Dusterbd13
Dusterbd13 PowerDork
2/21/17 6:13 p.m.
That is a carter wcfb. Junk. But worth money to restorers of early 60s gm stuff with big blocks.
Stampie
Stampie Dork
2/21/17 6:15 p.m.
There's Cadillac owners that'll pay a lot for a core one of those.
petegossett
petegossett UltimaDork
2/22/17 8:43 p.m.
I found a scraper that worked a bit better for me than the switch plate, at least with the detail work around the thin ridges of the metering block & plate.
Woody
Woody MegaDork
2/22/17 8:58 p.m.
Brilliant!
chandlerGTi
chandlerGTi UberDork
2/23/17 10:34 a.m.
Helps keep your fingertips tough as well!
conesare2seconds
conesare2seconds HalfDork
2/23/17 12:11 p.m.
"Slow Intentional Damage" - serendipitous.
petegossett
2/23/17 12:21 p.m.
In reply to conesare2seconds:
It was the guitarists' old band from the late-90's/early-00's of the last band I was in. They actually put out a couple albums on some minor label & toured quite a bit, but never really took off. They sure lived the rockstar life for a while though...
GTXVette
GTXVette HalfDork
2/23/17 1:06 p.m.
Uh HuH, and you don't go for that fun stuff,aka It's only rock and roll.
petegossett
2/23/17 3:36 p.m.
In reply to GTXVette:
I've always been 100% clean and sober. I never thought the effects of any type of inebriation seemed appealing, so I avoided it. But damn if most of my bandmates didn't jump straight into it at one point or another.
Flight Service
Flight Service MegaDork
2/23/17 3:53 p.m.
Nice find in the dirty 'dell.
I hate C4s but after a story like that do something glorious with it.
GTXVette
GTXVette HalfDork
2/23/17 5:23 p.m.
That's GREAT, Most Bands I know of broke up after getting Sober, Just couldn't play the same, Tom Petty is My Fav. Sober band. Alvin Lee Is another, Wow, Just Two Bands come to mind, Got to be more though.
GTXVette
GTXVette HalfDork
2/23/17 8:10 p.m.
And The Moody Blues
petegossett
2/23/17 8:29 p.m.
I love Ten Years After, but never listened to much of Alvin's solo work. "A Space in Time" is one of my all-time favorite records.
AClockworkGarage
AClockworkGarage Reader
2/23/17 8:34 p.m.
I quit my band shortly after I got sober. Turns out I can't sing as well as I thought I could, and that wasn't a good enough reason to keep doing drugs.
They went on to be mildly successful. I did not.
petegossett
2/23/17 8:38 p.m.
Day-67(2-hours):
I'll be busy packing up tomorrow night, and I didn't want to haul the carb home in pieces, so I finished cleaning it up and reassembled it - sans gaskets: I knew I was in a rush to get it back together, but don't want to rush final assembly. So I'll pull it back apart after I get home and make sure everything is correct before final assembly. I'm also going to use Evapo-rust on some of the crusty bits to clean them up some.
I'm not sure if I'll spend this weekend working on the Vette, or hanging my $15 Rural King LED lights that arrived this week though?
Crackers
Crackers Reader
2/23/17 8:38 p.m.
Mildly Successful, is a weird band name....
GTXVette
GTXVette HalfDork
2/24/17 5:38 a.m.
Crackers wrote: Mildly Successful, is a weird band name....
Now that's funny right there. To quote Jonathan Winters, but negetive of his meaning so much Money, so much Fun
AClockworkGarage
2/24/17 6:20 a.m.
In reply to Crackers:
It's not that weird. but the band was actually called "Structure Divine."
petegossett
2/24/17 8:11 a.m.
In reply to AClockworkGarage:
I've always thought it would be fun to start a blues trio with a couple big hairy dudes & call it "Peter & the Twins"...except I lose interest about 8-bars through the first 12-bars blues song.
petegossett
2/26/17 8:14 p.m.
Day-68(2-hours):
I spent about an hour hanging one of my Rural King LED lights over my main workbench, which made a HUGE difference, then hung my bookshelf and got my "garage" books unpacked. These are all either for vehicles I no longer own, or ones I've never owned, but I figure odds are good I'll encounter one someday.
I did do a bit of work to the car. I'm actually holding off ordering more parts, as it looks like we might owe taxes this year. So I decided to look into the inop electrical issues instead. First I located & removed the ECM, I was surprised to see it looks clean without any indication of water damage. Since I won't be needing it the recoup value should help out.
I decided to try testing the electrics to confirm what is/isn't working - as I remember the power mirrors & interior lights worked, but the windows, wipers, and all exterior lights were inop. However, I discovered all electrics were completely dead...obviously everything was grounded through the engine block. Duh. So I clamped & jumpered all grounds together, but still nothing. So I'll need to dig a bit deeper, but my hunch is I'm still missing a ground somewhere.
petegossett
2/27/17 7:59 p.m.
Day-69(1:45):
I pulled out the original master cylinder & compared it to the new one. I was happy to see the new one came with the reservoirs.
I'm not ready to bench bleed & install it yet - I still need to rebuild the front calipers & install the front brakes, but I want to get the engine in first...
I noticed the brake switch was pretty crusty, but after cleaning it I think it'll be ok.
I also started removing the unnecessary EGR lines, but some of them are tied to the vacuum reservoir, so I'll need to do some research before I go too far.
Stampie
Stampie Dork
2/27/17 8:32 p.m.
Man it's great to see you back at it. I was getting the shakes from withdrawals.
petegossett
2/27/17 9:03 p.m.
Stampie wrote: Man it's great to see you back at it. I was getting the shakes from withdrawals.
Me too Stampie, me too...
GTXVette
GTXVette HalfDork
2/28/17 5:50 a.m.
Funny How long Two Day's can Be....
petegossett
2/28/17 9:06 p.m.
Day-70(1.5-hours):
I used the 3M abrasive disc on my drill press to knock off the loose & flaking paint from the valve covers, then hit them with a couple coats of brown Rustoleum "hammer-tone". You can still see most of the imperfections from the horrible GM casting & my spotty paint removal. I suppose I could have filled the pits with bondo & tried for a better finish, but I'm not even sure this paint will withstand engine temps.
Unfortunately half of the new Rural King LED light I'd hung over my workbench Sunday decided to quit working, so I guess I'll be finding out how good their return policy is.
sYqR3MmHiE5yso2BknOxPCg1FQyQ0nlYsKFUlb5maKcJn4UMXcgKG31EJ5RKWuFX
