MarshHoltRacing
MarshHoltRacing New Reader
6/12/20 3:36 p.m.
 I got pretty bogged down with clutch details on my Renault, and I decided to get started on a new project. I've been designing this thing in solidworks whenever I've had downtime or can't get out to the garage to work on the Renault. I posted about it awhile ago, when I was thinking id do a modern transverse V6, but I've gone a bit off the deep end since then. I bought a never-rebored 4bolt 350 SBC locally(the guy thought it was a large journal 2 bolt main 327) as well as a richmond 2.43 1st super T-10, Winters Sprint Quick change, an IDF manifold, 15x10 & 15x8 TorqThrust Ds, 295/50/15 tires for the rear, 255 fronts, and a set of trickflow heads and a cam(its their advertised 420hp top end kit)
I'll be doing a DOM tube frame and a hammerformed 3003 alu body(luckily, there isnt much bodywork to it)
I'm basing the transaxle off the Bob McKee recipe, but a richmond super t-10 instead of the borg-warner, and a winters sprint instead of a halibrand 201. This does mean i loose reverse out of the maincase(output shaft coming from the quick change to the pinion has to occupy the space of the reverse layshaft ), but I can probably get a reverse gear between the trans output and the qc(4 forward speeds AND 4 reversedevil)
maybe i can linkage it so it will only go in reverse if its in 1st.
But anyway, someone brilliant here did a 3d scan with a kinect and I gave it a shot for scanning my transaxle parts. Not dimensionally accurate, but damn good enough for a placeholder in the model!
Also I printed some 50mm IDF style throttle bodies as well as a mold to sand cast them in aluminum.
I also am planning on white180 deg headers. I have them within .5" of each other in the CAD at 41" primary length
Ill get into some more detailed stuff but I wanted to throw this out into the aether because Im pretty excited about it
californiamilleghia
californiamilleghia Dork
6/12/20 3:52 p.m.
I love the cad , I assume you do CAD  at work ,
are there  any throttle bodies  off a production car that has a bolt on base like the Webers ?
I am much more impressed with all this than kitty is.
Indy "Nub" Guy
Indy "Nub" Guy PowerDork
6/12/20 5:12 p.m.
I'll be following this one closely.
The proportions of the CAD model look great!
bgkast (Forum Supporter)
bgkast (Forum Supporter) PowerDork
6/12/20 5:44 p.m.
Wow, looks like an awesome start.
Stefan (Forum Supporter)
Stefan (Forum Supporter) MegaDork
6/12/20 5:54 p.m.
None come to mind, by Jenvey, Borla and others make them ready to go with fuel rails, etc. for DCOE/DCNF/IDF, etc.
Mezzanine
Mezzanine Dork
6/12/20 6:26 p.m.
Holy cats. At first I was pretty mad that the Renault got moved back in priority...But after seeing the parts and rendering, I'm not even mad.
+/-.5" on your headers is pretty darn good.
nderwater
nderwater UltimaDork
6/12/20 6:55 p.m.
Subbed, for sure
MarshHoltRacing
6/12/20 9:24 p.m.
In reply to californiamilleghia :
Jenvey & borla has a set but i just cant justify the 1200$ for the set. I really want to be sub 10k into this build(yeah right) Ive cast a few TBs before and I have some ideas to do short production run. Its kinda what i do professionally, but alot more fun
MarshHoltRacing
6/12/20 9:41 p.m.
i know! I need to get back to the renault. It ought to be proper fast. But i have to come up with a cable clutch linkage for it and after having to rebuy a few clutches because i didnt know what year renaults had what clutch, i got a bit disheartened. SBCs and old school domestic parts are soooo much easier than obscure vintage french parts
AxeHealey
AxeHealey HalfDork
6/13/20 7:10 a.m.
SO in for this.
Hasbro (Forum Supporter)
Hasbro (Forum Supporter) SuperDork
6/14/20 9:46 p.m.
Subbed. Very similar looking to what I want to do with my Boxster, the differences being mine will be road legal and you know what you're doing.
MarshHoltRacing
8/25/20 9:29 p.m.
So ready to start cutting tube.
TVR Scott (Forum Supporter)
TVR Scott (Forum Supporter) Dork
8/26/20 8:49 a.m.
Very cool!
Your surface work in SW is terrific.  I wish I was better at it.
8/26/20 9:09 a.m.
Machinery's Handbook FTW
also, i super dig those headers. i wanted to do something similar for MonZora but i fear it would take me forever to execute.
nocones
nocones UltraDork
8/26/20 9:28 a.m.
I am pilling on the desire to follow along on this one.  I'm loving the mix of Xbox Kinnect 3d Scanning, 3D Printing, a T10, Iron Block V8 and Cooper Radial GT tires.    It's just so "I'm going to build what I want".
iansane
iansane Reader
8/26/20 10:20 a.m.
I like this build so much. I desperately want something in this vein. Hell, I've been threatening the girlfriend with selling off most of the fleet and building a lotus 49.
stroker
stroker UberDork
8/26/20 10:40 a.m.
I'd like to know more about your drivetrain hardware.  I'm not familiar with the gearbox/differential and how I might be able to source something similar.
This has a terrific '60's/early Can-Am vibe!
Gunchsta
Gunchsta HalfDork
8/26/20 11:15 a.m.
Cripes this looks like it's going to be impressive. Hell, it already is!
What a cool assortment of parts.
Dusterbd13-michael (Forum Supporter)
Dusterbd13-michael (Forum Supporter) MegaDork
8/26/20 11:22 a.m.
Oh, E36 M3.
This will be dangerous to my wallet....
Azryael
Azryael Reader
8/26/20 11:44 a.m.
You'll definitely be able to outrun those gleaming alloy air cars that are two lanes wide.
Following along!
8/26/20 1:11 p.m.
In reply to Azryael :
Only if it's red.
Lof8 - Andy
Lof8 - Andy SuperDork
8/26/20 1:21 p.m.
Wow!  Like a CanAm car. Very cool.
Azryael
Azryael Reader
8/26/20 1:22 p.m.
Now it has to be red... even if we have to put it to a vote.
smokeysevin
smokeysevin New Reader
8/26/20 2:18 p.m.
You may want to look at zx12r throttle bodies. They use a 2 bolt flanged rubber base with a hose clamp to the throttle body.
They are 46mm iirc.
Sean
O8a0ctV3hvPk7UPihtfxrS5tuMk1g9wsIiJU658KHdqpR5ThLGAqOmSBT1QIXjcr
