3_8scbug
3_8scbug New Reader
8/23/16 7:44 a.m.
[/URL]" />
jfryjfry
jfryjfry Reader
8/23/16 8:12 a.m.
Picture no worky :(
3_8scbug
3_8scbug New Reader
8/23/16 10:55 a.m.
[/URL]" />
3_8scbug
3_8scbug New Reader
8/23/16 10:55 a.m.
3_8scbug
3_8scbug New Reader
8/23/16 10:56 a.m.
3_8scbug
3_8scbug New Reader
8/23/16 10:56 a.m.
Idk what's wrong with them
3_8scbug
3_8scbug New Reader
8/23/16 10:57 a.m.
RedGT
RedGT HalfDork
8/23/16 12:10 p.m.
The last post that is marked 10:55am works, if that helps. Do whatever you did there.
3_8scbug
3_8scbug New Reader
8/23/16 12:19 p.m.
http://www.duramaxdiesels.com/forum/showthread.php?t=72273
3_8scbug
3_8scbug New Reader
1/7/20 8:14 p.m.
Different direction. S550 mustang gt front and rear suspension and brakes. 14" front brakes with 4 piston floating calipers. 13" rear brakes with independent rear suspension. V10 engine and tr6060 transmission. Right hand drive. Everything is at my shop. I will post updates and pics regularly. 18x9.5 corvette rallys. 295/45/18 tires
jfryjfry
jfryjfry Dork
1/8/20 4:51 a.m.
Well that took a sudden, awesome turn.
3_8scbug
3_8scbug New Reader
1/8/20 8:12 a.m.
I know right lol
GIRTHQUAKE
GIRTHQUAKE HalfDork
1/8/20 9:00 a.m.
V10? Like... like Dodge 8.1 Liter V10? And right hand drive? This thread has turned into the equivalent of a Lemons rally pit party when you can get Barbeque AND pizza AND homemade pastries. Full sensory overload!
3_8scbug
3_8scbug New Reader
1/8/20 9:57 a.m.
Ford 6.8 v10
3_8scbug
3_8scbug New Reader
1/8/20 4:55 p.m.
Really curious about a roots blower and how it would mount
3_8scbug
3_8scbug New Reader
1/10/20 6:58 p.m.
Yep this is awesome. I was waiting in the window for the ups truck like a puppy waits for its owner
Floating Doc
Floating Doc SuperDork
1/11/20 6:38 a.m.
Nothing in this thread makes sense.
I love it.
Edit: oh, and thanks for catching us up. I'd hate to miss anything.
3_8scbug
3_8scbug New Reader
1/12/20 12:01 a.m.
ok so got the irs in the nova today. I wanted to be able to take it in and out so i started off making some dowels out of grade 8 nuts
the mount plates have the dowel on one side and the hidden nut welded to the other then i placed them in the holes of the subframe mounts and bolted them down
i took the rear axle out of the nova and got the irs in place. made mounts out of flat steel, i ran pieces from the nova frame rails to the plates that were bolted down to the subframe.
once the suspension was in i test fit the corvette rallies and am in love with the way they fit. im looking for a flare that works.
its awesome sitting on its own. i have it on my wifes cobra wheels until i get tires
brad131a4
brad131a4 Reader
1/12/20 1:36 a.m.
I'm leaning more towards box flairs in the vain of dasianti 510 wagon. Same boxy feeling to the car. Wish I knew how to photoshop. That way I could just show you.
NOHOME MegaDork
1/12/20 6:11 a.m.
I know nothing about this IRS  and it's geometry, but the a- arms look to be too angled for my eye. I would expect that a lower ride height with the wood springs cut shorter  so the arms were almost parallel to the ground would be correct.
Pete
Dusterbd13-michael
Dusterbd13-michael MegaDork
1/12/20 6:15 a.m.
Nohome: The axles parallel make them the strongest on irs.
3_8scbug
3_8scbug New Reader
1/12/20 8:37 a.m.
Pete
If you look closely you can see I have 4x4" wood blocks cut and in place of the springs because of the offset of the wheels its sitting on. I will have to modify the wheel wells later.
3_8scbug
3_8scbug New Reader
1/12/20 8:39 a.m.
I put blocks in the place of the springs until I can get the wheel wells modified.
3_8scbug
3_8scbug New Reader
1/12/20 8:42 a.m.
It will sit a bit more level than in this picture once everything is correct with the wheel wells
AngryCorvair
AngryCorvair MegaDork
1/12/20 8:46 a.m.
My buddy Jay has those rims on his '69 Nova. They look so right.
Birthdays
YMEnRzmmrOCYtXhXeUw8z2OkK5AS1JtE9MyxXOzCN16WkB6l6DpkCX2fBIqgJAuj
