Several replies in this post.
In reply to AAZCD (Forum Supporter) :
You're funny. i can't wait to see what kind of junk i have to work with now!
In reply to TVR Scott (Forum Supporter) :
Yeah, it was a little non-sensical as written. i tend to jump around a bit, wherever there's white space. basic story is that i have a shifter base with lever that has some total movement in fore-aft (aka 1-2) direction and some total movement side to side (aka neutral). and for those total movements, i have total cable travels.
i have a transmission selector shaft that requires some fore-aft rotation for 1-2, and some lateral movement for neutral. because challenge, i have about $3 available for materials. Boxster shifter (separate purchase, not part of that $3 LOL) came with cable bracket and cables (thanks AAZCD!), so i have to make all those things work together.
at the trans, i can measure with a ruler the lateral travel between gates, no problem. but for the rotation, i can't measure the angle so i measured the linear travel at a known height from center. then by making that height taller, i can use up more cable travel, and by making it shorter i can use up less cable travel.
from my buddy Jay's SS, I have targets for how far i want the shift knob to move in the 1-2 and in neutral. so now i just have to go from knob travel to cable travel (this is defined by the shifter base itself, i just had to measure it), then calculate the lever ratios for the bell cranks so my desired cable travel gives the necessary selector shaft movement. i couldn't match the SS travels exactly because of package limitations on the neutral bell crank. Still, near as i can tell, it feels pretty decent.
In reply to maschinenbau (I live here) :
i have seen your work. i am honored by your praise.
In reply to java230 :
it ain't over yet!
In reply to ShawneeCreek (Forum Supporter) :
the kid is already in some STEM extracurriculars, and both the dad and the kid know they are welcome in my garage anytime. they are seriously my favorite neighbors ever.
In reply to NOHOME :
I sure hope so!
