bbbbRASS
bbbbRASS Reader
2/12/25 9:39 a.m.
Well, the little truck could be better with a trailer behind it to haul limbs and furniture and stuff. As it happens I browsed without purpose on Govdeals and found this 3 miles away.
2018 Carry-On trailer, 4x6 mesh deck, single 2K axle. That is perfect for the little areas I have to get around, and the 5x12 just doesn't fit well. Plus that means I don't need to bring my trailer from home when I need one at work. The description says "Agency reports that trailer is rusted and the ball bearings are bad. Agency states trailer appears to be road worthy."I call and ask what I would need to haul it, they say 2 inch ball and should be fine to make it 3 miles on surface roads. Here is what I discovered.
Ummm, I'm not driving that out of the parking lot. It's the morning of a workday, I have a meeting in 90 minutes, and my big trailer is over an hour away (round trip). I've never replaced a trailer hub, but it doesn't look too bad on Youtube...
Luckily there is an awesome trailer & hitch shop literally next to my work. I run back, grab my tools, jack, and jack stand, and they are able to hook me up with a used hub and new bearings. Let's wrench!
I'm no genius, but I don't think a hub should slide that far on the axle.
Glad I remembered to pack the inflator!
Old hub has to get hammered off, lots of fun detritus to pull apart and clean out. Time to put on the new bearing and limp back!
Well berkeley, the new bearing won't go on smoothly either. We are going to stop photos for a bit for plausible deniability of liability, but let's just say It made it the 3 miles back to the trailer shop with only 1 bearing installed, and a lot of wobble. Here is what the bottle of the spindle looks like, and why my new hardware wouldn't install. Time to break out the file! Can I just use a flappy wheel?
bbbbRASS
bbbbRASS Reader
2/12/25 9:47 a.m.
Cotter pin with chain installed. Safety chains are good, so is the tongue jack, wheel & pivot. Rust seems to be all surface, tires and maybe wheels need replaced but this will only get maybe 50 miles a year on a road. Carry-On actually has a pretty decent website and lists the parts. However this trailer isn't the 2-in receiver listed and what the facility guy told me it had. It is 1-7/8, and I was lucky I had thought to bring all my hitches and balls just in case. The electrical on this will get completely redone. Here is what I'm (not) working with.
New full replacement kit from big river should be here tomorrow. Also was able to 3D print a cover for the one good spare light i had, but no sense piecing it together with how cheap the whole kit is. Will flappy disc the ground points first. Any thoughts on paint/grease or treatment after grinding?
iansane
iansane SuperDork
2/12/25 10:06 a.m.
You still have the old inner bearing on that spindle. Well, the centersection of the bearing. Get a flat punch and hammer it off.
bbbbRASS
bbbbRASS Reader
2/12/25 10:13 a.m.
In reply to iansane :
Yes! Realized that when I got back to work. Need to update photo.
wvumtnbkr
wvumtnbkr UltimaDork
2/12/25 2:02 p.m.
I think I have a spare trailer light like that.  I'll dig it out and see what I got.
Let me know if you want some help fixing that up.
bbbbRASS
bbbbRASS Reader
2/12/25 2:21 p.m.
Thanks man, will do! Don't worry about the light. A complete kit was like $25. Just debating how aggressive to be on filing the spindle.
wvumtnbkr
2/12/25 3:22 p.m.
It only matters where the bearing rides.
It's been awhile since I messed with a little baby axle like this.  Can you hold the bearings beside where they go on the axle?  I know where one of them goes (cause as mentioned above, it's still partially there).  I imagine the smaller one goes roughly even with the start of the threads.
You don't want the inner race of the bearing to be loose when installed.  Some slight persuasion (preferably with aluminum or wood) to install is acceptable.  Don't hit a bearing directly with steel. Hitting Steel on steel bearings can be no Bueno for bearing life.
Edit...  now that I think about it, the outer bearing should probably slide on the shaft fairly easily in order to set bearing preload with the nut.  Disregard my earlier comment for the outer bearing.  Though it still applies to the inner bearing.
You can get that inner bearing race off by grinding it with an angle grinder most of the way through in 2 places 180 degree out.  Then hit it with a chisel.  That's if you can't just tap it off.
bbbbRASS
bbbbRASS Reader
2/13/25 11:07 a.m.
New lights arrived. Looking pretty good inside. Have to do some adjustments to make them fit the old mounts.
wvumtnbkr
2/13/25 12:26 p.m.
Hauling hank has some new hawtnes.
Toyman!
Toyman! MegaDork
2/13/25 12:48 p.m.
That's an impressive amount of damage. I've never seen one slide up the axle. They almost always go the other way with the tire and wheel.
