vwcorvette
vwcorvette SuperDork
1/18/18 8:00 p.m.
Will getting caught up in real time not open up a rift in the space time continuum creating a massive singularity whereby a Biturbo appears at the Challenge and wins outright first time?
<<Shudder>>
1/18/18 9:40 p.m.
I would love to see the Nelson magic on a Biturbo.
Rufledt
Rufledt UberDork
1/18/18 9:57 p.m.
I can see it now. Rip out the biturbo, insert 350, add lightness.  Best, most reliable, and fasted biturbo ever will result.
wheels777
wheels777 SuperDork
1/19/18 5:42 a.m.
You people who have this unhealthy attraction to BiTurbos really need to get some help.
TheV8Kid
TheV8Kid HalfDork
1/19/18 6:53 a.m.
Day 90 - November 8, 2017
Welded in cap plate on frame. Ground out and rewelded several factory welds. Made closeout plate for motor mount. Started to grind off rust for paint.
mazdeuce - Seth
mazdeuce - Seth Mod Squad
1/19/18 7:10 a.m.
If you guys didn't have to worry about budget, would you tube the crossmember and front frame instead of keeping the factory metal?
TheV8Kid
TheV8Kid HalfDork
1/20/18 9:27 a.m.
In reply to mazdeuce - Seth :
Yes. It would probably look something similar to this.
TheV8Kid
TheV8Kid HalfDork
1/20/18 10:29 a.m.
Day 91 - November 16, 2017
Worked on firewall.
TheV8Kid
TheV8Kid HalfDork
1/21/18 6:27 p.m.
Didn't have time to update until just now. Sorry guys.
Day 92 - November 20, 2017
More welding, grinding, fabbing, sanding, prepping...prime and painted the front end. And a parts run to Sahd's.
Crackers
Crackers Dork
1/21/18 6:31 p.m.
Holy crap, I'm jealous of your scrap pile. LOL
TheV8Kid
TheV8Kid HalfDork
1/22/18 5:13 a.m.
Day 93 - November 21, 2017
Cleaned and lightened A-arms.
solfly
solfly HalfDork
1/22/18 9:27 a.m.
all caught up, incredible build
TheV8Kid
TheV8Kid HalfDork
1/22/18 11:59 a.m.
In reply to solfly :
Thanks!
tuna55
tuna55 MegaDork
1/22/18 12:04 p.m.
Was there any testing done on the stiffness before/after on those control arms? I'm not sure that weight was entirely useless.
Dusterbd13
Dusterbd13 MegaDork
1/22/18 12:20 p.m.
Im interested as well. Seems like it would be a weight/stifness ratio that y'al followed.
But it definitely gives me ideas.
wvumtnbkr
wvumtnbkr UltraDork
1/22/18 12:26 p.m.
eh, they wont have any load on them when they are 4 inches off the ground.....
TheV8Kid
TheV8Kid HalfDork
1/22/18 1:12 p.m.
I like the way you think.
TheV8Kid
TheV8Kid HalfDork
1/22/18 1:23 p.m.
In reply to tuna55 :
In general we try to remove 10% of the mass from any piece we touch. The curb weight on these cars is around 3200 pounds. We hope to be around 2600 pounds with driver. There has also been an 8.75 inch engine setback taking even more weight off of the front end.
wheels777
wheels777 SuperDork
1/22/18 4:06 p.m.
No tests needed.  Just fundamental engineering principles applied.
Crackers
Crackers Dork
1/22/18 4:36 p.m.
I used to see this all the time on the pro-stock circle track cars.
A couple gussets per side and they're actually stiffer.
bluej
bluej UltraDork
1/22/18 4:51 p.m.
No dimple die for those holes? Seems it would add stiffness back, buy that's just assuming..
wheels777
wheels777 SuperDork
1/22/18 6:07 p.m.
Free body diagram.  Assume spring is in center laterally (it's not), assume the spring is concentrated over one side of the a-arm,  assume 700# wheel weight (it's not), assume we over tightened the bolts (we didn't), assume 2G load from bumper dragging wheel stand and driver panics, 240#/in spring and high damping rate. Thoughts?
bluej
bluej UltraDork
1/22/18 6:15 p.m.
Assume I've got a BFA and not a BS cheeky
But hey!, logic:
Since you've dimpled elsewhere, I figured you decided you didn't need to here, but was curious the reasoning since I wasn't sure how it could hurt.
wheels777
wheels777 SuperDork
1/22/18 6:18 p.m.
But hey!, logic:
It would negatively effect the tension line on the lower part of the vertical stiffener.... and if it would be a benefit.... the die won't fit.
FWIW, the force would have to exceed 4,710# tension to reach SMYS.
TheV8Kid
TheV8Kid HalfDork
1/23/18 5:22 a.m.
Day 94 - November 22, 2017
Drilled new holes for upper a arm mounts. Cleaned and painted steering components.
YsYKzH8Zf8m7xOgi1WQS8xEUHJ6JqZZasOQtZrJ9XDpGf08BE7aWLJE9c7L8nEcF
