1/6/24 4:59 p.m.
I keep going back to the taillight project. Outstanding stuff!
Manual_Trans
Manual_Trans New Reader
1/9/24 1:27 p.m.
This is one of the best looking R32s that I've ever come across. The color pallet is perfect. The green is beautiful.
R32Jordie
R32Jordie New Reader
2/21/24 4:41 p.m.
Thanks for all the kind words. I am still trying to finalize the ducting package.
For the exit duct, Due to packaging constraints, I had to exit out the side.  Im not 100% happy with the exit portion of it but the middle section maximizes all the available space.  Ideally It would exit out the side of the bumper But I cant bring myself to cut a hole in it just yet.
It is still too cold here outside Ottawa to play with resins and composits so that will have to wait a little.
I did add a little mesh and whipped up a little ricer badge for my grille. it should be good for about a 15hp increase so time well spent for sure.
Lastly, I managed to finally track down some media from the final (and only) round I had the car at.
Its so fun.
Only a few weeks left and I can fire up the parts cannon to get it ready for the season
-Jordie
R32Jordie
5/7/24 7:42 a.m.
Finally got the car tuned on the ECU Master Classic. We had no issues or dramas besides the intercooler piping coming off once.
The car ended out making 305hp/ 254tq @16psi on 91 octane. The turbo and fuel octane are the limiting factors at the moment.
Ready to go for this weekends autocross event.
-Jordie
golfduke
golfduke Dork
5/7/24 10:08 a.m.
VERY awesome color.  I highly approve.
R32Jordie
5/8/24 7:18 a.m.
In reply to golfduke :
Thanks, It changes so much in different light. I love it.
R32Jordie
6/10/24 12:49 p.m.
A couple weeks ago I signed up for the pre season Test and Tune / Autocross school day with my local club.
It was the first time out with the car since its been tuned. The car preformed flawlessly all day. The event allowed for way more seat time over a typical autocross round.
The day started out nice but then it poured rain just after lunch.  This made the car a bit more of a handful as any sort of drifting is frowned upon.
Ive got some actual lapping days coming up in July and cant wait to really put the car through its paces.
-Jordie
R32Jordie
7/17/24 10:31 a.m.
My first autocross round did not go well. I managed to get one run in before the car started going into a limp mode. Turns out the TPS was going out of calibration, the ecu would see the raise in RPM without throttle input and cut power to the injectors at 2000rpm.
I managed to get the car home and the shielding on the TPS wiring was grounding to the signal wire causing the wonky voltage. Easy fix but annoying nonetheless.
I decided to channel my inner Adrian Newey and chucked on the diffuser I had kicking around the garage. I had ordered it in FRP pre covid from ebay and was pleasantly surprised when it showed up in carbon.
Its probably a hinderance but it completes the look of the rear which I’ve always thought sits a little high without the rear valance I had before.
July 7 I had a Evening lapping session booked at Calabogie Motorsports park. Up until this point, I have only ever really driven on tracks with zero elevation. I think this event was the most fun I’ve had with this car. I did 2 x 30 minute sessions in behind a pace car. We were grouped in Pods based on skill level and experience, the pace was decent and it was a great way to learn the line of the track.
The brakes (with the cheapo Rockauto Pads) were phenomenal and all the cooling mods meant that the car barely hit 90deg C the entire session.
I drove up with my Dad in his BMW 2002. Was a fantastic driving road up to the track.
This past Monday I got invited to a private track day at Shannonville Motorsports park. We had the whole facility for about 15 cars. I ended out doing close to 100km on track, the car just did lap after lap without any issue at all.
The car needs a nut and bolt check and other than that its ready to go for the next round of autocross.  The Valino tires which came with my Advan wheels probably have a bout 30% life left in them after the 2 track days and I will run them until the end of the season.
Good car is good.
R32Jordie
9/30/24 8:16 a.m.
Its been a busy summer to say the least but its the first time since 2020 that the car has been driveable the entire season since the great lockdown of 2020
I've been doing autocross every couple of weeks which has been an absolute blast. The car is a handful (especially in the wet)
I ran out of talent when the track started drying out and hit a few cones. The impact broke the mounting tab on the FRP fenders and cracked the paint on the bumper.
I Printed some mounting tabs from ASA filament and bonded them to the inside of the fender. But since the bumper had been scuffed, I didn't really feel bad about drilling into the bumper.
Garage defend canards finally mounted.
I had Martino from Design Shop React, make up some number plates so things are getting really serious.
The canards and rear diffuser make the centre of the car look really high. I finished printing the side skirt extensions and did a quick test fit.
I think they tie the lines at the bottom of the car together perfectly.
To match the rear diffuser, I decided to try carbon fibre skinning for the first time and boy is there ever a steep learning curve. Its my first time ever trying this (and I should have started on a simpler part). The issue I am having is the cloth keeps lifting from the part once I fully wet it out. So far the best method has been putting the epoxy on the part and waiting for it to get to a “B Stage” cure. Then you put the cloth on and wait for it to dry before fully wetting it out.
And now we sand. Forever.
Tora
Tora New Reader
9/30/24 10:46 a.m.
Remember to use protection. Those carbon fiber particles are nasty.
And car looks really cool.
R32Jordie
9/30/24 12:59 p.m.
Thanks!.
And yep. I am pretty religious about wearing my respirator, long sleeves and gloves. Its tricky but a fun medium to learn
-Jordie
CCJ7KC85oJFI1i1PImMfNTBETtjzNazRBV6DsHzJ6iGTSY6zYxn6DMDIM0ukNlXC
