So the car is equipped with a 2.0 DOHC Direct Injection Turbo engine with 10.5:1 compression.
It is German and fickle.
First day back to work with the car I developed a coolant leak which required towing the car. A common coolant nipple failed. Fixed
Second day it developed a misfire. Diagnosed and replaced a coil. No pic of that but it's a coil lol.
The car has a cam follower that runs the HPFP off a lone on the cam. I ordered a new one along with tune up parts.
Saturday evening I pulled it out and found mine worn through. Asked on the groups and basically as I had no codes or drive ability issues. I sent it. Put a new one in and test drove her. Ran great!
Sunday morning while wife and son were sleeping I roll outside to make some improvements.
Cleaned the air box.
Replaced the air filter and cleaned the MAF.
It's a AEM dry flow filter. I don't plan on an intake as VW made the stocker pretty damn good!
While in there I replaced the coils with R8 coils
Further a fresh set of NGK plugs were installed.
Various clips and bolts were installed that were missing and a good wipe down of all the bay.
I have a GO Fast Bits Diverter Valve+ and a column mount boost gauge on the way. Also a PCV delete as well. Actually the GFB is here now. Timing belt and water pump is here. Have some days off coming up and I will do that service then.
Pic of the boost gauge from ECS.
And of the GFB. It reacts quicker than the stock unit and replaces know failure parts of the stock unit to minimize boost leaks and maximize throttle response.
Car runs amazing. Torquey and handled amazing. It really feels like a 07 Si (I had a 07 FA5). But with torque. Lots of it. Down low. The engine only revs to like 6500 or so unlike the K20Z3 I had. Which was what almost 8500?
Little things about the car. Really hard to describe. I love the interior and shifter. I'm in love generally.
Stay tuned.
