.
![](https://i.imgur.com/ArLRcyr.jpeg)
Yes the headliner looks like hell. I got a price from my upholstery guy the other day and its 400 to do all the pillars, the sunroof shade and cover, and the headliner. Will probably be the last thing I do with the window tint once I have it all sorted. Next I tried the sunroof. Expecting the worse since someone removed the buttons, and to my surprise it went all the way back nice and smooth with no weird noises. When I tried to close it, it stopped a few inches short and reversed. You can inch it forward the last few inches and it will close, but since I had no crunching I figured it was the shade guides binding it up.
I went ahead and pulled the glass to inspect the tracks and that is exactly what I found. This is the shade bracket.
![](https://i.imgur.com/EtR1jCx.jpeg)
They are all broken and I cant only find one of the slides. Its going to take some more research but I think that means I would have to replace the whole cassette if I wanted a working shade. I just took it out for now. I think if I remove the one remaining slide it should work fine, I just wont have a shade. I dont know what Im going to do yet.
My Leatherique came in so I figured Id give it a go. First you use a rejuvenator which will soften the leather and bring all the contaminants to the surface which you can then clean off with the cleaner. I rubbed the oil in yesterday and plan to clean it off late today. After about 12 hours there does seem to be a softening of the leather, but its pretty cold out and they recommend doing it in the heat so im no sure how well it will work,
![](https://i.imgur.com/TCuayDO.jpeg)
