Ok, I got impatient. Ended up installing the 24lb injectors, larger MAF etc tonite, much to my wife's dismay. ![](/media/img/icons/smilies/evil-18.png)
Ok, first you have to take off the strut bar and beauty cover to get to the fuel rail...
![](http://photoberkit.com/copper/albums/userpics/10011/normal_IMG_2658.JPG)
Then I pulled the old MAF, throttle body boot and boot from my Dinan intake to the stock MAF. The plug on the stock MAF just unscrews, so now you're left with this.
![](http://photoberkit.com/copper/albums/userpics/10011/normal_IMG_2659.JPG)
Big difference between the MAF's, larger one is the Porsche "803" MAF. The wiring isn't quite plug n play. You need to splice two ground wires on the stock harness, or Turner Motorsports makes a really nice plug n play adapter. That's the way I went as others have had issues with weird running behavior when they spliced the stock MAF harness.
Ok, now it's time to play with fiddly injectors clips, woohoo! There are little C clips that hold the injectors to the rail, then even more fiddly little clips that lock the wiring harness plug into the injectors. Take your time to remove these and don't drop them!
![](http://photoberkit.com/copper/albums/userpics/10011/normal_IMG_2662.JPG)
No pictures of me swapping the injectors. Getting the injectors seated and all the clips back on properly took me forever, especially the injector up against the fire wall. I dropped my screwdriver down between the clutch fan and radiator, plus dropped a few of those clips. Luckily I found them all. Finally got everything back together and seated the fuel rail by hand at first, then a few light taps with my rubber mallet to get everything completely seated.
![](http://photoberkit.com/copper/albums/userpics/10011/normal_IMG_2664.JPG)
OK, lets get the new Mishimoto throttle body boot on, with the new 803 MAF and the new interconnect from the Dinan intake to the MAF. Um, hmm. Ok, my old hose clamps are too small and won't go around the larger MAF. Damn, too late to run to the hardware store.
I turn my garage and basement upside down and either find clamps that are too small or too big. Hmph. The boot seats tightly, so it should be ok for me to trial start it at least. Turns out the 4" interconnect I bought is at least 1" too long, I'll have to trim it before I put on the new hose clamps I plan on buying tomorrow.
![](http://photoberkit.com/copper/albums/userpics/10011/normal_IMG_2665.JPG)
Ok, time to load the new map. Unfortunately when I try and launch the software it tells me its out of date! A quick email to the company yields the link to update it. Do that, then I have to jump pins #14 and 18 on the diagnostic port. This is a huge pita. Get that done, upload the new map.
Cross my fingers and fire it up. It fires off but runs roughly for maybe 5-10 seconds or so then smooths out. I check codes and there are some air injection codes and a check engine light on code. I clear them. Then key off, and start it again. It fires immediately and falls into a happy, smooth idle. I give it some gas and it smoothly revs up, success!
