Dusterbd13-michael (Forum Supporter)
Dusterbd13-michael (Forum Supporter) MegaDork
1/19/21 2:43 p.m.
Projector retrofit is almost done. Little more polish and finalize wiring (left front is wonky for some reason). Got the new condenser mounted and the fittings crimped for ac....
1/20/21 2:02 p.m.
i do believe art has figured out painting rustoleum outside!
1/21/21 6:32 p.m.
time to see if it will hold vacuum....
Justjim75
Justjim75 Dork
1/22/21 7:56 a.m.
In reply to Dusterbd13-michael (Forum Supporter) :
I've crossed my toes and fingers
1/22/21 8:36 a.m.
Leaks at the crimp on the low pressure fitting on the compressor. Dammit. Guess i try again.
1/22/21 9:16 a.m.
now im excited.
1/22/21 1:42 p.m.
pres589 (djronnebaum)
1/22/21 1:51 p.m.
Was there a lot of science that went into the fresh & well-sprayed Rustoleum?  I figured your guy Art would have that down pat based on everything you've said about him.
Car is looking good from what you've shared lately.
1/22/21 2:19 p.m.
In reply to pres589 (djronnebaum) :
Not really. 50/50 thin with mineral spirits and a splash of hardener. He sprays it with a good hvlp gun. Im thinking the different solvent (we tried acetone and lacquer thinner before) and cooler temperatures allowed it to lay much better.
Im also blessed that art has sprayed more E36 M3 paint in E36 M3 conditions with E36 M3 equipment than most painters have sprayed. Hes no a show car guy, but a great cheap paint guy.
1/22/21 4:59 p.m.
looks awesome in the dark
1/22/21 8:00 p.m.
Heading in the morning to grab new brakes. Powerstop evo pads and four new rotors. All for $50!
So, good brakes (at least not the leftovers from parts cars ive been running). Hopefully worth it!
1/24/21 11:11 a.m.
It holds freon and water!
Driver side wiring and lighting done.
Passengers next.
Also, blue aluminum lug nuts look a little dumb,  but are way more user friendly than the spline drive stuff i had.....
maschinenbau (I live here)
maschinenbau (I live here) UltraDork
1/24/21 12:47 p.m.
I can add +1 to spraying Rustoleum through a HVLP. 2:2:1 using lacquer thinner and Majic catalyst hardener from Tractor Supply. Goes down very glossy with that combination! I had better luck with warmer surface temp by pre-heating the parts with a space heater.
DeadSkunk  (Warren)
DeadSkunk (Warren) PowerDork
1/24/21 1:17 p.m.
In reply to maschinenbau (I live here) :
Would the Tractor Supply paint behave any differently to Rustoleum? I only ask because I'll buy whatever is cheapest when the time comes to paint my Challenge car.
1/24/21 1:47 p.m.
IIRC the Rustoleum was cheaper when bought in quart or gallon sizes compared to the tractor paint, which is why I used it on a Challenge car. The Rusto also has more color options and more places to buy it in spray cans if you need to touch up. I've used the tractor stuff on a frame and I didn't find it any more durable than the rustoleum.
1/24/21 5:16 p.m.
I found the tractor supply stuff way more fragile than rustoleum. And more expensive.
But it does lay down nice! Still staying rustoleum myself though.
1/25/21 5:26 p.m.
closer....
1/30/21 8:18 a.m.
one more corner, then test drive.
1/30/21 10:29 a.m.
Brad brought my decals this morning. $50 well spent!
Need to grab another can of rustoleum for touch up.
And ready to test drive!
1/30/21 4:10 p.m.
Not an uneventful test drive, but a successful one.
Had my splitter cables come apart and i ran over it. Time to rethink it entirely...
759NRNG (Forum Partidario)
759NRNG (Forum Partidario) UberDork
1/30/21 5:24 p.m.
equal greater than division from Seth?
1/30/21 6:09 p.m.
In reply to 759NRNG (Forum Partidario) :
Via stampie!
About 10 miles today! The heat doesn't seem to work. Im wondering if I missed hooking up the blend door cable.
Bew splitter is on, some decals removed as i felt it went too far.
Noisy rear again. Pretty sure i lost another bolt.
Staying at 195 more or less driving around,  ans thats what I have the thermostat rsted at. So thats nice.
Seems to run better
Dude in the chick-fil-a drive through was absolutely stoked to have a race car come through for a salad.
All WINNING.
Stampie (FS)
Stampie (FS) MegaDork
2/8/21 5:33 p.m.
That the bolt I put in or did you already replace with a nylock one?
wvumtnbkr
wvumtnbkr PowerDork
2/8/21 5:38 p.m.
If you get a chance for cheap, do the 3500 swap.  It is even mo Betta.   It's like the 3400 dialed up a bit.  1st and 2nd gear are useless with 245 and an aggressive launch.
oSI9AK1Br0k8Hf9F8fxu9eyX0eDURG0LCIEo5os5Us3lgP4ptKPAz1gapBL0l2Tr
