Day-61(4-hours):
I got a late start today due to errands, and replying to a Craigslist ad for 2 C4 Vettes/parts for sale. It was mostly a bust, as he's more interested in clearing his yard than parting them out. I neither have the room, money, or time to deal with parting them myself. However, he also had this...thing.
It's an 84, but with a C5-ish body kit.
By the time I left he'd said he'll take $2500 for all 3, including a supposedly running L82/700r4 combo he pulled from the other 84, an 85 with a long block of unknown(probably bad) condition & 700r4, and the yellow mess above. My gut says he'd take less if you start counting out $100's.
One other stop was Harbor Freight to pick up a dial indicator & mount so I could check valve lift.
Granted, I'm no machinist, and I'm using the cheapest tools possible, but my measurements weren't anywhere close to the specs. I checked cylinders 1 & 2 and got the following measurements:
Cyl-1 intake .452
Cyl-1 exhaust .256
Cyl-2 intake .273
Cyl-2 exhaust .233
The cam specs are supposed to be .488/.509 at the valves.
I made sure the indicator was as parallel to the valve stem as possible, but I think the curvature of the rocker, and possibly the triangle stamped inside the end, were skewing my readings.
I also continued hanging the accessories & plotting the alternator mounting/belt routing. You can see in the pic below the stock locations, including the space where the air pump would have been, and the resulting problem with the belt route.
Moving the alternator upward seems logical, but then the valve cover will be in the way.
So I'll need to do a bit more research on my options.
In reply to Cousin_Eddie:
Thanks! I checked with a flashlight tonight too and it's definitely a blind hole.
