Started in rearing the 86 saab 900 turbo. It is almost like starting a fresh build. All the rubber hoses were original 1986 pieces in 01 now they won't hold up now. I taught my daughter how to drive in this car and she drove to in high school. The pinion bearing is toast and locks up the car rolling backwards. I have another transmission to install. And some remnants of the last 100$ parts car.
I am not sure where to start with the budget. All the repairs are just maintenence items. The plan is to drive it down.
Powar
UltraDork
8/25/15 7:36 a.m.
Stan: If you end up needing any more parts, let me know. I just bought another '87 Turbo parts car over the weekend.
In reply to stan_d:
Welcome back, Stan. Looking forward to seeing more of the older Challenge cars.
Removed the engine and transmission now to clean a bunch of grime. And swap the transmission. I hope the box I stashed years ago is good.
I sent a pm to power.
XLR99
Reader
8/27/15 5:49 a.m.
Post up some pics of your adventures! I'll be (someday) pulling my C900 engine for an auto>manual swap once I get parts car(s) home.
Pulled the gear box out of the barn. Both inner drivers are bad part of bell housing is broken and it is a short ratio. #6
I swapped the primary chains front broken box (bad pinion bearing and pops out of 1st and reverse. ) #7 to the other box. Cleaning up parts to swap inner drivers out.
A lot was done today. Swapped the inner drivers and installed the transmission to the engine. Replaced the water pump and steering rack. Discovered the exhaust manifold gasket is bad.
I broke a wiper arm. Now to find one.
Need help with budget. This car was last used in 2004 challenge. After that I drove it and then gave it to my daughter. She drove it for a year. Then hit a deer. It sat till 2012. I bought a parts car for 100 and installed needed parts. Then it sat till this summer.
In the process of getting Ready I have changed the transmission replaced all radiator hoses. Rear brakes and calipers. I have had to work on just about every system on t he e car.
My question is starting point for the budget. Non driving examples of saab 900 are 400 by me.
I removed the nos.
It moved under its own power today.
XLR99
HalfDork
10/7/15 7:48 p.m.
Cool!
Oh, this applies in this thread as well:
I removed the nos.
I'm just going to WAG this, maybe people can agree or disagree.
used at the 2004 challenge, establishes value at $2004. Hit deer, plus driving/sitting for 10 years easily chops the value in half. I'd say you started at $1002 + 100 parts car, so total = $1102.
If you can sell the NOS, I'd say that counts as whatever you sell it for negative on the budget.
stan_d
Dork
10/11/15 4:43 p.m.
Day started rough. Broke my new s5 by sitting on it. Then the paint orange pealed badly. Also while masking
This happened.
I did get the alignment done.
stan_d
Dork
10/11/15 6:48 p.m.
Took her out for a test drive. Runs and drives good a little squeaky. But this is first time driving at speed.
