SuperDaleJRHotDogUSA4Ever
SuperDaleJRHotDogUSA4Ever New Reader
4/21/23 8:29 p.m.
Hello, I'm a new member and I apologize if this post is in the wrong section.
I have a bit of an undertaking on my hands, and I don't know if I should continue with it. It's an old extended Ford Aerostar.
I decided to rebuild the motor, swap it to a manual, convert it to true 4x4 and to slide in solid axles. When I started this project,
I didn't realize how much of an undertaking this turned out to be. I know this van inside and out, what I need to do to pull this off and make it reliable. I have most of everything I need, currently Im building a budget to get the ball rolling and took up fabrication classes to properly convert this thing into an offroader. This is my 5th project, each one has been something I wanted to either restore or turn into drag car and each one has failed. Ive learned a lot throughout each misguided attempt. I have the image of what I want to do, a plan on how to do it, but I dread looking at it as I fear it'll just turn into another failed project and the kicker is that I have another car that I fell head over heels for when my van crapped out. It is a 96, manual Jeep Cherokee. It's an absolute joy to drive, to maintain, everything about it is just perfect. I very much want to move on and start restoring this Jeep. However, I dont want to give up on the Ford. I feel as if Ive put in way too much time, work and money to just call it quits. What should I do?
Stampie
Stampie MegaDork
4/21/23 8:37 p.m.
I saw this and said why the berkeley is Dale berkeleying around with an Aerostar?  My 2 cents.
TurboFource
TurboFource HalfDork
4/21/23 9:35 p.m.
XJs are cool ..... nuff said
ToManyProjects
ToManyProjects New Reader
4/21/23 9:54 p.m.
If you're not familiar with the sunk cost fallacy, now would be a good time to read about it.
NOHOME MegaDork
4/21/23 10:44 p.m.
Could you please post a picture of the project?
wvumtnbkr
wvumtnbkr PowerDork
4/21/23 11:17 p.m.
If you REALLY want to keep going on the project, get a buddy and some beer.  Just go poke around and work on something, anything for 30 mins.
Where are you located?  There is probably a grmer near you that can help either motivate or help you to pull the plug.
jovibuilt
jovibuilt New Reader
4/22/23 10:30 a.m.
If you do the Aerostar I have a bunch of manual swap parts I would sell. Clutch pedal, mod trans  mission top with he shifter in the right place and clutch line and master cylinder new. Just letting you know. I hope you do the van I always wanted to do one.
NOHOME MegaDork
4/22/23 12:21 p.m.
Is it just me, or does the original post not read a lot like the one where the poster wanted to become a notable persona in the racing world after one year and 100k budget?
John Welsh
John Welsh Mod Squad
4/22/23 12:48 p.m.
In reply to NOHOME :
I see what you are saying though, an extended Aerostar converted to manual is a rather obscure reference.
Im guessing the intended is more like...
TRoglodyte
TRoglodyte UltraDork
4/22/23 1:59 p.m.
Not just you
4/22/23 6:29 p.m.
In reply to wvumtnbkr :
Im going to start doing that just to see if I really do want to give this up, thanks for that. Im located in Virginia.
4/22/23 6:31 p.m.
In reply to John Welsh :
yeah that's pretty much the build I'm after.
4/22/23 6:33 p.m.
Thanks man, I might be interested in that M5OD, I'm not sure if just one will last behind something like this. I already have the clutch pedal and lines.
3PPGdSUSjZ2xiyd4bZnVTmkDUn7LBwK9ljCphnVmvroRx9XnVdzqaBxoQAqINkwS
