pimpm3 (Forum Supporter)
pimpm3 (Forum Supporter) UberDork
11/5/22 9:21 p.m.
As some of you know I bought the BMW kart from Robbie after the challenge.  It is awesome so I could not pass it up.
Robbie Challenge Car
Of course Robbie got it from racebrick who originally built it to use with his kids for track days.
Original build thread
Since I already own a 2022 BRZ for track days and autocross I am going to take this build in a different direction.
My plan for the BMW kart is to build it into a four seat dune buggy.
I plan to modify the cage to seat four safely, install factory springs for a slight lift, put a set of 28 inch all terrain tires on it, add a set of wrangler bumpers, possibly a winch, and add a truck box behind the rear seat for storage.
Since I bought it without seats my 1st step was to buy a set of factory seats from the junk yard.
Obviously they bolted right in.  I grabbed the entire rear seat as well.
The back uppers's wont fit with the current cage.  I grabbed a core support, fan and hood while in the junk yard as well.
I grabbed all the seat belts as well.  Next step will be adding brackets to the cage to mount them and then modifying the rear of the cage to accommodate the rear seats.
Toyman!
Toyman! MegaDork
11/5/22 9:25 p.m.
This should be fun!
singleslammer
singleslammer PowerDork
11/6/22 12:27 a.m.
This car is a Swiss army knife!
11/6/22 3:06 p.m.
Installed the hood and core support today.
I also put an old harness in so I can use the car untill I update the cage.  It's even the right color.
11/6/22 5:43 p.m.
This car is on it's third life.
03Panther
03Panther PowerDork
11/7/22 9:37 p.m.
I case it might have made it to me, that had been my plan, sorta, as well!
So will definitely be following along.
11/18/22 9:00 p.m.
E36 M3 just got real.  I picked up 5 jeep wheels and tires for $150.00.
I snagged a set of stock 330ix springs and a dash and center console as well.  The stock springs should give me about 2 inches of lift up front and at least 3 inches in the rear.
Stampie
Stampie MegaDork
11/18/22 9:32 p.m.
In reply to pimpm3 (Forum Supporter) :
You should have hollared.  I'm sure I have Vette wheels that would have worked.
11/18/22 9:36 p.m.
Vette wheels with all terrain tires?
Stampie
Stampie MegaDork
11/18/22 9:40 p.m.
Oh with tires?  Nope I sold that set a year ago.
03Panther
03Panther PowerDork
11/18/22 10:31 p.m.
I think the jeep wheels suit the look better, anyway!
John Welsh
John Welsh Mod Squad
11/19/22 10:11 p.m.
The Bruiser.
Named so for its tough black and blue combination.
Oapfu
Oapfu Reader
11/20/22 1:02 a.m.
John Welsh said:
The Bruiser.
And almost the same color as on the Tamiya Bruiser (r/c truck), unfortunately there is no place to put "Hog Heaven" door art.
https://4.bp.blogspot.com/-hiDLK4a3PQs/T39nni87yII/AAAAAAAAAgo/lI5FQWC7Sxo/s1600/IMG_1384-2.JPG
SV reX
SV reX MegaDork
11/20/22 6:24 a.m.
Awesome!
Mr_Asa
Mr_Asa UltimaDork
11/20/22 8:38 a.m.
Oapfu said:
John Welsh said:
The Bruiser.
Looks like a lotta space on that hood, to me.
11/20/22 6:11 p.m.
I wanted one of the bruisers so bad when I was about 10.  They were super complicated and expensive.
I had to settle for a Mud Blaster which was basically a Blackfoot with a Subaru Brat body.
11/20/22 7:53 p.m.
I trimmed out some excess body work and tried to mount the jeep tires.  They fit in the front as long as I don't try to turn.  The rears were not even close.
Since I had the wheels off to try to fit the jeep wheels, I threw the stock 325xi rear springs in the back.  It netted me several inches of lift, but still not enough for the jeep tires.
Who would have thought 31 x10.5's don't fit an e46 based dune buggy...
I am going to need to find something in a 27 ish inch diameter for it to work.
Stampie
Stampie MegaDork
11/20/22 8:31 p.m.
Need some taller springs?
hobiercr
hobiercr UltraDork
11/20/22 10:14 p.m.
In reply to Stampie :
Exactly. I think he needs to do a slight lift.
Run_Away
Run_Away Dork
11/20/22 10:25 p.m.
Big lifts make geometry wonky. Can you add spacers to the subframe(s)?
11/21/22 9:26 a.m.
Around 27" diameter your best bet would be some aggressive ATs or maybe SxS MTs. The best diameters for offroad tires are 15" and 17", for these relatively small tire sizes you'll want to try fitting 15s (maybe with 215/70R15s?). It's always better to cut fenders than to lift bodies, but it looks like there's no room for that in the front so you may need to settle for subframe + top hat spacers plus whatever fender trimming can be done in the rear.
11/27/22 5:45 p.m.
Dashboard is in.  Much more finished feel to the car.
Bought a few things on eBay to move the project along.
12/26/22 6:06 p.m.
Headlights installed!
iansane
iansane Dork
12/27/22 1:00 p.m.
I have the General Grabber ATx in 27x8.5-14 on my e30truck and they're awesome. I don't know if they still do the 27's in a 15" though.
¯\_(ツ)_/¯
¯\_(ツ)_/¯ UltimaDork
12/27/22 1:56 p.m.
Would these work?  How streetable are you looking for?
Tire Recappers - LT265/70R17 Retread Proforce HT
ApatwWI6WP2k7LTZeMXPkjrCwpc7bfElT8TbnKRuQ4vL1rsGtTSM4Q8iij9GgnOw
