docwyte
docwyte UltimaDork
12/4/24 9:45 a.m.
I can't stand wheel locks and immediately remove them from all my cars.
iansane
iansane SuperDork
12/4/24 10:43 a.m.
Ah, gotta love the swedes.
That's some impressive adult'ing, sir. I would not have that restraint, which I'm sure you know.
AClockworkGarage
AClockworkGarage Dork
12/7/24 2:07 p.m.
I picked up the new caliper and managed to get it painted.
It's not a perfect match. The bracket is the OP's paint job, the caliper is mine. If you stick your face in there you can tell, but from 10 feet away, through the wheel, it'll be fine.
Just needs to be bled now, which isn't something I can do on my own.
I missed the cars n coffee...
AClockworkGarage
12/9/24 4:29 p.m.
The brakes are bled and I took her for a spin. Everything seems fine so I'll drive her to work today and find out for sure.
Some cosmetic updates. When putting my plates on I noticed that the front plate holder was attached to the bumper with double sided foam tape.
Nice. No holes in my bumper. But foam tape isn't the strongest thing on earth. it would eventually come loose. I decided to be proactive and found a tow hook style plate holder. I found on on E-bay. It was inexpensive and arrived relatively quickly. As with all things from E-Bay that are guaranteed to fit, it didn't fit.
If you powdercoat something with threads, the threads get larger... I took it to work, rummaged through the Metric Dies box that nobody ever touches and found the right one. A quick thread chase and we're back in business.
This time it threaded right into the tow hook port and I was able to assemble the rest of the holder.
I removed my plate from the original holder, mounted it on the new bracket and made the fun discovery. The tape had started to peel away already. PO had solved the problem by blasting a couple self tappers directly into the bumper.
I think I just sat there for a half hour. I thought about just putting the plate back and going on with my life. But I had "modified" the new holder and wouldn't be able to return it.
The only way is through.
I figured Id head down to the hardware store, get a couple of those plastic push-pins to fill the holes and move on with my life.
But my car isn't quite white.
I'll get some colour matched paint and spray the push pin heads.
that seems like work. Surely someone else has come across this problem. A quick Google search directed me to BumperPlugs.com, a company that sold properly paint matched plugs to solve this exact problem. They're not cheap, at $35 a pair, but that is way cheaper then repairing and repainting the whole nose of the car. I decided to give them a go. I'll report back when the arrive.
Lastly my venerable old magnetic numbers have decided that they're ready to rest now...
I contacted the company that made them to see about getting another set. A few emails back and forth and we had a design. They arrived about a week ago.
looking sharp.
one more project before I can shove the camaro back in the Garage. I picked up an IPD rally skidplate a while back and I really should get that mounted up. The roads suck around here. but Capitalism is unstoppable despite my best efforts and I have to work all weekend. So maybe next weekend.
AClockworkGarage
12/17/24 4:18 a.m.
So. Good news and bad.
Since buying this car I've been trying to find a rattle from the rear end. I found it. The rear brake service has eliminated the rattle.
The suspension is now quiet enough that I can hear the wheel bearing that is failing.
$100 bucks and a new one is on the way.
Got the plugs in on Friday.
Had to enlarge the holes and just stuck these in. Perfect match.
That's all for now.
brad131a4 (Forum Supporter)
brad131a4 (Forum Supporter) HalfDork
12/17/24 6:42 p.m.
Wife liked these but never fallowed through on one. See that you're some what close in the Tacoma area. Swear I've seen a house that purple color on 18 in Auburn while driving for work.
Going to try to get to The Ridge for the Lucky Dog event in April. Just going to watch for now. Might try and see what it would take to get on track for fun.
AClockworkGarage
12/17/24 10:05 p.m.
In reply to brad131a4 (Forum Supporter) :
I'm not in Auburn, so that's not me.
We are also trying to get to the Ridge for April... no guarantees though. Details in the other thread.
AClockworkGarage
1/7/25 1:46 p.m.
Hee hee... neat.
DsrTPSKOBCrBJWT2c1Rzu8Rv9IzFy21LbIF20x9fClyr1doX3FJIf7sinFz74Emu
