So, lessons in hand, I made sure to grab the "smoothest finish" small (4") roller they had at the hardware store, some paint tray covers, a handy 2 qt mixing cup, and some new stirring sticks.
My earlier trip to tractor supply yielded these gems for about $50:
![](https://media.tractorsupply.com/is/image/TractorSupplyCompany/1030957?$456$)
![](https://media.tractorsupply.com/is/image/TractorSupplyCompany/1177127?$456$)
And so I began my wonderful adventure.
First thing to know about this paint is that it is THICK. Like, we're talkin "Dammmmmmmmn giiirl" thick.
I couldn't find the golden ratio to mix anywhere, so I started to guess. I first poured 1 qt of paint, and that .5 pt of catalyst is for a whole gallon, so I poured in a bit over 2 oz of that (60 ml).
Then I started mixing in some mineral spirits. I started at about 4:1, so I was somewhere near 8 oz of it. I tried that for the first coat.
---disclaimer:. My expectations were so low that I did NO prep to the environment besides a basic sweep up the week before. I mean, look at the sawdust in some of these pictures. I just finished making three beds and a bookshelf in here! ---
It turns out that this was just too thick, so it went on with more texture than I wanted. Here's the the first coat:
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/11/24/1606270651_img_20201110_141859_mmthumb.jpg)
Not bad, but more texture than I was hoping for.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/11/24/1606270775_img_20201110_140608_mmthumb.jpg)
I let that sit overnight. The next day, it as dry enough to do my second coat.
As I mentioned, it was thicker than I wanted it to be, so I mixed in another 4th (8 oz) of mineral spirits.
That's the ticket! This stuff flowed a lot nicer and did a pretty darn good job of self levelling!
One tip I found is to use a foam brush to do the detail work and then blend that in with the roller.
And of course, enjoy the bugs!
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/11/24/1606270984_img_20201111_082251_mmthumb.jpg)
If you get something like this, grab the foam brush and work it down a bit. You can blend it in pretty acceptably.
For car prep, I removed anything that took less than 5 minutes to remove and made the job easier: marker lights, gas cap, windshield washer nozzles, headlight lids, tail lights and trim panel, top rubber seal along the a-piller/roof, and frankenstein bolts. Anything that took more effort was left on and masked with tape such as the door handles, mirror bases, windshield gasket, trim along top/door glass.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/11/24/1606271324_img_20201111_104236_mmthumb.jpg)
Here's the assembled car:
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/11/24/1606271013_img_20201112_232034_mmthumb.jpg)
Here's what those repaired rocker areas look like:
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2020/11/24/1606271370_img_20201114_174240_mmthumb.jpg)
I'd say that meets the goal!
