NGTD
NGTD UltraDork
9/7/15 9:16 a.m.
Well I removed the engine this weekend.
Will have to order a timing belt and valve cover gaskets so I can fix that stuff while it is on the stand.
Time to get the damn parts car out of the garage!!
NGTD
NGTD UltraDork
9/11/15 10:52 p.m.
Timing belt and valve cover gaskets arrived.
Dropped the transmission out of the parts car tonight.
NGTD
NGTD UltraDork
10/9/15 12:36 a.m.
I haven't been able to get the parts car out yet. But I have been slowly selling parts off.
ssswitch
ssswitch HalfDork
10/9/15 11:57 a.m.
If you've still got the LF fender off the bugeye and it's not totally rotten at the base we should probably talk. Are you close to a Greyhound depot?
NGTD
NGTD UltraDork
10/9/15 12:46 p.m.
In reply to ssswitch:
It is a little rusty at the base, where it bolts to the chassis but still solid metal. Yes, we have a Greyhound depot right in our City, they won't ship across border AFAIK. You have somewhere you can pick it up in Canada?
NGTD
NGTD UltraDork
10/12/15 6:11 p.m.
Well I decided to send the parts car packing. A guy building a rally car wants the WRX wiring harness and I decided that it was too much work to pull, so I am giving him what is left of the car.
NGTD
NGTD UltraDork
10/15/15 10:49 p.m.
Tonight I went after the timing belt on the replacement engine.
When I pulled the covers I found this:
So I ordered a new one. Old one is off for now. New one will go on tomorrow.
Whoever put the crank bolt on the last time must have been Hercules! It didn't come off without a fight!
NGTD
NGTD UltraDork
10/16/15 9:29 p.m.
Big night in the garage (for me at least). Only the 2nd timing belt I have ever done and the first Subaru, also the first DOHC one.
All buttoned up:
NGTD
NGTD UltraDork
10/17/15 9:07 p.m.
The transplant patient is back in the operating room! (Pushing cars with no engines around really sucks )
NGTD
NGTD UltraDork
11/8/15 6:41 p.m.
One of the steering rack lines is completely borked and I can't get it out in the car. Pulling the rack out tonight.
Other than that engine is ready to go in! And . . . . . . . . .
When I am done, I want to sell it!
Why?
Because Rally Car. Stay tuned.
Acme Lab Rat
Acme Lab Rat New Reader
11/10/15 4:07 p.m.
NGTD wrote: When I am done, I want to sell it!
Go ooooooooooooooooooooooooon.
NGTD
NGTD UltraDork
11/10/15 10:23 p.m.
Well it looks like I borked the rack!!! The high pressure connection would simply not come out. I tried everything heat, penetrating oil, etc. I tried to drill it out and I think I made nothing but E36 M3 out of that.
Hopefully I can make a scrapyard run tomorrow afternoon. Looks like there is one about an hour away.
NGTD
NGTD UltraDork
11/12/15 12:04 a.m.
Got the steering rack from the scrappers - 3 hour round trip. Doesn't fit!!!!!!
Looks like the interchange information must be wrong.
NGTD
NGTD UltraDork
11/13/15 9:28 p.m.
Took the day off Monday - I have to make a 5 hour round trip to the nearest auto recycler that has the correct steering rack and return the wrong one.
Tonight I changed the right side cam cover gasket on the engine to fix a small oil leak.
NGTD
NGTD UltraDork
11/14/15 8:23 a.m.
Located an 05 STi rack closer to home. Pick up on Monday!
NGTD
NGTD UltraDork
11/16/15 4:48 p.m.
STi rack was not the right one!!!
That was a complete waste of a day. Turns out a local scrapyard had an 07 WRX sedan. Rack from it will work. They are going to pull it tomorrow.
NGTD
NGTD UltraDork
11/16/15 10:04 p.m.
The Rally of the Tall Pines is in 1 1/2 weeks and this is scheduled to be one of the Course Cars. I have a lot of work to do.
Tomorrow I get the new steering rack and new rebar, so tonight I pulled the tie rods off the old rack and the rebar off the car.
warpedredneck
warpedredneck Reader
11/17/15 3:10 p.m.
where are you located?
NGTD
NGTD UltraDork
11/18/15 1:26 a.m.
warpedredneck wrote: where are you located?
North Bay, ON
NGTD
NGTD UltraDork
11/18/15 1:29 a.m.
Well, I'm finally going in the right direction - parts going back on instead of off!
The steering rack and stabilizer bar are back on and the power steering hoses are installed. Turns out the 07 rebar is missing a piece but I was able to remove it from the old rebar and I just have to install it.
NGTD
NGTD UltraDork
11/19/15 12:07 a.m.
Long but productive night in the garage. The patient has a heart again!!!
NGTD
NGTD UltraDork
11/20/15 12:44 a.m.
Did a lot of small stuff tonight:
  1. Downpipe bolted up (new mls gasket)
  2. Transmission bolted up
  3. Starter attached
  4. Clutch slave cyl reinstalled
  5. Boost controller and wiring all reconnected.
Hope to get it running this weekend!!!
NGTD
NGTD UltraDork
11/21/15 12:45 a.m.
Just have to finish:
  1. Intercooler and intake piping
  2. Install radiator
  3. Fill coolant, oil and power steering
  4. Connect downpipe to remainder of the exhaust
Then it will be time to fire it up!
NGTD
NGTD UltraDork
11/23/15 9:03 a.m.
A Subaru returned to it's natural environment!!!
Mother nature kindly provided us with about 10cm (4") of snow to go with my roll-out. I still have a couple of small issues to fix. I have a CEL (05 ECU expects to see a PCV sensor that the 02 motor does not have - this will be a PITA to fix) and a small exhaust leak.
NGTD
NGTD UltraDork
11/25/15 8:47 p.m.
Well that didn't go well.
I was heading out to get it certified after working through several small issues. Only a couple of minutes from home it started look power and I got a flashing CEL.
Took it home - P0304 - Cylinder 4 misfire. Started troubleshooting and the plugs are all white, which would seem to indicate it's lean. The car has sat for a while so a guy I know that knows Subaru's suggested changing the fuel filter.
Of class in 2005 Subaru changed from an easily accessed on under the hood to an in-tank one that is harder to change and get to!
nOKDkf0kd7uPN0f7PnMGGphj6c0cUowdnUuRCvXLTzrmKYLi2aJKwO3qZ9q81kU6