It may well be spindle or axle time. That looks like a standard spindle for 1" bearings. Depending on the axle, they are replaceable. $32 on Amazon.
JADODE Trailer Spindle BT8 EZ Lube Spindle for 2000lbs Trailer Axle Spindle 1-1/4"
Add a piece of 1.25 pipe and you can make a new axle in about an hour. BTDT
bbbbRASS
bbbbRASS Reader
2/13/25 1:07 p.m.
In reply to Toyman! :
Thanks! I'm having Corbin's check it out. They are my neighbor and help us a ton.
Toyman!
Toyman! MegaDork
2/13/25 1:08 p.m.
In reply to bbbbRASS :
#1 trailer shop in town. They won't steer you wrong.
bbbbRASS
bbbbRASS Reader
2/13/25 1:46 p.m.
They are fantastic guys (and women).
Worked sucked today (had to expel a Straight-A student) so I went to reset and run wires. Then it started raining harder and I decided it was a job for next week. I was cleaning off grounds when it occured to me, why not just run a ground wire to each light? The trailer is small, I have tons of wire, any reason it wouldn't be best to just individually wire all the grounds back up to a center tap?
In PA this would have been considered "clean." Down in SC this is one of the more rusty versions I've encountered!
The rain makes it hard to get really clean, but it should hold contact pretty well now.
AxeHealey
AxeHealey SuperDork
2/13/25 1:58 p.m.
This is what I was going to say. I'd bet an entire fresh axle is cheap enough to give you all of the time back you'd spend dealing with fixing the damaged one on there.
bbbbRASS
bbbbRASS Reader
2/13/25 4:44 p.m.
A little bench test of the Chinesey lights to make sure they all work and to see how much current they will draw.
Crazy how efficient LEDs are!
wvumtnbkr
2/13/25 8:10 p.m.
You are such a dork.
Stop playing with lights and come help me rebuild and reinstall my rx8 transmission so I can do the FIRM tt this weekend.
bbbbRASS
bbbbRASS Reader
2/18/25 4:42 p.m.
Lighting upgrade done!
the kit had crappy hardware and didn't include some terminals, so shrink solder joints, wago connectors, and Super 88 did the electrical. After grinding the mounts shiny I reused the old selftappers and added in several washers to get a nice tight ground connection. These clips I thought were nice, but they seem to be able to cut the wire and make a short? Still waiting on my new hub.
lights look great, and the wiring is all tucked away nicely and trimmed to length. The plug didn't come with a cover, so 25 minutes later and we have a 3D printed cover!
wvumtnbkr
2/18/25 8:22 p.m.
Those clips you refer to are sometimes called vampire clips.  They are the devil and should be avoided at all cost.  They suck louder than the fan driven Brabham car.
bbbbRASS
bbbbRASS Reader
2/18/25 8:27 p.m.
In reply to wvumtnbkr :
I think you're referring to the blue ones in the photo of crap parts? I didn't use those. The little metal "wire guide pieces" are what I used a few of and am doubting.
wvumtnbkr
2/18/25 9:15 p.m.
Ah gotcha.  Yes, I was.  Good call, brother!
bbbbRASS
bbbbRASS Reader
3/5/25 12:58 p.m.
Well, I had the experts finish off Hank. I forgot to have them take pictures, but they decided they didn't need to replace the spindle as the races were still good. The surface for the grease seal isn't perfect so that may leak some in time, but this will get a few hundred miles a year max.
Hank is Hauling!
wvumtnbkr
3/5/25 2:45 p.m.
Nice!
bbbbRASS
bbbbRASS Reader
4/24/25 12:31 p.m.
Hank did some hauling! Moved several tons of crusher run around campus (in multiple loads, no idea max weight I put on but probably close to the load limit). Not the idea deck for this, but a few pieces of scrap wood helps keep fines in and the holes made unloading a bit easier. The EGo power sweeper is one of my favorite yardwork tools I never knew existed/I would need. I also discovered the locks on the spring-loaded gate pins. Wow that's handy!
bbbbRASS
bbbbRASS Reader
4/24/25 12:37 p.m.
I will say while Hank is great, I need something a tad larger to move around the mower and such when necessary. So there will be a very, very low-key look for a 5x8 - 6x12 sized trailer with a ramp on the extreme cheap. Must have GVWR under 3K, and payload over 1300lbs. Located near Charleston SC if anyone spots anything in the next 6-16 months!
bbbbRASS
bbbbRASS Reader
5/7/25 4:59 p.m.
Hank keep hauling! Took out an acre of chainlink fence. Probably getting close to the weight here with the cement still on the bottom of most of the steel posts.
uBh3P53y2cJuwEmVoygpEN0eNhmSXxZN4G5Oc2fSbefevOxJFa0toaVCBmFP2YEj
