timster
timster New Reader
10/12/20 5:27 p.m.
Looking to buy a 2wd first gen S10/S15/Sonoma. Had several of the truck/suv first gen types years ago when they were just run of the mill used vehicles, band always had a soft spot for them. I started looking for one as a weekend project to tinker on. After missing out on several, and test driving a few that were thrashed, finally found a decent one at a reasonable price. Front end was a little loose feeling though. Haven't bought it yet, but thinking I will.
Question, what all tend to go on the front end of these? The front shocks seemed a little worn, so that's a no brainer to fix. Going from memory, but seems like the rag joint is something else to check. what else needs checked out, guessing idler arm, ball joints. What else am I missing?
Dusterbd13-michael (Forum Supporter)
Dusterbd13-michael (Forum Supporter) MegaDork
10/12/20 5:32 p.m.
My experience: tie rods and pitman wear pretty quick. Also, the bix has some adjustment in it if theres too much slop there.
Really,  its a matter of jacking it up.and checking for play. If its all tight, its probably the box or rag joint.
RevRico
RevRico UltimaDork
10/12/20 6:05 p.m.
My 4wd ATE tie rods and ends. Like a set every oil change.
einy (Forum Supporter)
einy (Forum Supporter) Dork
10/12/20 7:53 p.m.
Rag joint where the steering shaft connects to the steering box goes to heck.  Replace with a Dorman refurb part, or better yet the entire lower shaft with a u joint type from a Cherokee.  Other than that, tie rod ends and tbe aforementioned pitman arm thingy.
10/12/20 9:35 p.m.
Lower ball joints will lose their press fit in the control arm. LCA bushings get worn and make the truck wander.
ClemSparks
ClemSparks UltimaDork
10/12/20 10:34 p.m.
It's an old-school (non-Rack-and-peanut) steering system so the components that wear out and cause problems are:
Inner Tier rod ends, Outer tie rod ends, Idler arm, lower ball joints, upper ball joints, rag joint, steering gear/box, control arm bushings, sway bar bushings, sway bar end links, shocks, springs.  In other words:  all of them.  I might have missed one or two, though ;)
They're probably not all bad at once...but I guarantee replacing it all at once will make a WORLD of difference ;)
Amatuer tip:  if you have the lower control arms out, it's a good time to replace engine mounts.
10/13/20 7:17 a.m.
ClemSparks said:
Amatuer tip:  if you have the lower control arms out, it's a good time to LS swap it
fixed
c2TO5xFleK1Nbhieo74UflywmiZRZV92vvVHxvtqSWAfmT1yIx8U7WpgAhBIeQUx
