42 43 44
JoeyM
JoeyM Mod Squad
1/4/25 2:09 p.m.
I just tried a 3/4 inch Bimini slide jaw clamp even though the outer diameter of the conduit is only 0.706
This might still make a decent hinge.  I think I can remove the play and get this to work if I add a shim/collar to the tube at the spot it needs to grip.
JoeyM
JoeyM Mod Squad
1/5/25 5:50 p.m.
Now that we have an idea how the hinges might work, I did another 2D mockup of the back.  The blue tape line represents a possible position for top fabric.
I will call the top bow that mounts directly to the body, and extends all the way to the back of the car, the "primary bow." Based on the above mockup with blue tape for a roofline, it seems like this primary bow will probably me too be around 27 in on the sides.... Possibly a little less.
I'll call the bow that attaches to the primary and extends forward towards the roll bar the secondary bow. The secondary bow will be shorter, probably less than 19 inches.  That means the bow I created for a test of a fabrication method could be cut down and used for the secondary, because The sides are a little longer than that.
brad131a4 (Forum Supporter)
brad131a4 (Forum Supporter) HalfDork
1/5/25 10:17 p.m.
Just a thought. How about checking out one of those portable 10x10 shade tents. They have the scissoring sides that may work for you. I've seen people just throw them away because the top gets torn or lost.
JoeyM
JoeyM Mod Squad
1/5/25 11:20 p.m.
An attempt, using PCL plastic to form the collar
JoeyM
JoeyM Mod Squad
1/6/25 1:46 p.m.
that isnot a bad idea....definitely worth looking into
JoeyM
JoeyM Mod Squad
1/16/25 7:18 a.m.
Okay, here's a quick update on why I haven't been updating. It's the start of the new semester and I've been spending all my time trying to get my classes to launch successfully. Lots of fighting with learning management systems and publisher websites, etc.
In addition to that, I've been having reservations about the 1/2-in conduit. Although it looks like it is shapeable, and some Bimini fittings do fit it, The stuff just seems lightweight and flimsy for the task. I know that some rat rod folks do build frames for tops out of conduit, but I think they're working with larger diameter stuff. If I do have time to get out and work on the car this weekend, will probably try using the same conduit bender on larger conduit, and maybe even on better steel tubing than conduit to see what it's capable of.
Obviously, if whatever I try to build it out of it's not substantial enough and fails, then I'll have to try rebuilding it out of other stuff. I'd love to not have that failure and extra expense happen, though. That's why I'm going to try other materials before I go much forward.
BTW, there's some useful information on conduit on this page
MuSTANK
MuSTANK Reader
1/16/25 10:15 a.m.
If you're loving how the 1/2 inch conduit works for you but are just concerned about how flimsy it might be in use, mix up some fiberglass catalyzed liquid resin, or gel resin, and fill the tubes with that. Won't add a whole lot of weight but will strengthen it considerably. Used it on a smaller job, a light bar for the MG Midget bumper, and it worked out swell. Even let us drill holes for the light mounts without collapsing when the bracket bolts were tightened.
A thought . . .
JoeyM
JoeyM Mod Squad
1/16/25 12:37 p.m.
A thought . . .
Oh wow! That is a great idea. This is why I love this forum
JoeyM
JoeyM Mod Squad
1/17/25 10:52 p.m.
JoeyM said:
Today has been one of those good news/bad news situations.
the bad news:  3/16 inch flat rod I need for the Packard-style scissoring parts of the top may be difficult to find at a reasonable price.  .Mine and Mill advertises the far more reasonable price of $15.69 for 20 feet, but my local store says they haven't had any 3/16 - in any(!!!) width - for many months
Possible good news:  Mine and Mill may not have 3/4" flat rod but when I called today they said they have 1/4" by 1" on order, and may be getting some in this week.  If I can live with the beefier stuff, I can save a fair bit of money
JoeyM
JoeyM Mod Squad
1/18/25 3:39 p.m.
