1 2 3 4 5
RACEC4R
RACEC4R New Reader
12/5/19 9:13 a.m.
Robbie, I would 100% get that known good 1200 motor/trans setup.  Get the car running/driving THEN bite off more than you can chew and swap it.
No way you can get another drivetrain @ that pricepoint, plus known member.
Be an absolute bitch to swap the car, then try to fix gremlins.  Start with known good car, then mod it.  Pretty good recipe for success with respect to efficiency of time investment (which you are clearly tracking).
Also AWD is a no-go as front/rear ratios need to be identical.  So for G35 swap (badass idea that I fully support, btw) you'd need both the front and rear differentials from the G35.  Can't use your stock stick from the Roadstar.  You cannot have a delta speed difference between front/rear.
Robbie
Robbie MegaDork
12/5/19 10:05 a.m.
In reply to RACEC4R :
Doh! Duh. Of course I know about front and rear ratios matching but wasn't thinking about it for some reason.
dculberson
dculberson MegaDork
12/5/19 10:06 a.m.
I would hate to bother spending the time installing a drivetrain if you were planning on swapping it. Unless you would run it with the 1200 for 2020 then swap it for 2021, otherwise it feels like a waste of time.
Robbie
Robbie MegaDork
12/5/19 10:38 a.m.
In reply to dculberson :
I hear what you're saying but I think with a little sleuthing work I can learn if the 1200 would be a bolt in affair or not. At this point I'm assuming it would be, but need to confirm.
A bolt in job is a few hours worth of work and a swap is hundreds. A car that runs is faster than a car that doesn't.
There is absolutely a temptation to get to a running/driving car as cheap/fast as possible and then modify from there.
RACEC4R
RACEC4R New Reader
12/5/19 11:21 a.m.
In reply to Robbie :
Exactly my point.  I would want a running car, test out the brakes, steering, suspension and package as a whole.  Then modify if I liked the soul of the beast enough.
A running car is worth 100x more than a bench-racing-swap this forum is so exceptional at committing (myself included in that jab!).
Also, please see Rule #1 :-)
I'm not sure there is anything more dissapointing than spending hundreds of hours, maybe thousands of dollars swapping a car, and realizing you don't really like it as a whole?  lol
Remember Robbie.  E36 M3ty Miata.  E36 M3ty.  Miata.  LMFAO
Patrick
Patrick MegaDork
12/5/19 11:29 a.m.
Be quiet Ian.  Robbie does not need a voice of reason
rb25det
RACEC4R
RACEC4R New Reader
12/5/19 11:48 a.m.
rb25det
LMFAO, dude, I'm sayin!  I'm a Nissan head, so you're preaching to the right choir.
But if this chassis is awesome and a keeper, I'm inclined to suggest an SR20DET... entire swaps are getting cheap cause everyone is doing this now in their S-Chassis (that's mine)...
But seriously, this little guy would fit perfectly!
All aluminum, 2.0 square bore, fit back behind them shock towers as much as possible, tons of aftermarket, makes 200whp stock...I think mine made 225whp at that dyno day we went to at Kelly Moss, remember that Robbie?  I forget what it made, but it was as much as the 5.0 w/cam in your E36.  Such a slugger of a motor.
RACEC4R
RACEC4R New Reader
12/5/19 11:53 a.m.
Patrick
Patrick MegaDork
12/5/19 11:55 a.m.
I can get behind that, I've examined one of these cars closely and there isn't room for anything remotely big.
Robbie
Robbie MegaDork
12/5/19 12:01 p.m.
There are commercial mounts you can buy for sr20.
Front sump pan is probably going to be an issue with the roadster crossmember.
But again, engines are relatively easy in this car (since it's body on frame), it's replacing the incredibly narrow rear axle that is the issue on a challenge budget.
Stampie
Stampie UltimaDork
12/5/19 12:06 p.m.
How narrow is it?  Could you get two Explorer 8.8s and combine the short sides for a cheap narrowed rear?
ggarrard
ggarrard Reader
12/5/19 12:08 p.m.
I support the SR20 option (even without a turbo)....or the KA24.
 Another (less common) would be the Z22 from the earlier 200SX.
Good luck...
Patrick
Patrick MegaDork
12/5/19 12:10 p.m.
I have $95 into my narrowed 9" housing.  It's just that the jig to narrow it cost me $400
Robbie
Robbie MegaDork
12/5/19 12:21 p.m.
Rear track is 47.5 inches, I think. I can take a measurement but I can't imagine the space between the body at the top of the rear wheels is much more than 52 or so inches.
According to carnut.com/specs/rear.html,
The explorer with two short sides is still 56.75, or almost 10 full inches too wide. Saves about 3 inches over a regular explorer axle.
Robbie
Robbie MegaDork
12/5/19 12:23 p.m.
What about the axles though? Dont you still need to have custom axles made after shortening the housing?
slowbird
slowbird Dork
12/5/19 12:47 p.m.
Maybe you can find a really short 9" axle from someone's old tubbed drag race car? Might actually be too narrow then, though.
TurnerX19
TurnerX19 Dork
12/5/19 12:54 p.m.
Sturdy enough live rear axle that should be cheap: Late MGB, or Triumph TR3. Or a later Datsun roadster, but they are unlikely to be cheap, not enough parts cars around. How narrow is an early Jeep?
Robbie
Robbie MegaDork
12/5/19 12:58 p.m.
In reply to TurnerX19 :
I do have a line on the later roadster rear axle, that is my current plan (also easiest to bolt in and out). But I still don't think it'll stand up to something like an LS.
classicJackets
classicJackets Dork
12/5/19 12:59 p.m.
I love these, passed on a local one listed at $700 a few months back that had been sitting for ~20 years. I'll live vicariously through you until I can go about getting one..
gumby
gumby Reader
12/5/19 2:30 p.m.
I'll just put this here:
https://www.roundforge.com/articles/toyota-axle-widths/
Toyota 8" axle is strong, and plentiful. Way lighter than a 9" or Explorer 8.8. Lots of interchange availability and good aftermarket.
Early pickups are fairly narrow at 55" wms. The chart shows some FJ options at 55.6" wms and offset, which means two short sides makes an even narrower option with stock parts.
Patrick
Patrick MegaDork
12/5/19 2:57 p.m.
The key is finding short axles and making the housing to fit them, or finding a deal on cut to length axles.
wheelsmithy
wheelsmithy SuperDork
12/5/19 5:08 p.m.
Ummm,
MAZDASPEED!
alfadriver
alfadriver MegaDork
12/5/19 5:24 p.m.
Another axle possibility is from an Alfa Spider- they are pretty darned strong (I've seen 300hp out of them), light, and have LSD.  Bonus that they survive when the body is returning to it's more natural state.
mblommel
mblommel Dork
12/5/19 9:04 p.m.
I'm going to really enjoy watching this project.
Also:
Robbie
Robbie MegaDork
12/5/19 10:02 p.m.
In reply to mblommel :
I think racec4r texted me photos of that car a few days after we got me into this mess. Beautiful build.
1 2 3 4 5
KdAmQHR7P24mMT1CiVFMX82fTyp8MqjCKaZA6bUc2ljqNvBJFO3RI8ueQriBtzZd
