2 3 4
Indy - Guy
Indy - Guy UltimaDork
8/11/23 4:07 p.m.
In reply to NOHOME :
Well done.  Can you summarize your thoughts on the project?  Was it worth it?
NOHOME MegaDork
10/30/23 8:13 p.m.
Sorry Indy, did not see your post way back when and have not visited this thread for a long time.  Just came here to drop a video that Mrs NOHOME took of the first drive around the block way back when,
Was it worth it? Hell yeah it was worth it. Put it together for a good friend who has since been driving the rubber off the rear tires.  I myself only went around the block once and was glad that it was going home because it did not fit me ergonomically at all!  I think the car looks awesome, but not a car I want to drive.
 Painted another car when I swore that I would never paint another car. Swore off car painting all over again.   Met some new people who helped me a lot with the project and  gone on to joint the shop crew. Dipped a toe into the digital world of LS engines that I would not have done otherwise. Actually building an L33 aluminum block LS  for myself for who knows what reason. Time will tell where it gets installed but I will learn something building it.
Indy - Guy
10/30/23 10:02 p.m.
yes yes
NOHOME MegaDork
3/13/24 6:25 p.m.
The end of the story.
Dusterbd13-michael
Dusterbd13-michael MegaDork
3/13/24 6:28 p.m.
Oh man that sucks. Everyone ok?
adam525i
adam525i SuperDork
3/13/24 8:48 p.m.
Hope they walked away from it.
lownslow
lownslow New Reader
3/14/24 12:01 a.m.
Bummer.  I hope that no one was hurt.
Recon1342
Recon1342 SuperDork
3/14/24 9:55 a.m.
I think I speak for the entirety of GRM when I say "OUCH!!!"
Everyone is OK, right?
mechanicalmeanderings
mechanicalmeanderings Reader
3/14/24 10:03 a.m.
I hope everyone is okay, and that they enjoyed the car before it met its end!
NOHOME MegaDork
3/14/24 8:41 p.m.
In reply to all:
Believe it or not, not a scratch. Did a Mustang-show exit maneuver through a ditch, rolled and hit a tree. Everything but catch fire. Driver was ejected  and rolled to a stop unharmed.
Kendall Frederick
Kendall Frederick Reader
3/14/24 9:36 p.m.
That must've used up every bit of luck that driver stored up over a lifetime!  That's crazy, but good.
maschinenbau
maschinenbau PowerDork
3/15/24 8:51 a.m.
Ejected and no injuries? Amazing luck. That could have been so bad. I'm guessing this one's a write-off?
Recon1342
Recon1342 SuperDork
3/15/24 9:02 a.m.
Working in the armed forces and then as a Paramedic, I have seen far too many things to believe in random fate. If it ain't your time, it ain't your time.
Bummer about the car, though I am glad the occupant is ok.
3/15/24 9:26 a.m.
my crash reconstruction buddy tells me sometimes the person who is ejected is nowhere to be found, until they lift the car.  this could have been so much worse.
NOHOME MegaDork
3/15/24 10:22 a.m.
And on a separate note. The carcass was donated to me as a thank you for the help in building the car. How do I set a fair market value for the hulk if I decided to use the parts in a challenge build?  The engine and gearbox are a pig-in-a-poke at this point since the engine did impact the front cross-member after it met the tree. Would not be using this body/chassis, but it would be called the phoenix.
FYI the Hot Rod build was put together for a total cash outlay of only around 8k Canadian. While that did not include the chassis that rolled in the shop, it is a testament to the power of this board to make a cheapskate out of anyone who hangs around long enough.
3/15/24 1:08 p.m.
because i want to see your work up close someday, i'd be OK with you pricing it as a core engine and trans for whatever your local u-pull-it would charge, minus the cost of having to scrap a fiberglass body, plus the scrap value of bent wheels and frame. Gumby's head will explode though. ;-)
Recon1342
Recon1342 SuperDork
3/15/24 2:15 p.m.
New sub-class: Farthest fall from grace?
2 3 4
nkr7alZgYYGMKu4W2UQUVivTVHZNM4ocJQB6OhLISQFuDhokxU8t2LY2syrshlJn
