Welp, someone came over earlier than anticipated today, so she's already in love with it and yelling at me to fix it. Except she won't let me work on it...
Odd, the picture of the motor didn't transfer. oh well, we all know what mini motors look like.
Tech Manuals/wiring diagrams
I'm going to print them out, but having a link here will make last minute or late night research easier for me.
So. I did see the motor run before purchase on a test bench. According to the guy who rebuilt it(piston seals and rings), he rebuilt the starter but it spins backwards and while I can work around that, a new starter is cheap enough. It also doesn't look like I can clear the exhaust around the starter that is on it anyway, so it's in my interest to swap it out. He also had a fancy plastic spacer for the carb. Turns out, that's a rather important 1/4" piece of black plastic as it actually lets the carb fit on the motor. Hey, I've got a set of digital calipers, a 3d printer, and a spool of ABS, maybe I can make my own.
Also according to the guy I got it from, I should be able to make one good wiring harness from the 2 he gave me. Looks like there's only one piece I need to take off of one to put onto the other for everything to work. Some sort of solenoid. I really should have wrote down what he was telling me because my memory is pretty nonexistant. Luckily, he's a pretty nice guy, and we have some friends in common, so double/triple checking shouldn't be too much trouble if I can't figure it out myself. Also, the fact that parts and diagrams are the same across the model lines should make figuring it out easier.
The current plan is just to get it together and running. I might paint/plastidip the body to match the wagon, I might not. Eventually though, I'd like to be able to tow the wagon or a garden cart with it, so I'll be fabbing up some sort of mount for that. The wiring harnesses also have spots for light, and the push button start is on a light switch, so might have to add some lights, maybe some RGB LEDS.
The chain appears to be a bit short, so a chain buster and a master link set are in my future. Easier to buy a longer chain? Sure, but come on, I don't own these tools yet, perfect reason to buy them.
Once I get a total on all the parts and shipping I'll have a better idea on how soon this will be completed. I just don't think a 3 year old will understand "You're birthday present isn't ready yet because slow boat from China".
Anyone else have one? Anything I'm over looking or over thinking?
EDIT: Also, I need to get tubes for the tires. Would I be better off with tubes or just new tires? I've got 2 beads set and holding air, one bead set with a constant leak, and one that won't seat. I'm thinking the leaky one and one that won't seat can just get tubes, but if there are reasons that's a bad idea, please let me know.
Late edit for my referencing.
Your Cart
Chinese ATV Tire Tube 145/70x6
$ 4.95 x 4
$ 19.80
Chinese Starter - 50cc to 125cc Engine - 2 Bolt - Version 8
$ 15.60 x 1
$ 15.60
Chinese ATV Remote Control Alarm Box System Set Version 6 for all Taotao ATVs
$ 29.95 x 1
$ 29.95
Chinese ATV 12 Volt 4Ah Battery
$ 13.29 x 1
$ 13.29
Chinese ATV Handlebar Brake Master Cylinder with Lever Left Side Without E-brake - Version 7
$ 9.95 x 1
$ 9.95
Subtotal$ 88.59 USD
That also qualifies for free 5-6 business day shipping. Berkin' A.
