I ended up getting orders for two more roof panels, so the engines of industry have gotten turning again. Nothing I've not documented before, though I did buy more 17 oz biaxial fabric - that stuff is just so nice to work with.
I've turned my attention to the hood repairs. First up is this mess on the right-front corner - sorry about the blurry pic:
It should look like this:
I've got some ideas in-mind on how to get a mirror-version of the good side. I've got one crafty plan, and then the fall-back of scanning and 3d-printing a mold. We'll see where it goes.
Also, I messed around a bit with spider cracks. This frickin hood is covered with them. Example A:
You can see on the top right where I took a dremel to a couple of them. It's easy and fast, though I feel like I'm not going to have much hood left in some areas.
Also, some of the lines that look like cracks seem to be just glass fibers that show up very clearly.
More pics - a couple super obvious ones surrounded lines that probably aren't cracks:
I have many questions on this whole thing, so I'm hoping some of the members with lots of British glass knowledge with chime in (Paging: Roddy Mac and Turner X19).
Is there a way I can improve the contrast? Like could I wipe down the surface with epoxy coloring-agent, and then wipe the surface with acetone? The dye could wick into the cracks and show me what's what. Worth a try?
Once they're ground out, then it's fill with resin/chopped fiber? Or should I thicken some gel-coat? New experiences here.
Looking further down the road, should I think about some structural reinforcement on the underside? Like is this part all spider-cracked because it's old or because it's weak? The PO did add some fiberglass to the wheel-well area, though it's a poorly done repair that will need removal.
More on the annoying previous owner front, I had a quick look at the front turn-signals. Short answer, they look like crap. Gaskets are trash, chrome is rusted, housing is cracked:
And then I saw the Toyota logo. Screw you, PO. You suck.
I'm looking into replacements, and have a pretty good discussion going on the TVR owner's board. The originals are from some old Austin, and are NLA. Others have used TR7 or Spitfire parts. Maybe one of the TVR parts houses in the UK has a new version, but it's more modern with clear lenses, not the full orange original version. No need for decisions right now.
