In reply to AWSX1686 :
there's been a lot going on, believe me. i'm keying this in from my laptop, will edit from my phone to add pix in a little while.
C4 front upper shock mounts were integrated to C4 frame, where the crossmember bolts in. Last weekend, i cut them off the frame and bolted them onto the crossmember, then welded them in place so i could remove the bolts to save weight and possibly use them elsewhere.
I abandoned previously-posted design for front sta-bar chassis mounts, and sliced up more of the C4 2-piece brackets to make a simpler mount. was able to scrounge all required fasteners from the Red Solo Cup Of C4 Hardware.
then i updated the board. It felt good to cross off a few things, but it sucked to have to extend projected completion dates on other things.
Then from 9/8 to 9/13 i didn't accomplish a lot, just sort of picked at things here and there, pondered some additional crossmember bracing, and bought a bench-top sandblast cabinet. it's not big enough for rims, but it'll hold just about anything else i'll need it for.
Saturday 9/14, wawazat stopped by to do some more top secret stuff while i worked on the crossmember bracing. what a great guy, drives 30 minutes on a beautiful afternoon to work on part of the car that maybe nobody will ever see. His work will be featured in the build book.
Which brings us to the subject of crossmember bracing. Lets back up and consider C4 front frame and suspension design. Suspension crossmember attaches to frame rails relatively high. Braking forces are generated at the contact patches. So there's a large moment trying to roll the front suspension under the car in braking. The C4 had two bolt-on braces extending from the center of the crossmember diagonally rearward to the frame, to react these forces lower in the chassis, where it drops down and turn outboard to the rocker panels. The Corvair rails are smaller than the C4's, and the A7's will generate a lot more force at the contact patch than the OE Corvair tires ever could, so I knew these braces would be important. There's a good place on each side of the crossmember to attach to, inboard of the LCA rear bushing attachment. And there's a great spot on the Corvair body to react these forces into, where the frame rails meet the base of the forward bulkhead -- can't call it a firewall since there's no engine in front of it ;-)
unfortunately it's a pretty tight angle where the brace meets the chassis, so I improvised this solution:
Figuring it out on the passenger side took about 4 hours all in. Doing the same thing on the driver's side took maybe 1.5 hours. Part of my "figuring it out" included a lightbulb moment when i realized the CAD could be multiple pieces taped together. Duh! After that, i broke out a can of "make that E36 M3 disappear" and improved my welds dramatically.
I got my 14-year-old involved again, this time sandblasting and painting sta-bar parts.
Then I updated the board again.
Sunday: Applied some more "make that E36 M3 disappear", then some "highlight what you want people to notice", then i broke out the torque wrench and assembled the front suspension for what I hope is the last time.
Then i updated the board again.
today a bunch of parts came in. 37 days until I head for Gainesville. Berkeley.
