darkmedievaltimes
darkmedievaltimes New Reader
3/19/24 10:20 a.m.
Summer of 2022 my 74 Corolla SR5 saw very little of the road and even less the following year. This year that changes.
I've had this car since 2010, ended up driving it less and less in recent years. It has built 3tc, weber 45s, etc. After experiencing the 123 tune + distributor in my other TE27 which has more mild setup and a pair of weber 40s I have newfound motivation to see how well I can make this run.
Currently the front suspension and brakes are AE86 based, coilovers, adjustable tension rods, & camber plates. Being an SR5 model the rear end third member closely matches the AE86, both are 6.7" ring gears and the early AE86 LSD is a direct fit so this car has a 3.70 final drive with LSD.
Before it hits the road I need to rebuild the front end, new carbs and intake, and install the 123 tune +.
DeadSkunk  (Warren)
DeadSkunk (Warren) UltimaDork
3/19/24 12:27 p.m.
Welcome to the forum. Love the TE27s. Lot's of interesting old Japanese tin still available in your neck of the woods, colour me envious. Updates and pictures, please.
darkmedievaltimes
3/19/24 4:51 p.m.
This is 1 out of 5 total TE27s. If you need a windshield for your 73 let me know, my dad and I had them remade to match the factory one exactly.
DarkMonohue
DarkMonohue Dork
3/19/24 11:29 p.m.
Well, alright.  Let's see where this goes.
dannyp84
dannyp84 HalfDork
3/21/24 4:34 p.m.
What's a 123 tune ?
SpeedAddict502
SpeedAddict502 New Reader
3/21/24 11:44 p.m.
Programmable distributor
darkmedievaltimes
3/22/24 9:41 a.m.
In reply to dannyp84 :
Here is a link, this allows you to customize the timing curve from an app on your smart phone
123\ignition | Toyota Celica (2TG-Motor) | Online-shop (123ignition.de)
darkmedievaltimes
3/22/24 9:50 a.m.
More TE27 content: jumped on the FJ40 headlamp bandwagon. This is my green TE27 which was parked in 1982 until I got it in 2018 and I'm confident the headlights have not been changed since my ownership.
DarkMonohue
DarkMonohue Dork
3/22/24 9:14 p.m.
No regerts on the headlight swap. That will be hugely better than the old sealed beams.
Has your IG account changed? I was going to ping you this morning, but your account was called "Instagram User" and there was no content at all. Very strange.
darkmedievaltimes
3/25/24 9:10 a.m.
In reply to DarkMonohue :
I just recently reactivated it after a short break!
darkmedievaltimes
4/22/24 12:38 p.m.
A familiar sight
darkmedievaltimes
4/22/24 12:59 p.m.
123 tune + from 123 Ignition DE has landed
Shavarsh
Shavarsh HalfDork
4/22/24 1:12 p.m.
Is the headlight upgrade a drop in? Or are there wirirng changes. Very interested.
darkmedievaltimes
4/22/24 1:45 p.m.
In reply to Shavarsh :
I used the relay harness on one car but not on another. You can use it either way.
darkmedievaltimes
4/24/24 9:08 a.m.
Setting up the 123 distributor is much easier than I remember. I got the car fired up but there is a nasty intake leak. At first thought I considered the idle jets could be too small but at 2.5 turns out and the wideband being pegged lean and the car running inconsistent and poor it is time to take a closer look.
Xtrolla1
Xtrolla1 New Reader
8/31/24 10:15 p.m.
In reply to darkmedievaltimes :
Hello, I have 1974 te27 2 door Corolla , I came across your post, I need a front windshield for my car, can you please help me
7vr3pw8QXiyq4ZsBN9mzLk31nBGHKyDHiugWHOpHf5YMypAi02Fzcg7R23dOcLbw
