Professor_Brap (Forum Supporter) SuperDork
5/13/20 7:08 a.m.
Did some ecu repinning that did not go as planned.
TurnerX19
TurnerX19 Dork
5/13/20 8:10 a.m.
Aw come on, round peg in a square hole works fine with enough force appliedlaugh
5/13/20 7:38 p.m.
Did some updating, thanks duster for swapping me springs!
Got that drag car stance.
Full 4x4 status. Letting them settle and time to align
5/15/20 8:25 p.m.
got my crank back, dude polished it/made sure journals are round, hot tanked it, and balanced it with the clutch and flywheel.
Got hyper tonight and checked bearing clearances and they were right in the middle, and installed the crank.
5/16/20 6:16 p.m.
Had to modify the pickup tube, and oil pump, and every hole got chased.
5/16/20 8:39 p.m.
So long story short, new oil pump and pickup needed some heavy massaging to make them work, and had a torn rear main out of the box.
The oil pump had huge burs, and pickup needed some massaging to fit right.
Donebrokeit
Donebrokeit UltraDork
5/16/20 8:42 p.m.
I was wondering about the oil pump, looked a bit ragged out.
When are you starting it up?
5/16/20 9:28 p.m.
I was very very unhappy with my new oil pump, I don't know think it would have lasted long if I didn't clean it up.
No set date, had to order some more small parts and clutch disk. Need to finish motor up, swap wiring harnesses and reassemble, build turbo feed and return lines, build intake.
5/17/20 11:31 a.m.
Spent the first half of my day mowing, washing cars and fixed the ac on white trash, iris and focus. All 3 had small leaks.
5/18/20 10:06 a.m.
White trash is going to alignment shop tonight, first time I have gotten a car aligned on a machine for the first time in probably 4 years.
5/19/20 6:48 a.m.
Air hosed a heavy coating of pollen off the engine bay. It definitely needs some cleaning up.
5/19/20 6:36 p.m.
White trash is all aligned.
1.8deg of camber up front. 1/8in toe in.
1.4 out back, 1/16in toe out
5/21/20 6:09 a.m.
Oil pump is timed and on, along with timing belt.
Took some time for CAD since some heat sheilds are long gone.
All finished up, a bit bigger than stock to try to keep some heat out of the intake.
Had to stop for a kitty break.
5/22/20 6:15 a.m.
Build the oil feed and the coolant return last night.
Feed has a filter.
5/22/20 9:24 p.m.
Crank and start, parked and got a crank no start. This is how my evening ended.
Dusterbd13-michael (Forum Supporter)
Dusterbd13-michael (Forum Supporter) MegaDork
5/22/20 9:39 p.m.
Part out time
5/22/20 9:42 p.m.
In reply to Dusterbd13-michael (Forum Supporter) :
Sell it and the good running efi car as a pair once I steal the parts I need. Still the plan, but you know how that goes.
Crackers
Crackers Dork
5/23/20 8:43 a.m.
I'm not sure if I'm more impressed that that mower has the torque to pull the car, or that it was able to find enough traction.
5/23/20 11:43 a.m.
In reply to Crackers :
The old Sears suburbans have a high and low range, wheels are loaded with 75lb wheel weights on both sides
5/23/20 12:19 p.m.
New ultrasonic could ultrasonic my old ultrasonic.
Tons of running today, mowed, did some teaching, and running for small parts.
5/23/20 7:42 p.m.
Started out the afternoon with a f-650 that doesn't charge.... then started charging again.
Moved onto turning fly wheel.
Took almost nothing off to get it good.
Then we prelubed the motor after putting on a good filter, making a ps tightener bracket, thermostat, and more odds and ends on.
Garden sprayer filled with oil is the best thing we have found for this. Works super good.
Bent-Valve (FS)
Bent-Valve (FS) HalfDork
5/23/20 7:50 p.m.
Nice!
And you made my day with your charger! I chuckle at the sight of it and yet again vow to make one someday.
laugh
5/23/20 9:04 p.m.
Bent-Valve (FS) said:
Nice!
laugh
That one is old mans, it's got a even bigger motor and alternator on his.
GIRTHQUAKE
GIRTHQUAKE Dork
5/23/20 9:59 p.m.
Nice!
laugh
It's basically just a motor attached to a truck alternator with an internal governor, right?
5/23/20 11:39 p.m.
Nice!
laugh
It's basically just a motor attached to a truck alternator with an internal regulator, right?
This is correct. Works like a dream.
pzkF9rEN1Y7nVwA4KfHuna5fEC552358BhbNIOUrPCZxsHuOXgkLDoxnifp3iLby