I have another thought for materials. The taller top bows that I've been trying to build from conduit, could be built by using the short commercially made top bows and welding them to some narrow pipe.  I'm not sure how safe that would be, however, and have started a thread about using pipe in a convertible top.  Please chime in and let me know how Daffy that idea is. If the GRM hive mind says to steer clear, I probably will
JoeyM
JoeyM Mod Squad
1/19/25 10:55 p.m.
Yesterday I took my wife's grandpa puttering around the neighborhood
JoeyM
JoeyM Mod Squad
1/20/25 10:50 p.m.
A thought . . .
I'm liking this idea. What type of epoxy resin did you use? Was it a deep poor epoxy? Do you by chance remember the brand? More importantly, how long did it have to cure before it set up. Did you pour and then wait several days?
JoeyM
JoeyM Mod Squad
1/25/25 6:49 a.m.
Thanks to a comment from Trent in my other thread about the convertible top, I now know about the Metal Supermarket chain, and know that they have a store in Lakeland.  MS had what I need (3/16" thick, 3/4" wide) to make the scissoring portion of the top.  Most of the tubing in this car was purchased at Mine and Mill, but lately they haven't had the flat rod that I currently need; I've called repeatedly with them always being out of stock.  The MS price (1.94/ft) was double the advertised M & M price, but still less than a big box store (Home Depot = $4.77/ft.  & Lowe's = $3.33/ft)
Here's the flat rod along with some yardstick pieces of similar dimensions. I plan to mock up the scissoring bits in wood to figure out the design before I start cutting metal
For those wondering how cold it has been in Florida:  socks and shoes in this picture; I am not running around the garage barefoot.
JoeyM
JoeyM Mod Squad
1/26/25 10:16 a.m.
JoeyM said:
A thought . . .
Fingers crossed, I just ordered some resin.  Before doing this I will need to get my final tube lengths figured out and cut.  I will also test it out on a conduit scrap before doing the top bow pieces....and tape around the cut edges to make cleanup easier.
JoeyM
JoeyM Mod Squad
4/12/25 11:35 a.m.
Oh, the car has set for 2 months after an oil change gone bad, but thanks to some outside help from my mechanic making a house call, she's running again.  I'll probably post explanatory details later. Right now I'm just emotionally fatigued physically tired.   I want to curl up and sleep, but before that need to go get a new set of NGK plugs.  I'm posting a picture here, so I don't write down what I need on a scrap of paper and then lose it
Patrick
Patrick MegaDork
4/15/25 1:48 p.m.
Buddy is in japan right now and sent this
Crackers (Forum Supporter)
Crackers (Forum Supporter) SuperDork
4/15/25 2:01 p.m.
In reply to Patrick :
Anyone else amused that it's on stands and still has wheel chocks?
JoeyM
JoeyM Mod Squad
4/24/25 8:35 a.m.
Awesome! I *think* that is a Type 11.  I had heard that there was a green one in the "history of the Japanese automobile" section of a Toyota-owned car museum in Ginza. Do you know if this photo is of that car, or is there another surviving one that I have not heard about?
Patrick
Patrick MegaDork
4/24/25 10:23 a.m.
In reply to JoeyM :
It is that car
JoeyM
JoeyM Mod Squad
4/24/25 2:41 p.m.
That's cool.  I've seen pictures of it before, but never from that angle.  From photos I had seen previously, I knew that the back end on the Type 11
https://www.pinterest.com/pin/1933-datsun-12-phaeton--558516791278726587/
is a little different than the Type 12 back end, which has a little bit more curve.
The biggest difference I have seen is that the Type 11 fenders are nearly two-dimensional (i.e. very little crown to the sheet metal)  Obviously, the Type 12 has a bigger engine, too
42 43 44
Qn2brwEcWvoMZ35C3q8FYlJeO0yzxkHhNiMnT8RWbVJ1e9nvF20LFIGhSzJZgpny
