All engine torque and poor set up, we know what to do to improve it, some simple adjustments and one addition
I know 4 bar links are popular with drag racing, but you should look into a 3 bar link. I first read about it in a Racecar Engineering a long time ago, and then found some reference of it on corner carvers (just lurking) as well as a guy who has a website (I have the link at work).
Anyway, with proper set up, it will geometrically reduce or eliminate the torque wedge that the engine makes.
I'll try to remember to link it tomorrow. But it seems as if it would be a great solution to your launch issues. And work wonders on the autocross.
IIRC, the link has a references to this guy drag racing with an open diff, and getting great traction.
aussiesmg wrote: All engine torque and poor set up, we know what to do to improve it, some simple adjustments and one addition
Ok, so now I have to ask, what does one do to counteract the torque that's trying to flip the car over. Or is there someplace I can read about this sort of stuff?
Do tell, cause I am not fully convinced that it was all Panhard bar. I am looking for a broken spring, dead shock, or heavy dead hooker in the rear right corner of the trunk causing sever disruption of the corner weights. It happens.
Aussie, I'm kind of with NOHOME on this one.
The car leans to the right when sitting still and not running. As in, the rear bumper is about 2" out of level. That's not torque or the panhard bar.
Granted, it's greatly exaggerated when you punch it. THAT'S torque and the panhard.
But something is off on the static position as well.
Here's a 12 year old discussion about it on Corner Carvers. There was a link to a guy's site with a spreadsheet for caclucations, but time passes.
http://www.corner-carvers.com/forums/showthread.php?t=2474
In reply to aussiesmg:
Ah, I see that now. The torque wedge solution is to move it to the right side of the axle- the geometry uses the axle ratio, the distance from the center line, the height from the center line, the lenght and the angle up the upper arm. As well as the lower links, angles, lengths, etc.
Seeing that it's highly fabriated now- it looks to be a pain to move. But something to think about...
Most of the links are no longer there- the most recent post in thread was 5 or so years ago.
Took a little more looking, but here's the site with a simple calculation http://www.shopeshop.org/tim.19.htm
I tried to make a spreadsheet based on the math of the Racecar Engineering article, but I never checked to see if it worked or not. I wish I could find my copy of that article...
(finding a very old post of mine at alfabb- this is the aticle- "The Design & Tuning of Asymmetrical Racecars, Part 4: Asymmetries in Beam Axle Suspensions"- V9N6- Racecar Engineering)
Remember if you read this through at no time did I state this was all Panhard related.
1 Panhard adjustment.
2 Corner weight adjustment, 200lb off front right to left rear, which also explains the high left rear
Test
3 Add adjustable rear sway bar
Test
From there I will see where we are.
Until the baseline is straight, every change is not able to show improvement or otherwise
Watch it run in $2010, (The very 1st post has link) the car chassis is sound IMHO, but testing will show its true ability
aussiesmg wrote: Remember if you read this through at no time did I state this was all Panhard related. 1 Panhard adjustment. 2 Corner weight adjustment, 200lb off front right to left rear, which also explains the high left rear Test 3 Add adjustable rear sway bar Test From there I will see where we are. Until the baseline is straight, every change is not able to show improvement or otherwise
If you are answering my posts, neither am I. Just pointing out that there are some ideas that the third upper link can be used to couter act the engine torque- which should ballance the loads to each wheel as well as change the squat.
NOHOME wrote:aussiesmg wrote: All engine torque and poor set up, we know what to do to improve it, some simple adjustments and one additionDo tell, cause I am not fully convinced that it was all Panhard bar. I am looking for a broken spring, dead shock, or heavy dead hooker in the rear right corner of the trunk causing sever disruption of the corner weights. It happens.
hobiercr wrote: Tell me they let you drive it into the hall!
Our humble little MGB is parked 10 feet from an Indy Car, life is good
The engine is out, we are porting the intake and installing a fogger system for the Nitrous.
Hoping to get some time at Norwalk and Muncie to sort the suspension and to learn the car before $2015
